Go Back   The Ranger Station Forums > Truck Discussions > General Discussions
Notices
General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here.
Post New Thread Reply
Thread Tools Display Modes
Old 07-05-2012, 04:50 AM   #1
bluebombersfan
Year: 2006
Make: Ford
Model: Ranger Sport
Engine: 3.0
bluebombersfan is on a distinguished road
Default getting a p0456 code, what do i do now?
I looked it up and it says (EVAP emmission control system leak). The question is now what do I do?
Also every time I clear the code it takes about a week of driving for it to go back on. I am assuming this the computer is having r hard time detecting, thus the problem is very minor
bluebombersfan is offline   Reply With Quote
Old 07-05-2012, 06:55 AM   #2
97RangerXLT
97RangerXLT's Avatar
Year: 1997
Make: Ford
Model: Ranger XLT Supercab 4 x 4
Engine: 4.0
Class: 4 x 4
Used For: Daily Driver
97RangerXLT has a reputation beyond repute97RangerXLT has a reputation beyond repute97RangerXLT has a reputation beyond repute97RangerXLT has a reputation beyond repute97RangerXLT has a reputation beyond repute97RangerXLT has a reputation beyond repute97RangerXLT has a reputation beyond repute97RangerXLT has a reputation beyond repute97RangerXLT has a reputation beyond repute97RangerXLT has a reputation beyond repute97RangerXLT has a reputation beyond repute
Send a message via MSN to 97RangerXLT
Default
what do you do? Find the leak
Check all the lines to the charcoal canister, check the filler neck.
AJ
__________________
Quote:
Originally Posted by soylent_green View Post
"If it weren't for physics and law enforcement, I'd be unstoppable!"
Quote:
Originally Posted by robertc1024 View Post
Hey - we all have to help each other. Otherwise, we'd become an S10 forum and we'd all kill ourselves.
http://www.therangerstation.com/foru...ad.php?t=13474
97RangerXLT is online now   Reply With Quote
Old 07-05-2012, 09:48 AM   #3
bluebombersfan
Year: 2006
Make: Ford
Model: Ranger Sport
Engine: 3.0
Default
I suck in this department so I will need some guiding. Basically what your saying is look at all the piping/hosing that connects to the gas tank? This won't be easy for me to find anything I don't think because the leak is very small almost undeductable. I guess I will be looking for any kind of cracks of any sort but it sounds challenging because of the lack of space to really get a good look at everything.
Also how about the senser? could even be the senser going bad too.
Old 07-05-2012, 05:14 PM   #4
Andy D
Year: 94
Make: Ranger
Model: 4x4
Engine: 4.0 OHV
Used For: mini pick up stuff
Andy D will become famous soon enoughAndy D will become famous soon enough
Default
Would a loose gas cap be the problem? If your truck is 10 yrs old or older , I would start at the canister up by the battery on my 94 and work your way back down the right side of the engine bay to the right inside of the frame rail. I had to replace and re-connect vapor hoses on mine. But it never lit up a trouble light or ran better. YMMV
Andy D is offline   Reply With Quote
Old 07-05-2012, 05:47 PM   #5
97RangerXLT
Year: 1997
Make: Ford
Engine: 4.0
Class: 4 x 4
Default
what Andy said. if it were a sensor, you would get a specific code for the sensor in question, as the computer would be able to know if it was working or not.
chances are, it is the fuel filler neck, they are a known issue with this truck. 40 bucks on ebay for a replacement.
AJ
__________________
Old 07-05-2012, 07:55 PM   #6
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: 2.9 High Performance
Class: 4x4
Used For: Elevenses
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
Guys, who knows the definition of P0456? Anyone, anyone? Anyone who thinks you are just going to "find the leak"? No one, ok.
P0456- EVAP control leak dected, very small. Can anyone tell me how small "very small" is?
A hole that measures .020 inches across will set this code. You aren't going to just "go find the hole". That is on top of the fact that you have to open up the purge valve and shut down the vent valve, to pressurize the system for a proper test.
The light is taking a week to come back on is because your driving style is not setting the monitor right away, and then other conditions, temp, fuel level, and amount of time the engine is off, all have to be met before it will detect a leak that small and set the code.
You are probably going to need to consult a shop to find this leak. Unless you have a fog machine. If you have access to a fog machine I can work with that.
Personally, I will put money against it being either the gas cap or the filler neck. Those are more likely to set a P0457- gas cap off/loose, or in layman's terms, "screen door on a submarine sized leak".
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: 12-Volt Sandwich
Quote:
Originally Posted by Raj
What you need is cheat codes, motor skills, and a magic genie who grants wishes to little boys who suck at Mario Kart
Quote:
Originally Posted by John Adams
Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other.
HELP REPEAL OBAMACARE
Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind.
adsm08 is offline   Reply With Quote
Old 07-05-2012, 11:45 PM   #7
bluebombersfan
Year: 2006
Make: Ford
Model: Ranger Sport
Engine: 3.0
Default
dam good answer adsm08, This was exactly what I was thinking, how the heck do I find a pinhole leak, your right I won't, and I kind of had a feeling I wouldn't.
I can already assume that this is not a big milage waster by the sounds of it? Question then is how much will a shop ding me to find this needle in a haystack? Can I just tell them I got the code already or r they going to ding me the darn $80 or so bucks just to grab the code again?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
