How hard would this be? I have read the A4LD to FM145 swap sticky. I just did a manual swap on a '97 Ranger and it wasn't all that hard.
Questions:
1. If I use the M50D-R1 out of a 4.0, will I have to move the transmission crossmember?
2. What wiring colors will be needed to hook up the backup lights to the manual?
3. Is there a CPP (Clutch Pedal Position) switch on the inside of the BII to make the PCM work properly?
4. To use a 4.0 clutch, do I use the 6 or 8 bolt 4.0 flywheel on the 2.9?
I am sure I will have more as it comes around to actually swapping...
Questions:
...is that a good price? or if I pull it myself at the local pull it yard, it is $350 for one....IF they have one...
