| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| 4X4 Suspensions For stock & off-road suspensions using stock & aftermarket parts (IE suspension kits). Forum sponsored by RCI Metalworks |
Thread Tools | Display Modes |
#1 |
Year: 2008
Make: ford
Model: ranger
Engine: 3.0l v6
Class: 2wd off road
Used For: DD and wheelin
Rep Power: 0 ![]() iTrader: (0)
ordered a fabtech spindle kit , and am putting 2 inch blocks and a two inch AAL's
in the rear, thought the AAL would come with U-bolts, apparently you have to get the made , i'm assuming i would give them the measurements of the stock u-bolts plus 4 inches? if anyones had this problem help would be appreciated i wanna put this lift in on friday and i'm gonna be screwed without u-bolts. my trucks an 08 sport but im sure the u bolts would be the same from the 01 edges up? |
Tweet
#2 |
Year: 2002
Make: Ford
Model: Ranger
Engine: 3.0
Class: 2WD Off-Road
Used For: taking up space in my garage
Rep Power: 12 ![]() iTrader: (0)
well the bolts would be the same if the axles are the same... do you have a 8.8 or a 7.5
__________________
2002 Ranger Edge 3.0 5 Speed 3.5 Fabtech Spindles, Skyjacker 6" Lift Leaf Springs 33x12.5x15 BFGoodrich A/T's on 15x8 Rock Crawlers James Duff Traction Bars Explorer OHC 2002 Nissan Sentra SE-R - The Rice Rocket 1993 Nissan Sentra - The Ghetto Sled 1977 Mercedes-Benz 240D - Der Panzerwagen |
Tweet
#4 |
Mall-Rated
Year: 1990,1994
Make: Ford
Model: Bronco II, Ranger
Engine: 2.9L, 4.0L
Used For: Crawling over things
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
Shouldn't matter, all 28 spline Ranger axles have 2.75" tubes. Only Torsen-equipped FX4 8.8s differ from that (31 spline, 3.25" tubes).
You might be able to use stock 4x4 Ranger u-bolts on that with a 2" block.
__________________
'90 Bronco II XLT 5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s '94 Ranger XLT 6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s Last edited by 4x4junkie; 03-11-2008 at 07:00 PM. |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
