starting my 94 ranger project
2old4this
15+ Year Member
NJ
I plan to lower my 94 ranger with a DJM 3/4 kit. I'd also like to put 235-70 15s on the front & 275-60 15s on the back. Any one see any clearance problems with that combo?
thanks
Pat
You "should" be fine. I ran 255-60-15 up front with a -11mm offset on an 8" rim when I was dropped 2" and had clearence. The rears should be good depending on offset as well. I didn't run into problems in the rear til I went all the way down. I currently have 275_60_15 but with a GEN II Ranger rear(2" shorter then Gen III).
James
