Help lift kit Mazda B2300 1995
Greivinsc
10+ Year Member
Hello friends I want buy a lift kit to Mazda B2300 1995. I need comments and recomendations about the best option I want lift the Mazda 3" or "4 to install 31x10.5 tires.
Grettings from Costa Rica
Hello and welcome to TRS. In case you didn't know, the mazda trucks are the same as the ford truck suspension wise for quite a few years. Yours is one. If you read through the following link, you should be able figure out everything you want to know;
http://www.therangerstation.com/forums/announcement.php?f=21
If you still have questions, feel free to ask again.
Good luck,
Richard
Hi Richard thanks for the info, I'll check it any questions I have asked in the forum.
regards
iirc you can fit 31s by just levelnig out the front. I fit 31s without a lift
As rose said no lift needed for 31s. Get a set of spring spacers off of ebay and stick them on the front.
If you need anything I am right down the road in Panama City give me a shout.
Mazda B2300
Hey guys thanks for the help, then I need a lift kit to install 31x10.5 tires?
regards
just a leveling kit. you can make one yourself by stacking 1.5 inches of washers and welding them together. search washer lift itll give you more info then i ever could
Mazda B2300
Hi Rose thanks for the information.
Grettings
