Go Back   The Ranger Station Forums > Suspension & Armor > Fabrication
Notices
Fabrication Bumpers, sliders, cages, flatbeds, tube work, etc. Forum sponsored by Ruff Stuff Specialties
Post New Thread Reply
Thread Tools Display Modes
Old 05-13-2012, 09:23 PM   #1
lil_Blue_Ford
lil_Blue_Ford's Avatar
Year: 95
Make: Ford
Model: F-150
Engine: 4.9L
Class: 4x4
Used For: Work
lil_Blue_Ford is a splendid one to beholdlil_Blue_Ford is a splendid one to beholdlil_Blue_Ford is a splendid one to beholdlil_Blue_Ford is a splendid one to beholdlil_Blue_Ford is a splendid one to beholdlil_Blue_Ford is a splendid one to beholdlil_Blue_Ford is a splendid one to behold
Send a message via AIM to lil_Blue_Ford
Default Cage questions....
So I'm getting ready to put a cage in my choptop (finally). Gonna pull the windshield since it's broken and I'm inclined to go with a pre-fab cage from Jegs (Ranger cage, 10 point) as something to start with and I'll add whatever I need to make it suit my purposes. I figure for what it costs compared to what the cost of steel is locally, it's a good deal.
That said, I have some questions about making it all work the way I want it to.
The tube they use for the cage is 1 5/8 round .134 wall mild steel. I priced some out locally since I want to do an inverted V behind the front seats so it's easier to crawl into the back as well as doing a full cage in the back (like the Jeep family bar type), only thing is, locally that tube goes for $5.66 a foot and if I would get four sticks, that's nearly $500 bucks. So I thought about trying to see if I can find something a little more reasonably priced, but I'm not sure if I should stick with the same diameter or if it will cause any problems to go slightly bigger/smaller, etc.
Also, the Jegs cage uses a Halo bar setup. Looking at where the front supports will come down, I can see that they will probably be pretty close to the dash. I don't really want to go through the headache of swapping out my dash now, but at some future point, it's probably going to get swapped out. I saw that a couple companies make a sort of cage joint that bolts together, so what I'm asking is if ya'll think it would be safe to use one of those joints up near the roof so that I can remove the front support bars at some future point for ease of replacing the dash. THESE are what I'm talking about.
Finally, (for now) comes the floor plates. Jegs includes some 1/8" thick plates with the cage and the instructions say to weld the plates to the floor. Eventually I'll probably make braces that go from the plates to the frame. Should I be using say a 1/4" thick plate? Should I just bolt it to the floor for now until I fab up the frame braces instead of welding?
__________________
"lil Blue" 2000 Ranger Supercab xlt: 3.0L, 5-spd, 2wd
"S**tbrick" 1988 Bronco II Eddie Bauer: 4.0L, auto, 4x4
1989 Bronco II choptop: 2.9L, 5-spd, 4x4, 7" lift, locked f/r, 33's
"Phoenix" 1986 Bronco II xl: 2.9L, auto, 4x4 (future trail toy)
1989 Ranger parts donor: 4cyl, manual trans, 4x4
Quote:
Originally Posted by JohnnyO View Post
Some people are too stupid to be in management. That's why they keep getting promoted.
lil_Blue_Ford is offline   Reply With Quote
Old 05-13-2012, 09:42 PM   #2
3.0ranger1227
3.0ranger1227's Avatar
Year: 2003
Make: Ford
Model: Ranger Edge
Engine: 3.0L
Class: 2WD Off-Road
Used For: DD, playing in the sand
3.0ranger1227 will become famous soon enough3.0ranger1227 will become famous soon enough
Default
Yes the tube clamp is safe. good luck getting it all back together once you drive it a few times and then take it off though. DO NOT bolt the cage to the floor. you want the cage to pass through the floor and go straight to frame. yes you can bolt plates to the floor and have them welded to the tube, but you want the tube as unbroken as possible to the frame.
__________________
2003 Edge 2WD 3.0, Camburg Performance 6.0 dual shock, SSBC rear disc brakes
Red Stepside
4.3L on the way!
3.0ranger1227 is offline   Reply With Quote
Old 05-13-2012, 11:56 PM   #3
alwaysFlOoReD
Super Moderator
Year: '91, '85, '97
Make: ford
Model: ranger, b-II, f-150
Engine: 4.0,4.0,4.2
Class: 4x4 race, 4x4, 2wd work
Used For: 4x4 race, 4x4,2wd work
alwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to behold
Default
I've done a fair amount of research on cages and for your own piece of mind, so should you if you plan on building and/or installing your own.
I've seen both good and bad reports on the tube clamp.
From what I could find on Jeg's web site, there is the main cage hoop,with another hoop attached to the top of the main hoop running at the top of the cab roof perimeter from drivers side to passenger side. At the front of the cab roof hoop there are two down tubes that are the ones that might interfere with the dash. It looks to me that you could temporarily leave off the two down tubes and the cab roof hoop until you have changed out your dash.
