93 Ranger A/C Drain
RadDadsRanger
10+ Year Member
I got my A/C fixed and recharged and it works great (93 XLT, 3.0 5 spd)! Next problem, it drains all over the carpet. For the life of me, I don't see a drain tube anywhere. I'm sure there's a drain that's plugged somewhere on the truck, but where the heck is it? Help!! :temper:
It's under the evap box, coming out of the firewall.
It's next to impossible to see on a vehicle on the ground with the wheel wells installed. You can peel the passenger side wheel well back with a couple of screws removed, and look at it through there.
It might be easier to see on a lift.
Thanks, MAKG. I never did SEE the drain, but I could feel it, so I took the garden hose and sprayed some water into the drain, and it unclogged whatever was clogging it. The A/c drains fine, and works like a champ. Thanks for the info!
