| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Junior Member
Year: 1986
Make: Ford
Model: Ranger STX
Engine: 2.9L v6
Class: 4x4
Rep Power: 12 ![]() iTrader: (0)
I know how to put clutch fluid in but how do i put fluid into my mannul transmission
I have an 86 ford ranger with a 5 speed Mazda transmission! |
Tweet
#2 |
Year: 1977
Make: Ford
Model: Pinto
Engine: 2300
Class: 4x4
Used For: Mud racing/trails
Rep Power: 15 ![]() iTrader: (1)
There is a fill plug on the side. If it is the stock TK5 (Toyo Kogyo made them for Mazda) it will have two fill plugs, either one will work. They are about halfway up the left (drivers) side of the trans. One in the main housing, one in the extension housing.
What some people do is pull the shifter and pour the fluid in until it come out the fill plug hole. I just use a barrel pump. The Mazda M50D R1 was used in newer Rangers and has only one fill plug in the main housing.
__________________
'84 Ranger, 351c,C6,208,EBsas."DeRanged Mudder" '86 Ranger, 3.0swap,coil rear suspension"Black Frog" |
Tweet
#3 |
Year: 1995
Make: Ford
Model: Ranger
Rep Power: 13 ![]() iTrader: (0)
Go to your local AutoZone and buy a fluid lubricant pump for like $5 bucks.
Allen
__________________
1995 Ranger Extra Cab 2.5 Swap 8.8" w/4.56's and Posi 31" Rubber (Remington Right Now) Thrush Turbo Muffler 4" RC Lift w/6" SJ Coils Overbuilt's better then underbuilt. After a 12 pack of beer and a dare from your best friend. |
Tweet
#5 |
Year: 88-95
Make: Ford-Dodge
Model: BII-Dakota
Engine: 4.0-5.2 Turbo
Class: Real 4WD, 3WD.
Used For: Going where I point it-Going fast
Rep Power: 24 ![]() ![]() ![]() ![]() ![]() iTrader: (1)
I pull the shifter out and dump it in there, no screwing around with a sideways bottle cramped underneath the rig. Are you sure its a mazda tranny? 86 should be a FM145 unless you swapped it.
__________________
88 Bronco II, 4.0L, M5OD, 4.56s, Aussie Locked 8.8/D35, 1354M, 34" LTBs 95 Dakota CC, 5.2, 5 Spd, 2WD,Turbo, Megasquirt, 3.55s, Locked |
Tweet
#8 |
Year: 88-95
Make: Ford-Dodge
Model: BII-Dakota
No, M5ODs use Mercon...
All the other use 80w gear oil.
__________________
Tweet
#9 |
Year: 1990
Make: Ford
Model: Ranger Ext. Cab
Engine: 2.9
Class: 4x4
Rep Power: 11 ![]() iTrader: (0)
I took like 2.5 ft of clear 1/2 inch Pvc tube and slid it from inside down the shifter hole and into the fill hole. nice and clean from in the cab and no trying to squeeze a sideways bottle. Definitely 90w in the trans and diffs in those old trucks..
Tweet
#10 |
Year: 1984
Make: Ford
Model: Bronco ll
Engine: 2.8 duraspark
Class: 4x4
Used For: everything
I've seen alot of posts about what type of fluids to put in manual trannys all witth different answers.
The Chiltons manual states "Use transmission lube SAE 80 in the 4-speed or Mitsubishi 5-speed. The Mazda(Toyo Kogyo) 5-speed transmission uses Mercon automatic transmission fluid. Use of improper fluids could lead to leaks or transmission damage." Here's a link that goes to an on-line Chiltons manual. Login and password is Library. http://search.ebscohost.com/login.aspx?authtype=url,uid What I typed above is under "General information and maintenance-Fluids and lubricants-manual transmissions".
__________________
If it don't fit,force it. If that don't work get a bigger hammer! 84 Bll 2.8L duraspark, rv cam, cowl induction T-K 5, 31x10.5x15 manual T-case and hubs |
Tweet
#11 |
Junior Member
Year: 1989
Make: ford
Model: bronco II
Engine: 2.9
Class: 4x4
Used For: all around good time
they stoped making the tk in 87 and only the 88 and newer mazda trans use atf so 80w gear oil is the way to go. but if you ask I run 40w motor oil in mine and change it every time I change my engine oil got 500,000+ on my tranny
Tweet
#12 |
Year: 1987
Make: Ford
Model: Ranger
Engine: NONE
Class: 2WD
Used For: Working on
Rep Power: 21 ![]() ![]() ![]() ![]() iTrader: (5)
IMO, If in doubt, Smell the old fluid before installing the new to make sure.. Gear oil has a really bad distinctive smell to it.
Pete |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
