Go Back   The Ranger Station Forums > Truck Discussions > General Discussions
Notices
General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here.
Post New Thread Reply
Thread Tools Display Modes
Old 08-27-2007, 01:38 PM   #1
RCC
Junior Member
RCC's Avatar
Year: '85 & '96
Make: Ford
Model: B2 & Rngr
RCC is on a distinguished road
Default get tanked
Hey TRS'ers,
I have a '96 extended cab Ranger and need to get
the gas tank off. Hole in it somewhere.
The blasted thing is about 6' long and front part rests
on a non-removable cross member.
I can't slide it back enough to clear that cross member
without hitting the rear axle.
HOW do I get the tank out short of taking the rear end
loose or cutting the cross member??
RCC
__________________
Lookin' to learn...
RCC is offline   Reply With Quote
Old 08-27-2007, 01:42 PM   #2
ZSK
ZSK's Avatar
Year: 2004
Make: Ford
Model: F-150
Engine: 5.4
Class: 2WD
ZSK is on a distinguished road
Default
I assume that you already have the bed off? Or are you trying to removed it from under the truck?
__________________
Past:
1996 Ext. Cab 2wd XLT 4.0 auto, Flowmaster 40, K&N, Jet Chip, AAL, Rough Country 4" lift with 31's and 4.10's
Present:
2004 F150 Crew cab 5.4 2wd auto
ZSK is offline   Reply With Quote
Old 08-27-2007, 01:44 PM   #3
JohnnyU
"Outlaw"
JohnnyU's Avatar
Year: 1991
Make: Chevrolet
Model: K-3500
Engine: TBI 350
Class: 4x4 Extreme
Used For: Exploration
JohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond reputeJohnnyU has a reputation beyond repute
Default
Remove the straps and drop it out the bottom....
__________________
Trail Rig (1) - 1991 Chevy Silverado - [Build Thread] (SOLD 12/2/2011)
Trail Rig (2) - 2007 Polaris Sportsman 500HO EFI
Tow Rig - 2004 Dodge Ram CTD - [Build Thread]
Earth Resin Offroad
JohnnyU is offline   Reply With Quote
Old 08-27-2007, 02:13 PM   #4
RCC
Junior Member
RCC's Avatar
Year: '85 & '96
Make: Ford
Model: B2 & Rngr
Default
Hey JohnnyU,
Obviously, you ain't never tried this on a '96.
With every line, hose, and strap taken off,
the tank don't drop nowhere!
Just hangs by the front of the tank over that freakin'
cross member.
ZSK, no.
I have not taken the bed off, but I thought about it.
Been underneath and it seems impossible.
Gave that cross member a stern look. It supports
the front of the tank and the drive shaft carrier bearing.
Almost ready to grind the rivets off! IF that thing were
removable, the tank WOULD just drop down.
RCC
__________________
Lookin' to learn...
Old 08-27-2007, 03:55 PM   #5
BOSS302Man
Junior Member
Engine: 4.0 overhead x
BOSS302Man is on a distinguished road
Default
You can't do a search under the old forum, but everybody always says it's easier to take the bed off any Ranger than try to drop the tank. 6 bolts and it's off. It's got to be the best way to replace a sending unit or fuel pump, rather than work under a dirty truck.
BOSS302Man is offline   Reply With Quote
Old 08-27-2007, 08:09 PM   #6
RCC
Junior Member
RCC's Avatar
Year: '85 & '96
Make: Ford
Model: B2 & Rngr
Default
BOSS302Man,
Yep, I came to that conclusion after looking
at all the other alternatives. Still a pisser
that Ford had to rivet that mid cross member
in place. If it just unbolted, the tank would fall
right out from underneath.
So, I'm going to start pulling the bed tomorrow.
Got to get this tank out. See if I can repair it.
Anybody ever made a permanent repair on
one of these polyethylene tanks?
Otherwise, I'll be looking for a replacement.
__________________
Lookin' to learn...
