Hello all,
Right now I'm going through most of the D35 in my 93 Ranger and i had a few questions. I bought all three new U-joints and have the outer u joints installed and would like to do the middle u joint, but im not positive how to get the shaft out off the differential. I assume there is a clip inside of the pumpkin..If that is true, what is the easiest way of getting this off? I've read about some C clip eliminator writeups, and i do have the echo spring to put between the passenger shafts, does this spring eliminate the need for the inner c clip? One more question, should there be clips/washers on the outer axle shafts the hold the shafts out(into the lockouts)? My D35 is in pieces right now so i figure this is the time to do the middle u joint and any mods to save me time in the future. I've bought upper and lower moog greaseable balljoints, moog super strength greaseable ujoints, spindle bearings, spindle seals, axle seals, wheel seals, and spindle nuts for the d35, is there anything else im overlooking? Thanks!
As far as the lockouts go, i believe i have the standard warns, but I will wait to upgrade to the 37780s until i break the current ones (i have a spare set of the regulars).
, ball joints and u-joints are all already installed. I guess I will just cross my fingers and hope for the best. As an update, i have the front differential out and have got the c clip out. I noticed my yoke on the inner-most shaft was all bent up so i'm searching for a used replacement right now. I also noticed the pinch bolt (?) on the driver's side on my differential was broken. Do I need to have a certain oem bolt or can I just run to the hardware store and get something similar for replacement? one more question, Have any of you installed a drain plug in your d35?
Just need to bleed the brakes, try to bleed the slave cylinder, change the fluids, and a little work to the body and i will be ready to rock.
