Rear Axle ?
2manyfords
15+ Year Member
Brandon Manitoba Canada
I have a chance to pick up a 7.5 rear diff with 4.10 gears from a 98 Mazda B2300.
I want to install into my '88 2wd Ranger. (Make the old POS more fun to drive)
Can I install the axle shafts from the '88 diff in to the '98 diff?
I believe 3rd gen+ axles are a bit wider. B2 7.5 shafts should be the same as gen3+... Why do you want to swap them?
Ok, thanks guys.
I wanted to be able to use the stock rims from the '88.
The newer axles have a larger centre section.
