Saginaw Pump Fittings
Sampson
15+ Year Member
Milford, Mi
My stock pump on my 99 B3000 4x4 is on its way out. It whines like crazy right now and I want to do the upgrade to the saginaw pump as described in the tech library. But the fitting on my stock pump are M16x1.5 and the saginaw pump is 5/8x18. Is there and adapter I can by to be able to still use my stock hose or can I have a new one made at Napa like the stock one just with the 5/8x18 fitting on the pump side. I really don't want to just put a stock replacement back in.
Thanks Pat
Just buy the the hose for the Saginaw and cut the the end off your stock line, flare it and use a union to put it back together using the Saginaw end.
Sent from my DROID RAZR using Tapatalk 2
