- Mar 3, 2013
So I am new to this forum, i am mostly a Ford diesel guy but i just picked up this 96 4.0 4x4 5 speed for $600, has a few issues but the one that gets me right now is the blinkers.
I replaced the blinker/wiper assembly on the column, the reason being is that the flashers work, the blinkers work only if you haven't fully turned the ignition to where the engine cranks. After you crank over the engine, they will not work.
Is there a sensor on or around the lock cylinder that can be adjusted or cleaned??
Thanks guys
Thanks guys
