- Aug 17, 2011
- Austin, TX
- Automatic
First off, Hello! I've been lurking for quite some time reading as many tech articles and other posts before I make a fool of myself. Secondly, I should be purchasing a 93 3.0L 2WD Ranger from my climbing buddy next week. It's got 174,000 and she wants $1000 for it. Body is in fantastic shape and it seems to be in great running condition.
My goal would be to put 31-33s on it using 15in rims and give it a functional and nice looking lift of anywhere from 3-5inches.
Anyways, after using the search function, it is my understanding that:
I can lift the rear with Explorer leafs and a 4x4 block for about 4" of lift (depending on the sag of the springs). If I wanted to add another 1" I could extend the rear shackles by 2" via Belltech 6400 or extending the stock shackle.
As for the front setup, since it's TIB (correct?), I could add a 2" spacer underneath the coil springs on each side and also add in taller coils for more lift.
Assuming that my information is correct:
1. On the rear, would using an extended shackle be a smoother ride than using an add-a-leaf?
2. For the front, if I added a taller coil and a spacer, would I need a frame drop down bracket for each of the I-Beams to correct the camber?
3. For the front, I assume I will I need taller shocks?
------If Yes for Question 3, Should I do the F250 shock tower swap for standard-style shocks or should I just find taller stud shocks?
Sorry for the assault of questions!
