- Dec 12, 2012
Hey guys. I've got a 87 BII 4x4 manual trans, and I have been trying to restore this thing to its former glory. I hate to be the new guy that turns up with problems day one, but im in a spot, and I hoping you guys can help. Sooo....
I swapped in a new motor (still a 2.9), extended the engine bay harness and ran it along the fram so it wouldnt be running through the plenum. That all went well. I pulled the dash and the wiring harness, and that is where the troubles started. As soon as I got the dash back together and the wiring harness in, and pressed the clutch, the horn went off. And now it blows constantly, so I unhooked it until I could find the problem. No cluster lights. I have the rear ABS light on. It turns off when the truck is started and then comes right back on. Lastly the engine starts sputtering and backfiring when it revs higher than 2500, with and without load. Ive set the timing at idle, and its at 8-10 BTDC. My thinking is something didnt get hooked up, or something was hooked up wrong and/or I jerked some wires loose. I used to be an aircraft electrician, before my current military job, but civilian wiring systems and military are waaaaaay different. lol. So I suppose one crisis at a time, can someone ID this wire?
The wire in my hand is the same one in the plug. Wire color are yellow/red,black/white, and what looks to be blue/green.
Sorry for the problem bomb on the first post. Many thanks ahead of time.
