Go Back   The Ranger Station Forums > Styling & Electrical > Interior
Notices
Interior Seats, carpet, consoles and interior panels. Speaker/sub enclosures go in the Audio & Video forum. Forum sponsored by Aqua Graphix
Post New Thread Reply
Thread Tools Display Modes
Old 04-25-2012, 05:57 PM   #1
scrapper
Year: 1994
Make: ford
Model: ranger
Engine: 2.3, 3.73 with 235/75/15
Class: 2WD, 3" body lift
Used For: daily driver, towing trailer
scrapper is on a distinguished road
Default what dashes will fit my 94
I was looking at dashes and noticed that some 91's had the same looking dash as mine, was looking for a 92-94 explorer one, but, am ready to try a ranger one. I was thinking cutoff was 92-94 on rangers, for a 94 ranger. Will a 91 fit and have the correct wiring, not like a 88 or something older. I know it will actually fit but was wanting to hook up cruise and a/c in my truck. Thanks for any help.OH, did 91 rangers have bucket seats and a center console? I was thinking someone put all that stuff in there, no air under the hood, blower wasn't set up with a place for an evaperator, no condinser,no a/c pump. looked nice but someone smashed it already so will still have to keep checking the junk yards.
scrapper is offline   Reply With Quote
Old 04-28-2012, 09:25 PM   #2
nitrofan1
Man without a Ranger
nitrofan1's Avatar
Year: 2000
Make: Subaru
Model: Forester
Engine: EJ251
Class: AWD
Used For: Everything and then some
nitrofan1 is a jewel in the roughnitrofan1 is a jewel in the roughnitrofan1 is a jewel in the rough
Default
89 thru 94 are clones. This gives ya a lot of options!
__________________
No matter where you go, there you are
nitrofan1 is offline   Reply With Quote
Old 04-29-2012, 06:43 PM   #3
scrapper
Year: 1994
Make: ford
Model: ranger
Default
Will a 91 2.3 be wired the same as a 94 with a 2.3? I ask because wiring is really hard for me, I'm color blind but can make out different colors just almost impossible with dirty small strips of color.
Old 04-29-2012, 07:04 PM   #4
snoranger
Boost Junkie
Tetris Champion
snoranger's Avatar
Year: 94,94,95,01
Make: All 10 are Ford
Model: Ex, Cobra, Ex, Ranger
Engine: 4.0,5.0,4BT,4.0
Class: none
Used For: Going places.
snoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond repute
Default
Do you need a new harness, or just the dash?
The harness unbolts off the back of the dash and can be swapped in 10 minutes when the dash is out.
__________________
'95 Explorer -- EEC-IV SOHC swap. Now getting a "moderately built" 4BT Cummins, ZF, 4406, US Gear OD unit, 13" Cobra brakes, '99 Cobra wheels,....
4BT swap thread
Ranger bed trailer build
Scars are just tattoos... with better stories!
snoranger is offline   Reply With Quote
Old 05-01-2012, 07:02 PM   #5
scrapper
Year: 1994
Make: ford
Model: ranger
Default
I was wanting to install a/c so from what I understand you need the dash with the vent doors set up for a/c. My dash is cracked though, so if I can find one that is better then I will. I found one at the junk yard but didnt get it because it was a 91 and I wasnt sure it would work. I hope it is still there. I am going to try to get it this saturday.
Old 05-14-2012, 08:27 PM   #6
AllanD
RBV Technical Advisor
Year: 1987... sorta
Make: Ford
Model: Ranger Supercab
Engine: '93 4.0
Class: 4x4
Used For: Roadtrip Warrior
AllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to behold
Default
There is NO reason to change out the dash to retrofit factory air.
The only parts you need to swap out is the HVAC control panel and the length of wire from it to the switches under the hood and A/C relay in the fusebox.
You MAY (but I'm not sure) need to change out the interior side of the firewall HVAC box, but this is NOT "The Dashboard"
The reason you may need to chage it is because the vacuum controlled vent doors may operate differently
What needs to be changed is the ENGINE side "Firewall box" and that is only held into the truck with FOUR nuts.
Three of those nuts are in the engine compartment the fourth is on the interior side of the firewall near the fuel inertia cutoff switch.
MY truck was not factlry air, but it is now, but I had it "Easy" as all my control doors are operated by push-pull cables...
AD
__________________
Gun Control - A theory espoused by some monumentally stupid people; who claim to believe, against all logic and common sense, that a violent predator who ignores the laws prohibiting them from robbing, raping, kidnapping, torturing and killing their fellow human beings will obey a law telling them that they cannot own a gun.
AllanD is offline   Reply With Quote
Old 06-04-2012, 09:05 PM   #7
scrapper
Year: 1994
Make: ford
Model: ranger
Default
ok, I am willing to try. I am thinking the only thing in the engine compartment is the blower , I changed mine to the one that has the evaporator . I may have to look to see if there is something else??? I am guessing the wire goes from the switch, then to the a/c relay. I am wondering if there is a clutch wire hiding in my wiring harness? I put the a/c blower control in also. Thanks for the info.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
