Go Back   The Ranger Station Forums > Styling & Electrical > Misc Electrical & Gauges
Notices
Misc Electrical & Gauges Post your speedometer, gauges, interior and non audio/video questions here.
Post New Thread Reply
Thread Tools Display Modes
Old 04-07-2012, 11:24 PM   #1
Snal
Snal's Avatar
Year: 2000
Make: Ford
Model: Ranger
Engine: 2.5L
Class: 2WD Off-Road
Used For: DD & Jumping!
Snal is on a distinguished road
Default Airbags deployed, where to start
wednesday night I was out and hit a rock I didn't see in time with my lower control arm. I'm replacing the arm tomorrow but the shock from the hit set off my airbags and I don't want to go to the dealer to have them drain my bank account so I have a few questions.
  • What do I need?
    I know I'll need both bags, a new crash sensor and a computer reset. Is there anything I'm missing
  • How to reset the computer?
    do the airbags have their own computer that I can just replace
  • Where do I get the parts?
__________________
Camburg 5.5; Expo Springs; 33x12.50 General Grabbers
Snal is offline   Reply With Quote
Old 04-08-2012, 11:11 AM   #2
Hooligan2c
Premium Member
Hooligan2c's Avatar
Year: 2001
Make: Ford
Model: Ranger
Engine: 4.0 SOHC
Class: 4x4
Used For: Leisure, strip club hopper
Hooligan2c will become famous soon enough
Default
Junk yard the airbags, they are quite common. The bags themselves do not have the reset in them, they are just plug ins. You can probably find everything you need in they yard. I myself am not sure on the resetting of the computer though. If you need airbags, I can get them for you so shoot me an email.
__________________
2001 XLT 4" Superlift, 3" PA body lift, 06+ front end conversion 35" BFG's on Mickey Thompson Classic II's...and much much more!!
Click to see My Build
Hooligan2c is offline   Reply With Quote
Old 04-08-2012, 01:50 PM   #3
Sasquatch_Ryda
Coast Mountain Crawlers
Sasquatch_Ryda's Avatar
Year: 1991/1997/2008
Make: Ford
Model: Ranger/Ranger/SuperDuty
Engine: 4.0L/3.0L/6.4L
Class: 4x4
Used For: Play toy/Daily Driver/Grocery Getter
Sasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to behold
Send a message via MSN to Sasquatch_Ryda
Default
Air bag, crash sensor, if the seatbelt pretensioners went off you'll need those (not sure if a 00 ranger has em) and once the RCM (restraints control module) registers a deployment it needs to be replaced.
__________________
http://www.coastmountaincrawlers.com
1991 Ranger - one tons, 3 link, air shocks and 40's
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 4.56 gears, 6" lift, 33" MT's.
2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake
1967 Mustang Coupe - 289, c4, pretty much stock
Sasquatch_Ryda is offline   Reply With Quote
Old 04-08-2012, 02:21 PM   #4
Ranger Kip
Ranger Kip's Avatar
Year: 05,98,01,98,13
Make: Ford,Suzuki,Inf
Model: F150,Ranger,Swift,Q45,Taurus,Elantra
Engine: 4.6,2.3,1.2,4.8,4.0,2.5
Class: DD, Fixing, DD, Fixing
Used For: listed up there
Ranger Kip will become famous soon enoughRanger Kip will become famous soon enough
Send a message via AIM to Ranger Kip Send a message via MSN to Ranger Kip Send a message via Yahoo to Ranger Kip Send a message via Skype™ to Ranger Kip
Default
youd think theyd make these things resuable, well, guess its true, the more simple the better
__________________
Quote:
Originally Posted by 85_Ranger4x4 View Post
a well aimed bird crap would make most of those around here implode.
PROJECTS
84 One Eye'd Beast - Status: Junked
79 Iron Horse - Status: Sold
95 Tan Tortoise - Status: Replacing Brake Lines
Ranger Kip is offline   Reply With Quote
Old 04-08-2012, 05:09 PM   #5
SeanWilson
SeanWilson's Avatar
Year: 1998
Make: Ranger
Model: Gen 4
Engine: 4.0L
Class: 4x4
Used For: to space and back
SeanWilson is on a distinguished road
Default
After a impact or a crash the sensor trips, to reset your trucks computer, which mainly turns your fuel pump back on (turns off so if your engine bay catches fire it wont push more fuel into it)
-there is a little push button switch on the passenger side floor board close to dead center of the glove box just pull the carpet back a little bit (at the top where it disappears up and into the dash) just about at the carpet line there is a little RED button. push that and it will reset your computer.