Welding a plate to the cab/body is a legitimate way of attaching a cage to a vehicle....how do you think a cage is attached to a uni-body? Though I agree that a unbroken cage to the frame is "probably" strongest...probably be cause I'm not an engineer.
Unless you solid mount the cab, you need to have some form of movement in the cage to frame mount to match the movement of the cab to frame. I've seen an example of such with a cage welded to a plate bolted through the floor, another plate of a different size bolted to the underside, making a sandwich- plate,cab,plate. Welded to the bottom plate is cage-tube with a "rubber" mount similar in design to leaf-spring mountings, and a final tube welded to a plate welded to the frame.
Good luck,
Richard
__________________
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
alwaysFlOoReD is offline   Reply With Quote
Old 05-14-2012, 12:34 AM   #4
Bennybooster
Bennybooster's Avatar
Year: 1996
Make: Ford
Model: Ranger
Engine: 3.0
Class: 4x4 offroad
Used For: Driving over stuff
Bennybooster is a splendid one to beholdBennybooster is a splendid one to beholdBennybooster is a splendid one to beholdBennybooster is a splendid one to beholdBennybooster is a splendid one to beholdBennybooster is a splendid one to behold
Default
Check out my build for some ideas, if you have some more questions feel free to pm me
__________________
Built not bought
1 Ton, Caged Ranger build
Bennybooster is offline   Reply With Quote
Old 05-14-2012, 07:21 PM   #5
4x4junkie
Mall-Rated
4x4junkie's Avatar
Year: 1990,1994
Make: Ford
Model: Bronco II, Ranger
Engine: 2.9L, 4.0L
Used For: Crawling over things
4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all
Default
Quote:
Good luck,
Richard
This is something I've seen overlooked once. The result was the cage literally ripping the floor apart around the plates because it couldn't move with the cab.
Mounting to the floor by itself is fine if the load is spread out a ways using large foot plates.
I used 3/16" thick plates on mine and 1/8" plates underneath to sandwich it. They are approximately 6-8" or so in size (I think the rearmost plates ended up being 4x8" or something due to space limitations, however they are also sitting right on top of the thick rear body mount crossbeam).
As for tubing size, 1-3/4", 1-1/2", and 1-5/8" O.D (in that order) with a .120" wall thickness appear to be the most popular sizes for cage building. 1-1/2" DOM should be fine for your supports if you can get it significantly cheaper than 1-5/8".
__________________
'90 Bronco II XLT
5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Old 05-14-2012, 07:29 PM   #6
alwaysFlOoReD
Super Moderator
Year: '91, '85, '97
Make: ford
Engine: 4.0,4.0,4.2
Default
Edit; the two plates should be different sizes not in thickness but perimeter IE 4x6 on top 5x7 on bottom. IIRC square inches @~ 30"
Richard
__________________
Old 05-15-2012, 09:03 AM   #7
lil_Blue_Ford
Year: 95
Make: Ford
Model: F-150
Engine: 4.9L
Class: 4x4
Used For: Work
Default
Yea, I don't want to solid-mount the cab, and what you're talking about, alwaysfloored, is exactly what I had in mind - using a piece of tube with a leaf-spring type bushing at the frame. I want to keep things sturdy, but I'm also trying to keep in mind that this truck will see both street and trail use. I don't intend on beating it off-road (I'm building something else for that duty), but more milder stuff with minimal risk to body panels, lol. I put new poly body mounts in it two or three years ago now.
As far as changing out the dash goes, I'm really itching to get the truck on the road and I don't really have a whole lot of time to work on it right now, so I'd rather leave the dash for some other time (provided you don't have to pull the windshield to pull the dash). Right now my windshield is broken, so I figured it would be an excellent time to install the cage and get it properly welded up, unless I break another windshield, this is the time where I'll have the most access to welding things up.
I'll have to look into some other steel prices then, thanks for the input.
__________________
Old 06-24-2012, 02:23 PM   #8
AZFX4
AZFX4's Avatar
Year: 1990
Make: FORD
Model: Bronco II
Engine: 2.9
Class: 4x4
Used For: Off Road
AZFX4 is on a distinguished road
Default
So did you go with the jegster cage?
AZFX4 is offline   Reply With Quote
Old 07-02-2012, 09:37 PM   #9
lil_Blue_Ford
Year: 95
Make: Ford
Model: F-150
Engine: 4.9L
Class: 4x4
Used For: Work
Default
Quote:
I had the money. I had the day planned. Then I called Jegs the day before to make sure they had the cage in stock (their website showed that it would ship out the next business day) and found that they really didn't have it in stock, they'd have to bend one up in their fab shop, which they said they wanted a week's notice. So I scrapped my plans and said I'd get back to them.
Then I needed some of the money to pay a bill.
Then I got enough money saved up again and had to buy some more parts that I didn't expect to have to buy....
Now come Friday I should have enough again. So at this point I'm planning on calling in later this week and picking it up early next week. Cross your fingers, I'm getting tired of delaying this project, lol.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
