- Jun 13, 2011
- South Bend, IN
Last summer I swapped out my stock springs for some 150 springs for some added ground clearance. I then had a pos camber issue. I did a V8 swap and a Pro Comp 4" lift on it. I just installed a drop Pitman arm and bought the fully adjustable camber bushings, #594, to correct the severe neg camber issue, per the tech at Pro Comp. I took them down to the shop to get them installed to at least make it drivable. They couldn't get them out so they had to remove the whole spindle and pop them out that way. They then called me and told me that they were too big in diameter to go in, about 1/16". I called Pro Comp to complain and they said that those are the only ones that they have ever made and used for their lift kits. Has anyone else had this problem. MB the old diameter is rusty and needs to be honed out? Any help would be appreciated...
Do you need to remove the whole spindle to pop these out. I tried to get them out before and couldn't. How do I remove the spindle, if necessary. Tried beating on it but it just wouldn't pop off the ball joint.
