| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Non-Ranger Axles All other axles. Ford 9-inch, Dana 44, Dana 60, etc. |
Thread Tools | Display Modes |
#1 |
Premium Member
Year: 97
Make: Ford
Model: Ranger Splash
Engine: 4.0 OHV
Class: JD 5.5" Stage 3
Used For: wife drives it to work
Rep Power: 8 ![]() iTrader: (0)
Has anyone looked into using the newer Jeep Rubicon Dana 44 Axels to do an SAS with? They seem, on paper like they would be decent axels to use for a Ranger SAS swap. I am just wondering if anyone else has looked into them.
Tweet
#2 | |
Motorboater (.Y.)
Year: 1988, 2000
Make: Ford
Model: Bronco II (Eddie Bauer), Explorer
Engine: 2.9L, 4.0L
Class: 4x4, 2WD
Used For: Annoying the old ball and chain.
Rep Power: 48 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (6)
unless you find a damn good deal, they're too expensive for what you're getting.
the only difference between a rubi 44 and a d30 is that the center section and inner axles are larger. from the knuckle out is the same as a d30. what always breaks on a d30? the outer shafts/u-joints. so i'd rather just use a HP D30. parts are available anywhere and i know of 5 off the top of my head that i could have for less than $100
__________________
BUILD THREAD<<<<<<<<<<<<< The Tikki Torch Build Thread 1988 Bronco II 4x4 2.9, FM146, 1350M, Disc 8.8, D30 SAS, 3.73's, 31's (for now) 2000 Explorer 4.0 2WD DD Everything I need to know about Islam, I learned on 9/11. The hardest part about a zombie apocalypse will be pretending I'm not excited. Quote:
Tweet
#3 |
Year: 1985
Make: Ford
Model: Ranger
Engine: 5.0
Class: 4x4
Used For: A weapon of massive consumption.
Rep Power: 51 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
I think they went across the board with them, so in a couple years the prices of them should be coming down as the market floods.
__________________
1985 Ford Ranger Custom, 4x4, PA 3" BL, 5.0 HO wannabe, C5 Transmixer, 31 spline T/L 8.8 w/ disc brakes. Build Thread My Ranger is not old; no one would call her old. She has a bluff bow, lovely lines. She's a fine truck: weatherly, stiff and fast... very fast, if she's well handled. No, she's not old; she's in her prime. |
Tweet
#4 | |
MALL CRAWLER POST WHORE!
Year: 1988
Make: Ford
Model: Bronco II
Engine: 4.0 v6
Class: 4x4
Used For: Taking my Money
Rep Power: 51 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (4)
Quote:
if you can get a d44 front and rear matching combo cheap, go for it... rubi's are locked and 4.10's. they are nice axles for what they are. however most people want like 3 grand.. and for 3 grand you can build a nice 14 bolt/kingpin 60 locked and geared... yeah, not worth the rubi 44's unless you can get them CHEAP. in the future, if they go down pricewise... maybe. until then, not a chance for the going price. |
Tweet
#5 |
Mall-Rated
Year: 1990,1994
Make: Ford
Model: Bronco II, Ranger
Engine: 2.9L, 4.0L
Used For: Crawling over things
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
I'm not sure, but I think he might be asking about the JK axle.
If I recall correctly, these have some sturdy parts like 32 spline shafts (with 30 or 32 spline outers, can't recall), a 1.625" pinion shaft (same as the 8.8"), and are hi-pinion, but have weak housings (makes sense, nearly everyone sells gusset kits for them). The JK axle IIRC is 65" wide however, putting it within half-inch of an F-150 D44, and has a less-common 5x5.0" lug pattern.
__________________
'90 Bronco II XLT 5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s '94 Ranger XLT 6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s |
Tweet
#6 |
Year: 1988
Make: Ford
Model: Ranger XLT
Engine: 396W
Class: 4x4 Extreme
Rep Power: 15 ![]() ![]() iTrader: (2)
They don't take a standard D44 gearset so gearing selection is rather limited and expensive. Sure they are better than standard fare jeep stuff but the tried and true standard D44 would be cheaper and easier to work with in the long run.
Matt
__________________
88 Ranger XLT 4x4, no drivetrain, no frame, nothing....new stroker, frame and drivetrain in the works |
Tweet
#7 |
Premium Member
Year: 97
Make: Ford
Engine: 4.0 OHV
It is in fact the JK axels I am talking about. Looking at what you get for the money they did not seem to bad to me. A buddy can score them at cost for me. putting them right around 1k each. That is complete brake rotor to Rotor. I did not look into gearing options as of yet but have toyed with the idea of grabbing a pair.
Tweet
#8 |
Year: 1988
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: Trail Slut
Rep Power: 19 ![]() ![]() ![]() ![]() iTrader: (1)
The rubicon axle are in there own group as for parts, meaning width and gear sets. IIRC they are 1.5 inches wider per side than any other 44's. The gear sets are known as "thick" meaning they are thicker than a normal 44 which are skinnier than the rubicons. All the rubicon gears should end in "T" or "RUB" and can only be had in 4.11, 4.56, 4.88 and 5.13 they are also factory electric lockers. The tubes are weaker but have outstanding selections for upgradable parts like "C" strengtheners and tube inserts which are put inside the stock tube for more strength. They all 5on 5 bolt pattern.
__________________
HE WHO DIES WITH THE MOST TOYS WINS Last edited by Explorin94; 07-03-2012 at 01:43 PM. |
Tweet
#9 | |
Year: 1985
Make: Ford
Model: Ranger
Engine: 5.0
Class: 4x4
Quote:
A guy has a D60 out of an old Dodge with a free 14b for $500 on craigslist up in Omaha right now.
__________________
Tweet
#11 |
Year: 2005
Make: Ford
Model: Ranger Edge
Engine: 4.0L V6
Class: 4x4
Used For: trails/daily driver
Rep Power: 7 ![]() iTrader: (0)
They are not bad axles if you build them up but for the same money you could just build 1 tons.
__________________
Wheeler '05 Ranger Edge SAS'd, 5.38's, D60/D60U, 38.5" TSL SX's, build thread |
Tweet
#12 |
Year: 1988
Make: Ford
Model: Bronco II
Engine: 4.0 v6
Class: 4x4
yeah, do some skids and c-gussets with RCV's... and you're good. but.... pricey.
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
