TheRangerStation.com  SM
Serving Ranger, Bronco II, Explorer & Mazda B-Series Owners Since 1999
Home Resources Tech Library Magazine Video Gallery Truck Gallery Shirts & Decals Parts
Go Back   The Ranger Station Forums > Suspension & Armor > Extreme Suspensions
Extreme Suspensions Non bolt-on suspension swaps. 3 & 4 links, eliptical, and other custom suspensions.
Post New Thread Reply
Thread Tools Display Modes
Old 03-25-2008, 05:17 PM   #1
ignerntkneece
ignerntkneece's Avatar
Year: 1994
Make: ford
Model: ranger
Engine: 4.0
Class: 4x4 Extreme
Used For: play and show
ignerntkneece is on a distinguished road
Default 44s under a ranger? how?
I'm bout to start biulding my 94 ranger and I want to put 44 inch tires or so under it? how much lift and how would i do that? maybe a f-250 lift... i'm not sure help me out? i know i'm gonna put a dana 44 under the front...
ignerntkneece is offline   Reply With Quote
Old 03-25-2008, 05:44 PM   #2
metalmacguyver
Yeah, I built that.
metalmacguyver's Avatar
Year: 1997
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4 Extreme
Used For: Working and Wheeling
metalmacguyver is on a distinguished road
Send a message via AIM to metalmacguyver
Default
I would start by buying a D60 at the bare minimum but you would be better off with 2.5ton Rocks under there.
__________________
Horsepower is how fast you hit a wall. Torque is how far you move a wall.
http://www.therangerstation.com/foru...ad.php?t=21890
1994 F350 7.3L PSD, 5spd, DD/tow rig, 2wd for now...
1997 Excab/4.0/5spd/Manual1354/4.88/locked F/R /35"BFG MTs/WarnXD9000i/6"lift/HYDROBOOST!!/Extended radius arms/Wheeling only.
metalmacguyver is offline   Reply With Quote
Old 03-25-2008, 05:54 PM   #3
KELLY88
Oops
KELLY88's Avatar
Year: 1997, 2005
Make: Ford
Model: Ranger STX, Ranger Edge
Engine: 4.0, 4.0
Class: 4x4, 2WD Street
Used For: Offroader, Daily Driver
KELLY88 is on a distinguished road
Send a message via AIM to KELLY88
Default
Quote:
+1 on the Rockwells.
Plus to clear those tires you can have a shop build you a custom suspension. It definitely won't be cheap but I'm not sure there's a kit on the market to jack a Ranger up that high.
__________________
1997 Ranger STX 4.0L 4X4....... 200,000 miles and counting
4" Superlift w/ Pro Comp shocks, 33" Mud Terrains, 4.56 Gears, Iridium plugs, Warn manual hubs, Flowmaster 40
"I can predict the motions of the cosmos but I can not calculate the madness of the people." - Isaac Newton, 1727
KELLY88 is offline   Reply With Quote
Old 03-25-2008, 05:59 PM   #4
Hahnsb2
Hahnsb2's Avatar
Year: 88-95
Make: Ford-Dodge
Model: BII-Dakota
Engine: 4.0-5.2 Turbo
Class: Real 4WD, 3WD.
Used For: Breaking things-Going fast
Hahnsb2 is on a distinguished road
Send a message via AIM to Hahnsb2
Default
Dana 44 with 44s? Funny joke... You're going to need a retarded amount of lift to clear 44s.
__________________
88 Bronco II, 4.0L, M5OD, 4.56s, Aussie Locked 8.8/D35, 1354M, 34" LTBs
95 Dakota CC, 5.2, 5 Spd, 4x4, Remote Turbo, M1 Intake Manifold, Mopar PCM, HS 1.7 RRs, 50mm TB, 3.55s, 31s, Locked
Hahnsb2 is offline   Reply With Quote
Old 03-25-2008, 11:41 PM   #5
Todd
HCT
Todd's Avatar
Year: 90/91/99/04
Model: BII/Ranger
Engine: 2.9
Class: 4x4 Extreme
Used For: Da bush
Todd is on a distinguished road
Default
Go with a 60, sterling combo or 2.5 tons. And if you need to ask now to fit 44's on a Ranger then pay someone to build you a lift. And this WILL not be cheap.
__________________
Rig: BIITR, BII frame Ranger cab, Wontons, Winches, Transfer cases, Batteries. None steet legal.
D.D/Tow rig: 94 F-150, I-6, 5 speed
Todd is offline   Reply With Quote
Old 03-26-2008, 12:26 AM   #6
Dishtowel
August OTOTM Winner
Dishtowel's Avatar
Year: 1986
Model: Bronco 2
Engine: 5.0
Class: 4x4 DIY
Used For: Playing follow the leader
Dishtowel is on a distinguished road
Default
Quote:
+1
__________________
86' Bronco2, 5.0L, fabbed 6" suspension lift.
I dream of a 609 TTB front with full hydro steering. I'm going to make it happen.
Quote:
Originally Posted by Capt Jay View Post
You might not agree but that's no reason not to listen.
