Fuel problem
scrappy
10+ Year Member
Ventura, CA
2004 2.3L manual 2wd
  • Check continuity of grounds
  • Replace fuel pump
  • Check operation of inertia switch
  • check fuses
  • check relays
  • check continuity from relay to pump
If all that is good, and I still do not have power to the pump... what is the deal? I have the FSM for this, and seeing something about the Fuel pressure switch. Any ideas or known problems here?
Thanks guys!
Discovered it is a intermitant problem with the inertia switch! :dntknw:
Jumpered it for now, replace tomorrow.
