Go Back   The Ranger Station Forums > Truck Discussions > General Discussions
Notices
General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here.
Post New Thread Reply
Thread Tools Display Modes
Old 04-10-2012, 05:08 PM   #1
86ranger4x4owner
86ranger4x4owner's Avatar
Year: 1986,1988
Make: Ford
Model: xlt ranger,
Engine: 2.3l,2.9l
Class: 4x4
Used For: Shcool, Hunting, Playing around
86ranger4x4owner is on a distinguished road
Default gas tank
I have a 88 xlt ranger super cab and a short bed with the 2.9l auto. I was wondering how many gallons is the gas tank? Also when i do fill it up the fuel nozxle at the gas station doesnt cut off but i can see gas at the top of the gas neck.
__________________
'88 ranger ext. cab 4x4 2.9 3" inch bl 31'' bfg km2 mud-terrains. l/s 7.5'' rear with 4.10
1986 ranger reg. cab 2.3l 5 speed 4x4 stock
86ranger4x4owner is offline   Reply With Quote
Old 04-10-2012, 05:29 PM   #2
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: 2.9 High Performance
Class: 4x4
Used For: Elevenses
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
Sounds like the flapper isnt closing right. The fill capacity should be 14.5 gallons, give or take.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: 12-Volt Sandwich
Quote:
Originally Posted by Raj
What you need is cheat codes, motor skills, and a magic genie who grants wishes to little boys who suck at Mario Kart
Quote:
Originally Posted by John Adams
Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other.
HELP REPEAL OBAMACARE
Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind.
adsm08 is offline   Reply With Quote
Old 04-10-2012, 06:11 PM   #3
86ranger4x4owner
Year: 1986,1988
Make: Ford
Model: xlt ranger,
Engine: 2.3l,2.9l
Class: 4x4
Default
Quote:
The flapper closes right but i filled it up with 10 gallons and it was close to empty gas only comes out when you pump it cause it doesnt stop pumping when its full.
__________________
Old 04-10-2012, 06:16 PM   #4
clvanhorn
clvanhorn's Avatar
Year: 1988
Make: Ford
Model: Ranger
Engine: 2.9
Class: 4x4
Used For: dd and my workhorse
clvanhorn has a spectacular aura aboutclvanhorn has a spectacular aura aboutclvanhorn has a spectacular aura about
Default
i've never been able to get more than 9.9 gallons in my 88...
clvanhorn is offline   Reply With Quote
Old 04-10-2012, 06:33 PM   #5
86ranger4x4owner
Year: 1986,1988
Make: Ford
Model: xlt ranger,
Engine: 2.3l,2.9l
Class: 4x4
Default
Quote:
When you fill yours up does the pump turn off automatically?
__________________
Old 04-10-2012, 06:37 PM   #6
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Class: 4x4
Used For: Elevenses
Default
Have you ever run it dry?
A 10 gallon tank is ridiculously small for a vehicle of any size.
__________________
Old 04-10-2012, 06:44 PM   #7
clvanhorn
clvanhorn's Avatar
Year: 1988
Make: Ford
Model: Ranger
Engine: 2.9
Class: 4x4
Default
no, i'm scared to because i bought the ranger so i don't have to walk. the time it fit 9.9 the needle was past E, and i topped it off. so yeah, the gauge could be inaccurate, but i'll just pretend its good for now
and yeah, i agree, neon's have 10 gallon tanks for christ sake. something that small doesn't belong in those let alone a ranger
Old 04-10-2012, 06:46 PM   #8
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Class: 4x4
Used For: Elevenses
Default
Yeah, your gauge is busted. I go 200 miles on a tank in my truck and take on between 12 and 14 gallons depending on the time of year, how I was driving, and such and I have basically the same truck.
__________________
Old 04-10-2012, 07:02 PM   #9
86ranger4x4owner
Year: 1986,1988
Make: Ford
Model: xlt ranger,
Engine: 2.3l,2.9l
Class: 4x4
Default
Also it has pressure on the tank. When i open up the cap it lets off a good bit of pressure. I found a hose that i thought could be a vacum hose and traced it all the way to the front of the truck to the vapor canister i think that is what it is. But that lined cant be stopped up because it is connected. Is there any other vacum lines? And could i go 200 miles on my truck? It usually says E when at about 150 miles and i get about 15 miles per gallon.
__________________
Old 04-10-2012, 07:33 PM   #10
fyre82
fyre82's Avatar
Year: 1988
Make: Ford
Model: Ranger Custom Ranger Super Cab
Engine: 2.9
Class: 4x4
Used For: everything
fyre82 has a spectacular aura aboutfyre82 has a spectacular aura about
Default
The gauge in both of my '88s are funky.
The single cab doesn't work at all. I go 180-200 miles and go for gas.
The super works sort of. When I tested it outside the tank it read perfectly but not now, 75 miles and it reads 1/4, by 150 it is below E. I used the same rule for both, get to 180-200 miles and go for gas.
Don't trust that one, the oil pressure or temp, they all suk for various reasons.
__________________
The memories of a man in his old age are the deeds of a man in his prime . . .
http://www.cardomain.com/ride/2534007
http://www.cardomain.com/ride/2868105
fyre82 is offline   Reply With Quote
Old 04-10-2012, 07:36 PM   #11
Twisted_Steel
Twisted_Steel's Avatar
Year: 1991
Make: Ford
Model: Ranger XLT
Engine: 302 HO
Class: 2WD Street
Used For: Daily Driver
Twisted_Steel is on a distinguished road
Default
You probably have a split in the float. It slowly fills with gas over time and starts to drop.. had that problem on my ranger.. just take off the bed, pop out the assembly.. and replace the float. I just snagged one from a 78 F150.. was the same thing. pop one float out, pop the other in.. and reassemble
__________________
BTW that is one cute lil turbo.
Twisted_Steel is offline   Reply With Quote
Old 04-10-2012, 07:51 PM   #12
86ranger4x4owner
Year: 1986,1988
Make: Ford
Model: xlt ranger,
Engine: 2.3l,2.9l
Class: 4x4
Default
What would cause it to make the gas pump not stop? It has pressure when i open the cap.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
