getting started
acidh3r3t1c
15+ Year Member
Des Moines Iowa
right now im slowly collecting stuff to do my v8 swap on my ranger its an 88 ranger with the 2.9L in it and ive got a 5 speed out of an f250 and a t case out of a bronco which all work together and im just not sure what year of 302 i want and out of what vehicle i just was wonder what my best bet would be for an engine wiring wise and compatibly/clearence wise
what are you looking to do with the truck? Is it already lif\ted? Do you have emissions testing where you're at?
I would highly recommend any 302 out of a mustang that is FI.
wiring is not hard, just get the complete harness when you pull the donor engine :icon_thumby:
i want it to be a fairly good off road truck and its going to get a 3inch body lift before the swap then a suspension lift after the swap depending on the funds and in the dsm iowa i dont have any emissions testing and how good do the engines out of the crown vics and the marquis and the lincoln town cars go for performance and fit
At the least, get a 5.0 from a 94-97 E or F150. Explorer motors are good, as well as the Mountaineer 5.0. Also the 88-up T-Bird/Cougar, Lincoln Mark VII LSC, and the Mustang 5.0's from 87-95. The full size Ford, Merc and Lincoln had a roller 5.0 from 87-91 but it's what Ford called the "Base" 5.0 rated at about 150 hp. It's a good start for a rebuild with aftermarket heads though due to the roller block and hardware, otherwise the cam is the smallest roller and the heads suck.
