| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
HCT
Year: 90/91/99/04
Model: BII/Ranger
Engine: 2.9
Class: 4x4 Extreme
Used For: Da bush
Rep Power: 12 ![]() iTrader: (0)
Ok, I know the beams, knuckles/outers, stubs, third minus the ribs and internal difference from the carrier is all 35. The carrier is a 28, but what are the side gears? Are they 23 spline or 27 spline Dana 35 side gears in a 28 carrier?
I was just wondering if the 28/35 hybrid uses a special inner shaft that is all 35 specs but then tapers down to 23 spline for the side gears. If this were the case then the 28/35 inner would be really hard to source and the weak point in my mind would not be the 28’s ring and pinion but the 23 spline shaft ends.
__________________
Rig: BIITR, BII frame Ranger cab, Wontons, Winches, Transfer cases, Batteries. None steet legal. D.D/Tow rig: 94 F-150, 4x4, ZF 5 speed, 300 I6 Trust me, I'm an Engineer |
Tweet
#2 |
Yeah, I built that.
Year: 1997, 1994
Make: Ford
Model: Ranger, F350
Engine: 4.0, 7.3
Class: 4x4 Extreme
Used For: Working and Wheeling
Rep Power: 10 ![]() iTrader: (28)
I like these kind of technical posts. Good info. Sorry I cant help.
__________________
Horsepower is how fast you hit a wall. Torque is how far you move a wall. http://www.therangerstation.com/foru...ad.php?t=21890 1994 F350 7.3L PSD, 5spd, DD/tow rig, 2wd for now... 1997 Excab/4.0/5spd/Manual1354/4.88/locked F/R /35"BFG MTs/WarnXD9000i/6"lift/HYDROBOOST!!/Extended radius arms/Wheeling only. |
Tweet
#3 |
Year: 2003
Make: FORD
Model: Ranger-SuperCab
Engine: 4.0 SOHC
Class: 4x4
Used For: Riding mad max style......
Rep Power: 18 ![]() iTrader: (38)
The Ring and Pinion, carrier etc is all true dana 28. The inner shafts that slide into them are weird part, and I think this is what you're asking. They fit the D-28 guts, and as they exit the housing they taper to match D-35 specs. As for what size the shaft seals are on the housing, not sure, but i know the inner shafts taper out to D35 specs. I'd think this would be hard to source an inner shaft. I hope I never break one of mine. LOL
__________________
Some people are like mushrooms, ya gotta feed em' shit and keep them in the dark. Giddywomp Offroad & Fab
Tweet
#4 |
HCT
Year: 90/91/99/04
Model: BII/Ranger
Engine: 2.9
Class: 4x4 Extreme
Used For: Da bush
Ok so then it is a 35 inner that tapers down to 23 spline.
__________________
Tweet
#5 |
Year: 1985
Make: Ford
Model: BroncoII
Engine: 8 rabid gophers
Class: 4x4
Used For: to GET IT!
Rep Power: 13 ![]() iTrader: (0)
__________________
1985 BII Eddie Bauer 302/C5/1350M/Aussie Locked Explorer 8.8/D35/4"ish of Tuff Country lift/35x12.50x15 MT/R's... Some assembly still required. 1992 Explorer - Sold The Org |
Tweet
#6 |
Year: 2003
Make: FORD
Engine: 4.0 SOHC
Class: 4x4
Like I said, I really hope I don't have to replace one. They seem like they'd be hard to source. Junkyard would be about the only bet. I'll get under there tonight and look at it again and take measurments, just to be sure. This has got me thinking.
__________________
Tweet
#7 |
Year: 2003
Make: FORD
Engine: 4.0 SOHC
Class: 4x4
Yes it tapers like said before, and it uses the bigger d35 U-joints.
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
