Serving 1984-1990 Ford Bronco II Owners & Enthusiasts
Home Library Bronco II's For Sale Bronco II Gallery B2C Shirts & Decals The Ranger Station
Go Back   The Ranger Station Forums > Truck Discussions > Bronco II & Explorer Specific
Notices
Bronco II & Explorer Specific Also check out our Bronco II section at the BroncoIICorral
Post New Thread Reply
Thread Tools Display Modes
Old 04-04-2012, 06:11 PM   #1
ENixB2
Year: 1986
Make: Ford
Model: Bronco II
Engine: 2.9 V-6
Class: 4x4
ENixB2 is on a distinguished road
Default Bronco Fuel
I have an 86 Bronco II V6 fuel injected and I was wanting to replace the fuel lines but then I heard that fuel injected cars need to have high pressure fuel lines. Ive never heard of high pressure fuel lines so Im not sure if the guy was making stuff up or if I really need high pressure lines and how much it is and where I can get the stuff.
Thanks Erik
ENixB2 is offline   Reply With Quote
Old 04-04-2012, 06:24 PM   #2
martin
Year: 1984 1991
Make: ford
Model: b2 explorer
martin is a jewel in the roughmartin is a jewel in the roughmartin is a jewel in the roughmartin is a jewel in the rough
Default
The regular stuff will work just fine, it's only 65 pounds as an absolute maximum. you get higher pressures in your household plumbing.
martin is offline   Reply With Quote
Old 04-04-2012, 07:29 PM   #3
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: What engine?
Class: 4x4
Used For: Elevenses
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
Quote:
Nix that. You do need FI specific line. You can't use the stuff that you would use on a carbed system. Carbed fuel pressures are about 5 to 15 PSI AFTER the pump. FI systems can produce up to 75 PSI through the whole system.
You don't have to have all hard lines, but I would recommend it if you can find it, but if you go to the parts store there IS a difference between regular fuel lines and injection rated lines. In PA if I see a fuel line that is printed with "Not for FI" on it on an injection system I can fail it for saftey inspection.
The stuff running through your household pipes isn't flamable enough to be used as an automotive fuel.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: 12-Volt Sandwich
Quote:
Originally Posted by Mark_88 View Post
Question: "What year is your truck"?
My Answer: "What part"?
Quote:
Originally Posted by John Adams
Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other.
HELP REPEAL OBAMACARE
Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind.
adsm08 is offline   Reply With Quote
Old 04-04-2012, 09:59 PM   #4
Earl43P
Premium Member
Year: 2000
Make: Ford
Model: Ranger
Engine: 3.0
Class: 4WD
Used For: DD
Earl43P is just really niceEarl43P is just really niceEarl43P is just really niceEarl43P is just really niceEarl43P is just really nice
Default
http://www.oldfuelinjection.com/?p=95
__________________
If at first, you don't succeed, RTFM.
Earl43P is offline   Reply With Quote
Old 04-05-2012, 03:35 PM   #5
Shran
Shran's Avatar
Shran will become famous soon enough
Default
You are OK with low pressure line from the tank to your high pressure pump. From there, you need and should have high pressure line to the fuel rail. The return doesn't matter, and can be either because it just dumps back into the tank and is not pressurized at all.
I would not run low pressure hose after the pump on the frame for safety reasons, ie IF it ruptures you will have a LOT of fuel spraying everywhere, like on your exhaust, engine, and possibly YOU when you get out of a burning truck.
__________________
1986 Ranger XL 4x4, 302, NP435/205, HP D44, RCV shafts, 8.8 Lock-rite/lsd, 4.10 gears, 35" BFG M/T --- Build Thread
1996 Ranger XLT 4x2, 2.3, M5OD
1986 F150 4x2 302/T18
1985 F250 4x4 460/T19
Shran is offline   Reply With Quote
Old 04-05-2012, 10:23 PM   #6
sjr53
Junior Member
Year: 1986
Make: Ford
Model: Bronco II
Engine: 2.9L
Class: 4x4
sjr53 is on a distinguished road
Default
The fuel lines are nylon, so rust is not an issue. I see no reason to replace the lines. I just replaced the tank fuel pump and had damaged connectors from rust on the metal lines coming out of the tank. Dorman makes replacement ends, usually with 18" of attached nylon fuel line and a coupler that requires warming up the nylon to manage to make the splice. Molding the sharp curves in the line is a problem I need to resolve. The pressure line is 3/8" and the return line is 5/16" using hairpin connectors except at the fuel rail where spring locking connectors are used. I couldn't find a fuel filter anywhere on my '86 but have replaced the filter on my '88. My accumulator doesn't want to open up and I'm not going to force it open to look for a filter in there.
sjr53 is online now   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
