Serving 1984-1990 Ford Bronco II Owners & Enthusiasts
Home Library Bronco II's For Sale Bronco II Gallery B2C Shirts & Decals The Ranger Station
Go Back   The Ranger Station Forums > Truck Discussions > Bronco II & Explorer Specific
Notices
Bronco II & Explorer Specific Also check out our Bronco II section at the BroncoIICorral
Post New Thread Reply
Thread Tools Display Modes
Old 06-09-2012, 04:40 PM   #1
HVAC_Rat
Year: 1989
Make: Ford
Model: Bronco II
Engine: 2.9
Used For: Everything
HVAC_Rat is on a distinguished road
Send a message via Yahoo to HVAC_Rat
Default Stripped starter bolt
The lower bolt on my starter is stripped and won't tighten, not letting the starter and flywheel make good contact. Can I just get a longer bolt and drive it further into the flange to make it tight again?
HVAC_Rat is offline   Reply With Quote
Old 06-09-2012, 06:48 PM   #2
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: What engine?
Class: 4x4
Used For: Elevenses
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
I'd get a heli-coil kit.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: 12-Volt Sandwich
Quote:
Originally Posted by Mark_88 View Post
Question: "What year is your truck"?
My Answer: "What part"?
Quote:
Originally Posted by John Adams
Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other.
HELP REPEAL OBAMACARE
Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind.
adsm08 is offline   Reply With Quote
Old 06-09-2012, 07:00 PM   #3
--weezl--
June 2011 OTOTM Winner
--weezl--'s Avatar
Year: 2007
Make: Ford
Model: Ranger FX4 Level II
Engine: 4.0
Class: 4x4
Used For: stealing candy from babies, and sometimes driving to work
--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute
Default
better question, is it the bolt, or the hole that's stripped?
hole, as ADSM said, heli coil, if it's the bolt, new bolt...
semi related note, where do you get helicoils? i've heard about them, but never seen them at the parts stores... i've got one bolt that holds the reserve tank on my bike, it's stripped and i've been looking for a solution similar to this
__________________
Quote:
Originally Posted by Insanejughead View Post
Don't worry Weezl, if you're banned I'll petition to have you brought back.
Quote:
Originally Posted by multiranger View Post
I asked my girlfriend to measure it for me.. It's only an inch
check out my build thread
--weezl-- is offline   Reply With Quote
Old 06-09-2012, 07:11 PM   #4
shane96ranger
\----===FoMoCo===----/
shane96ranger's Avatar
Year: 1997 / 1989
Make: Ford
Model: F150 XLT / Mustang GT
Engine: 4.6 Triton / 5.0
Class: 4X4 / Hot Rod
Used For: Everything / The war on imports
shane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond repute
Default
Autozone has them here by another brand. Helicoil is a brand name. I think it's called Fix-a-thread.
Sent while I should be doing something else
__________________
Click to see my 97 F-150 XLT
Click to see my 89 Mustang GT
Quote:
Originally Posted by jammert609@yahoo.com View Post
I am being told by family an friends my truck is a piece of shit
shane96ranger is offline   Reply With Quote
Old 06-11-2012, 05:49 PM   #5
4x4junkie
Mall-Rated
4x4junkie's Avatar
Year: 1990,1994
Make: Ford
Model: Bronco II, Ranger
Engine: 2.9L, 4.0L
Used For: Crawling over things
4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all
Default
Yeah look for a "thread repair kit" (about $25-30). Typically they include a drill bit, special thread tap, and some steel coil repair inserts. You can buy the inserts by themselves too, if needed.
A longer bolt might work if there's enough undamaged thread at the bottom of the hole... However it's probably more likely you'll end up having it strip out again though. You'd be harder-pressed to strip it again once the steel insert is in there.
__________________
'90 Bronco II XLT
5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Old 06-12-2012, 01:48 PM   #6
AllanD
RBV Technical Advisor
Year: 1987... sorta
Make: Ford
Model: Ranger Supercab
Engine: '93 4.0
Class: 4x4
Used For: Roadtrip Warrior
AllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to behold
Default
The proper thread to match the original threads and accept the stock bolt
is 10mm x 1.5
I helicoil the starter bolt holes on every 2.9/4.0 trans case that I don't scrap
__________________
Gun Control - A theory espoused by some monumentally stupid people; who claim to believe, against all logic and common sense, that a violent predator who ignores the laws prohibiting them from robbing, raping, kidnapping, torturing and killing their fellow human beings will obey a law telling them that they cannot own a gun.
AllanD is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
