Serving 1984-1990 Ford Bronco II Owners & Enthusiasts
Home Library Bronco II's For Sale Bronco II Gallery B2C Shirts & Decals The Ranger Station
Go Back   The Ranger Station Forums > Truck Discussions > Bronco II & Explorer Specific
Notices
Bronco II & Explorer Specific Also check out our Bronco II section at the BroncoIICorral
Post New Thread Reply
Thread Tools Display Modes
Old 04-15-2012, 01:30 PM   #1
jkufen
Year: 1986
Make: Ford
Model: Bronco II
Engine: 2.9
Class: 4x4
Used For: Daily driver now but eventually be a trail rider
jkufen is on a distinguished road
Default which speaker wire is + and which is - in dash?
My 86 I am trying to correct the previous owners crappy stereo system and the kid that did it didn't have any idea what he was doing. Now I have never do door or dash speakers so I'm trying to learn as I go. On my 86 the driver side has two wires a white and an orange one that went to the factory speakers. On the passenger side there's a white and black wire that went to the speaker. Now before I blow my new speakers using trial and error I was hoping someone here could help. On my new speakers there is a + and - where the wires go. I tried to figure out which was + and - with a volt meter but they both have a current so that idea was shot down. Any idea which is which. I can't determine since both sides have a white that that one is power or since they both have white its the ground. I haven't done any kind of sound system in probably 5-6 years so I'm a little rusty.
jkufen is offline   Reply With Quote
Old 04-15-2012, 08:47 PM   #2
jkufen
Year: 1986
Make: Ford
Model: Bronco II
Engine: 2.9
Class: 4x4
Default
Well after reading this wiring diagram I got from lmc for the last 7 hours I have finally traced out all the wires and for anyone else that may do this the front left (+) is the orange/green wire the front left (-) is the black/ white wire. The front right (+) is the white/green wire and the front right (-) is the black/white wire. I still got to trace the back speakers out but that will be a headache for another day. The guide they sent me didn't specify the colors of each wire so that was the fun part.
Old 04-15-2012, 08:55 PM   #3
hende
Junior Member
hende's Avatar
Year: 1985
Make: FORD
Model: Bronco II
Engine: 2.8
Class: 4x4
hende is on a distinguished road
Default
Been looking in my haynes and cant find it try google bet it pops up
hende is offline   Reply With Quote
Old 04-18-2012, 10:45 AM   #4
PetesPonies
Year: 1984
Make: Bronco II
Model: V8
Used For: fun
PetesPonies will become famous soon enough
Default
Couple basic things here to learn.
First, if you have a black and white wire going to both speakers, that is obviously your negative wire. On most speaker systems, negative is common .
Secondly, if even in doubt, hook it up. You will not blow the speaker if it is backwards. What will happen is the cone will move in rather than out, noticeable on a bass note. So by watching the speaker, you can tell if it is connected correctly.
If you don't know which is positive and negative on the speaker, hook up a 9V battery to the speaker. Again watch which way it moves ( the cone ) and you can determine which connection is positive and which is negative.
__________________
Pete's Ponies
Mustang RUSToration & Performance
PetesPonies is offline   Reply With Quote
Old 04-18-2012, 11:37 AM   #5
Shran
Shran's Avatar
Shran will become famous soon enough
Default
You can always get out the multimeter too... connect it to both speaker wires, if it reads a negative number, your negative lead on the multimeter is connected to the positive speaker wire
__________________
1986 Ranger XL 4x4, 302, NP435/205, HP D44, RCV shafts, 8.8 Lock-rite/lsd, 4.10 gears, 35" BFG M/T --- Build Thread
1996 Ranger XLT 4x2, 2.3, M5OD
1986 F150 4x2 302/T18
1985 F250 4x4 460/T19
Shran is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