Old 08-27-2007, 08:19 PM   #7
Shoeboy
Shoeboy's Avatar
Year: 2001
Make: Chrysler
Model: PT "Loser" Cruiser
Engine: 2.4L
Class: FWD
Shoeboy is on a distinguished road
Default
When pulling the bed, remeber about the 3 bolts (7mm if I remember right) from the fuel filler neck, and to unclip the tail light harness (clip should be above the licence plate, or between the licence plate and left (driver) side tail light. or remove the lenses and feed the wires down.). The bed bolts are a T-55 torques and you may need to get a breaker bar (long arm, strong arm, L handle, ect) on it, and if one brakes (like in my case) the bolts, are quite pricy, and are a Ford Only item (I paid about $12 for 1 bolt, and about $15 for one of the "nuts", thats when I ran it through the shop account, I love that part about working in a garage, thats CDN funds as well). Ya, when I was doing my box swap, I forgot about the tail light wiring, and ripped my apart, so I used the one out of the doner truck, luckly, it worked.
Shoeboy is offline   Reply With Quote
Old 08-27-2007, 08:49 PM   #8
wahlstrom1
J-man HD Mech
wahlstrom1's Avatar
wahlstrom1 is a jewel in the roughwahlstrom1 is a jewel in the roughwahlstrom1 is a jewel in the roughwahlstrom1 is a jewel in the rough
Default
I pulled the straps, bent the guard out of the way and pulled the rear driveshaft and it came out.....oh damn, wait....I removed the crossmember when I did my one piece driveshaft swap...goodluck, lol.
-andrew
__________________
UNDER RE-CONSTRUCTION
97' U.A. Ranger, Bent and Broke...
Quote:
Originally Posted by Kyle M. View Post
LOL, wheres the loony bin, cuz we be crazay
wahlstrom1 is offline   Reply With Quote
Old 08-27-2007, 09:19 PM   #9
RCC
Junior Member
RCC's Avatar
Year: '85 & '96
Make: Ford
Model: B2 & Rngr
Default
Hey wahlstrom1,
Said you "removed" that cross member and went
to a one piece drive shaft. Did you put it back in?
I ain't changing my shaft, so I have to retain the
carrier bearing. Wondering if there would be any
problems later if grind the rivets off, take the cross
member out and bolt it back in when I'm done.
Don't have the T55 Torx socket for bed removal and
the thought of breaking one of those "pricey" bolts
doesn't encourage me much. What I do have is a side
grinder, cutting/grinding discs, and a bunch of grade 8
nuts& bolts.
What to do, what to do....remove bed or cross member?
__________________
Lookin' to learn...
Old 08-27-2007, 11:12 PM   #10
brendank
It's only money...
brendank's Avatar
Year: 1993
Make: Ford
Model: Ranger
brendank is on a distinguished road
Default
Why make more work then you have to by removing the bed? Just grind off the rivets and then bolt the crossmember back on. There's nothing wrong with doing that. I switched to a one piece a few years ago and I've been running with no crossmember ever since.
__________________
Blue 93 Ranger 4.0L 4x4 5spd, 38.5's on 16x10's
EB coils, 6" Skyjacker Leafs, Belltech 6400's, Bilstein 5150's
Fullwidth D60, Lockright, 5.38's, Dedenbear C's
14BFF, 5.38's, Detroit, Disc Braked
3" B/L, Dual batteries, 9500lb winch, Bushwacker cutouts
brendank is online now   Reply With Quote
Old 08-27-2007, 11:22 PM   #11
High Desert Ranger
High Desert Ranger's Avatar
Year: 1987
Make: Ford
Model: Ranger
High Desert Ranger is on a distinguished road
Default
Try jacking the truck up in the back by the frame and let the rear end drop down.
Then maybe you can slide the gas tank back and let the front fall.
High Desert Ranger is offline   Reply With Quote
Old 08-27-2007, 11:33 PM   #12
Jeepman401
Junior Member
Jeepman401's Avatar
Jeepman401 is on a distinguished road
Default
Quote:
Its much easier to pull the bed.
Do it all the time at work
__________________
1992 ranger 4.0 4wd- in surgery
1999 jeep cherokee sport- the new daily driver
Jeepman401 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