SeanWilson is offline   Reply With Quote
Old 04-08-2012, 07:14 PM   #6
MrRangerSir
MrRangerSir will become famous soon enough
Default
I don't think so.
All that red button does is reset the motion tripped breaker to the fuel pump. Nothing happens at the computer, much less the airbag module.
MrRangerSir is offline   Reply With Quote
Old 04-08-2012, 09:35 PM   #7
Snal
Snal's Avatar
Year: 2000
Make: Ford
Model: Ranger
Engine: 2.5L
Class: 2WD Off-Road
Default
I plan on getting my passenger airbag and most of the parts from a junkyard I just want to make one trip and get everything at once. My seat belts still latch so I don't think I have the pretensioners. Where is the RCM located? is that the "computer" that needs to be reset?
__________________
Old 04-20-2012, 03:21 PM   #8
Snal
Snal's Avatar
Year: 2000
Make: Ford
Model: Ranger
Engine: 2.5L
Class: 2WD Off-Road
Default
ok so the new bags are in. if this happens to someone with a similar problem here's what I did. my truck is a 2000 and I read that if they look they same then they will work for the drivers airbag and I'm pretty sure all passengers work. I didn't have the seat belt tensioners so I didn't have to replace any of that.
I took out the battery and let it sit for about 30min to and hour with the headlights on to drain all power from the truck. I took out the drivers airbag then passenger and then the RCM. then I replaced both bags and connected the new sensor after both bags were in.
I reconnected the battery and my truck would beep slowly five times and repeat five times then would come back after 45 minutes of driving. The beeping is from a bad bulb in the cluster. I replaced it and I got airbag code 29. from my research airbag codes are supposed to disable the airbag system but this code wasn't listed as on of those. code 29 means that RCM is from another truck and doesn't match your trucks computer. I don't know yet how to get rid of this flashing code or if it disables my airbag system.
My truck is a 2000. my driver airbag is from a 99 and the passenger and RCM are from an 01. aside from the code everything works properly.
__________________
Old 04-22-2012, 12:02 AM   #9
pcollins
Year: 2012
Make: GMC
Model: Sierra 1500
Engine: 4.8L
Class: 4x4
Used For: Around the farm, Daily Driver
pcollins will become famous soon enoughpcollins will become famous soon enough
Default
Make sure that clock spring is in right on the steering wheel or you could be in for a surprise. As for the Code 29 i'm not too sure. 99 and 01 are same generation i think...
__________________
'12 GMC Sierra | 4.8L | Auto | 4wd
pcollins is offline   Reply With Quote
Old 04-22-2012, 12:53 AM   #10
Sasquatch_Ryda
Make: Ford
Class: 4x4
Default
The RCM is a programmable module and needs to be configured to your truck using as built data. Something you need the dealer to do, or someone with a capable scan tool.
__________________
Old 04-22-2012, 09:05 AM   #11
JoshT
Premium Member
JoshT's Avatar
Year: 1999
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Used For: Back-up DD, Hunting, ETC.
JoshT has a spectacular aura aboutJoshT has a spectacular aura about
Send a message via AIM to JoshT Send a message via Yahoo to JoshT
Default
Quote:
What for? He didn't remove the steering wheel, just the airbag from the steering wheel.
__________________
1984 Ranger 2wd - RIP
1986 Ranger 2wd - V8/street truck/rebuild project
1998 Explorer EB V8 - Totaled engine donor for 86
1999 Ranger 4wd - Back-up DD/Hunting truck
2003 Honda Shadow Sabre - For Sale
2010 Kia Forte Koup SX - DD
JoshT is offline   Reply With Quote
Old 05-02-2012, 11:41 PM   #12
Snal
Snal's Avatar
Year: 2000
Make: Ford
Model: Ranger
Engine: 2.5L
Class: 2WD Off-Road
Default
yeah I heard about the clockspring if the connecters for all of the cables are melted than I'd need a new clockspring but everything was fine so I didn't need to. I've yet to visit the dealer about the code but once I get all my other stuff fixed i'll be heading their way
__________________
Reply
Bookmarks
Tags
airbag, computer, crash, replace, sensor
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