Dishtowel is offline   Reply With Quote
Old 03-26-2008, 01:18 AM   #7
Branger2B
Branger2B's Avatar
Year: 1988/86
Make: ford
Model: Branger (86 cab on 88 B2 frame)
Branger2B is on a distinguished road
Default
ive seen few rangers on 40's.. a few on this site too i believe. how much bigger is a 44''? i think it is doable.. if theres a will theres a way. Hopefuly u know what youre doing when you "build ur lift" (stay away from the 10'' roof truss body lift and the custom Re-Bar /chunk plate "Z" link.. and Remember youre going to need about 5 shocks per corner with tires that big..
heres one of the better examples ive seen of a "wheelinsuspension and 44's on a RBV
Branger2B is offline   Reply With Quote
Old 03-26-2008, 11:36 PM   #8
Toreadorranger
Toreadorranger's Avatar
Year: 2000
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4 Custom
Used For: Crawling
Toreadorranger is on a distinguished road
Send a message via AIM to Toreadorranger
Default
You dont need 5 shocks, you just need correctly valved and setup shocks. And with only a Dana 44 under there that truck is gonna Blow that thing up.
Toreadorranger is offline   Reply With Quote
Old 03-27-2008, 01:08 AM   #9
mhughes165
mhughes165's Avatar
Year: 1987
Make: Ford
Model: Ranger
Engine: 302
Class: 4x4 Extreme
Used For: crawling over jeeps
mhughes165 is on a distinguished road
Send a message via AIM to mhughes165
Default
not truc actually, having owned and built a small block ranger on 44's, the weight of the ranger is a huge advantage to solid axle durability, especially in the mud, i left the eb 44 open in the front, with a set of moly axles and beefier u joints and NEVER had a problem with it, and the 9" can be beefed up aswell to take the abuse......
that ebing said, it would be MUCH cheaper to run 1 tons under it, id run personally a 14blt ff in the back with 4.88's and a detroit with a ford hp 60 up front, get the moly shafts for the 60 and leave it open(will really help save axles) also todo this properly your going to want atleast a 250hp small block, as a under powered motor can cause breakage aswell(getting traction when it should keep spinnin due to lack of power),
now for height wise your goin to want the complete lift kit for a 79 ford, atleast 8" (gives u about 12" on a ranger) and a 3" body lift. your going to have to setup a hydrosteer system if u actually want to turn the truck
you know......this could take forever.....
i think i should just post pictures of my 93 f-150.....you basically NEED everything i have done to it....hold on lemme get some pics
__________________
if ur from jersey, get up on this forum
http://njmudtruckshome.freeforums.org/index.php
Quote:
Originally Posted by TrucksGetDirty View Post
Its like a real fine woman with all the STDs of the world. Sexy to look at, not fun to get into.
Quote:
Originally Posted by Will View Post
We don't discriminate against fags here. You like Kojak, then by gawd get some posters of balding men and wear yourself out. Just don't post pictures.
mhughes165 is offline   Reply With Quote
Old 03-27-2008, 04:52 AM   #10
RWARanger
RWARanger's Avatar
Year: 1993 & 1997
Make: FORD
Model: Ranger
RWARanger is on a distinguished road
Default
you guys and your huge lifts. first off is this truck gonna be driven on the street or just off road only? off road only cut the fenders. no body lift, d60 and d70 6.17 or 7.17 gears with the stock 4.0l, and for suspension coils with radius arms or a custom 4 link. my rig right now has 38's under it and is about the same height as a ranger with a 6" lift and a 3" body lift. cutting fenders and having fw axles helps alot to fit big tires. just my $.02 thats how i'd do it.
RWARanger is offline   Reply With Quote
Old 03-27-2008, 11:29 AM   #11
mhughes165
mhughes165's Avatar
Year: 1987
Make: Ford
Model: Ranger
Engine: 302
Class: 4x4 Extreme
Default
thats just room to flex the 44's, and im just the kind fo guy that likes the appearance of the rangers without the fenders all hacked out
__________________
Old 03-27-2008, 11:55 AM   #12
Branger2B
Branger2B's Avatar
Year: 1988/86
Make: ford
Default
Quote:
it was a joke ..... i fugured the 10 inch roof truss body lift would have gave it away? some people have no sense of humor...
Old 03-27-2008, 02:53 PM   #13
Toreadorranger
Year: 2000
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4 Custom
Used For: Crawling
Default
I skimmed your post, looking back at it now I realize it was a joke.
Old 03-27-2008, 06:32 PM   #14
mhughes165
mhughes165's Avatar
Year: 1987
Make: Ford
Model: Ranger
Engine: 302
Class: 4x4 Extreme
Default
oh....to the original poster....i REALLY hope u have no intentions of driving a ranger on full width axles and 44's on the street.....
__________________
Old 03-27-2008, 06:41 PM   #15
bobbywalter
RBV Technical Advisor
bobbywalter's Avatar
Year: 1988
Make: FORD
Model: RANGERISH SORT OF THING
Engine: BIGGER
Class: 4X4
Used For: EVERTHING
bobbywalter is on a distinguished road
Default
250 hp max with 44's on a d44
swap in 60's with 4 in fullsize springs and some fender trimming will fit 44's with room to play. 40 fill my wells perfect
bobbywalter is offline   Reply With Quote
Reply
Bookmarks
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 1999 - 2010 The Ranger Station - James Oaks Enterprises LLC - All Rights Reserved
'The Ranger Station' and it's logo are Service Marks of The Ranger Station owned by James Oaks Enterprises LLC.
Legal Notice
