- Aug 20, 2009
- Connecticut
- 2.9 V6
- Total Lift
- Stock
- Total Drop
- Stock
- Tire Size
- 235/75/r15
When I swapped 2.9's a few years back I chucked the drivers side manifold off my 87 motor and used the manifold off the 89 with the egr block off. So I've been running it with a bypassed egr, I want to reinstall the egr because I saved most of the parts and it should help my gas mileage a little. My question is I will have to make my own egr tube since mine is broken, and I will need the fitting on the drivers side manifold where the block off plug is now where can I score these parts? None of the salvage yards around here have any rangers with the egr 86-87..Has anyone made there own egr tube and could you share a picture of it, also does the tube get double flared?Thanks
