Go Back   The Ranger Station Forums > Axles, Brakes, Wheels & Tires > Ranger Axles
Notices
Ranger Axles Dana 28, Dana 35, Ford 7.5 & Ford 8.8
Post New Thread Reply
Thread Tools Display Modes
Old 03-21-2012, 08:51 PM   #1
arren
arren's Avatar
Year: 1994
Make: Mazda
Model: B4000
Engine: 4.0
Class: 4x4
Used For: dd, wheelin
arren is on a distinguished road
Default Rear Axle Shaking bad
I have a 94 b4000 4x4. I swapped in a 3L73 8.8 from a mid 90's ranger to upgrade from 3.27's and an open diff. Around the same time, I had replaced the transmission and transfer case as well as swapped in a one-piece driveline. The truck has a 4 inch lift, blocks in the rear. With that new axle in, I have a terrible shake. I won't even call it a vibration because it is so bad. My shifter moves back and forth, it's like driving on a washboard. Since this, I have rebuilt the transfer case, bearing and seal kit, had the driveline balanced, went to 33's and had them balanced. With the rear end on jackstands and running in gear, I can see and feel the driveline wobbling, so I swapped in another driveline only to have the same effect. I can see the passanger side brake drum is bent and can hear it scrape the brake shoe with every turn. The rear wheel bearings have minimal play in them, about the same for each side. I can't see the brake drum having that large of an effect, but it is next on my list as it needs to be replaced regardless. So, any ideas or direction would be greatly appreciated
Thanks in advance,
Arren
__________________
A rifle and a four wheel drive is all i need -Justin Moore
arren is offline   Reply With Quote
Old 03-21-2012, 09:36 PM   #2
RangerSVT
Oct 09 OTOTM
RangerSVT's Avatar
Year: 1996
Make: Ford
Model: Ranger SC 4x4
Engine: GT-40 5.0L EFI W/AC
Class: 4x4 EXTREME DD
Used For: Anger Management
RangerSVT is a splendid one to beholdRangerSVT is a splendid one to beholdRangerSVT is a splendid one to beholdRangerSVT is a splendid one to beholdRangerSVT is a splendid one to beholdRangerSVT is a splendid one to behold
Send a message via Yahoo to RangerSVT
Default
Check your trans mount. Also, check your pinion for play (where the d-shaft bolts to your rear axle). BTW, I hope you re-geared the front as well...
SVT
RangerSVT is online now   Reply With Quote
Old 03-21-2012, 09:43 PM   #3
arren
arren's Avatar
Year: 1994
Make: Mazda
Model: B4000
Engine: 4.0
Class: 4x4
Default
Will check the trans mount. the rear yoke is solid, could be bent tho i guess? not sure. I did regear the front with a lock rite no worries there!
__________________
Old 03-21-2012, 10:00 PM   #4
RangerSVT
Oct 09 OTOTM
RangerSVT's Avatar
Year: 1996
Make: Ford
Default
It's possible you have an axleshaft bent, causing both your vibration and oval-like brake drum...
SVT
Old 03-21-2012, 11:46 PM   #5
Sasquatch_Ryda
Coast Mountain Crawlers
Sasquatch_Ryda's Avatar
Year: 1991/1997/2008
Make: Ford
Model: Ranger/Ranger/SuperDuty
Engine: 4.0L/3.0L/6.4L
Class: 4x4
Used For: Play toy/Daily Driver/Grocery Getter
Sasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to behold
Send a message via MSN to Sasquatch_Ryda
Default
Might be the axle flange bent and not the drum...
__________________
http://www.coastmountaincrawlers.com
1991 Ranger - one tons, 3 link, air shocks and 40's
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 4.56 gears, 6" lift, 33" MT's.
2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake
1967 Mustang Coupe - 289, c4, pretty much stock
Sasquatch_Ryda is offline   Reply With Quote
Old 03-22-2012, 12:02 AM   #6
arren
arren's Avatar
Year: 1994
Make: Mazda
Model: B4000
Engine: 4.0
Class: 4x4
Default
I actually did think of that and replaced that shaft with the one from my old axle, sorry forgot to mention that. I figure it must be good as I didnt have the vibration with that old axle. Once the transmission mount and drum are checked out I will post results. Thanks for the help guys!
__________________
Old 03-22-2012, 01:26 AM   #7
Sasquatch_Ryda
Make: Ford
Class: 4x4
Default
You could drop the rear shaft and go for a drive on the front. See if it changes.
__________________
Old 03-23-2012, 06:58 PM   #8
arren
arren's Avatar
Year: 1994
Make: Mazda
Model: B4000
Engine: 4.0
Class: 4x4
Default
So I got another brake drum and put it on. No change so I jacked the truck up and both drums are rubbing the shoes now. With it running I put my ear to the diff cover and could hear an awful noise like something is broken in there. So, I pulled the cover to see what I could find. The carrier bearings had no play and neither did the pinion. The cross pin had a little bit of axial play so I pulled the retaining bolt and it had play inside the hole of the cross pin. I dont know if that's normal or not. The spider gears had a bit of backlash, again I dont know if that's normal or not. I also noticed my clutch pack(limited slip) is definitely worn out because I can spin the wheels separate without too much difficulty. Aside from that, the axle looked fine. Maybe theres something wrong that I can't see. I wasn't able to get another transmission mount yet, but it doesnt look like it's moving when the truck is up on jacks and running.
__________________
Old 03-24-2012, 04:21 PM   #9
arren
arren's Avatar
Year: 1994
Make: Mazda
Model: B4000
Engine: 4.0
Class: 4x4
Default
Update: I ran the rear end on jacks with the drums off and found both axle shafts looked out of round at the flanges, not a lot but with a screwdriver planted next to it you can see and hear it hit with every rotation. i'm not sure if its out of specs or not but it could be normal as far as i know. theres also a tiny bit of up and down play at the wheel bearings, very minimal but its more than any junkyard axles ive checked have. I checked the rear shocks and they seem fine. I took the driveline out and ran it to see if the noise I'm hearing is coming from the t-case or transmission and there was no noise so its definitely in the rear end. Is there any thing else anyone can think of for me to check?
__________________
Old 03-24-2012, 06:46 PM   #10
legoms013
legoms013's Avatar
Year: 1996
Make: Ford Ranger
Model: XLT 4x4
Engine: 4.0L V6
Class: Serious Bolt On 4x4
Used For: DD, Rearranging the Landscape
legoms013 is a jewel in the roughlegoms013 is a jewel in the roughlegoms013 is a jewel in the roughlegoms013 is a jewel in the rough
Send a message via AIM to legoms013
Default
No.
Nothing should be rotating out of round and there should be no play in the bearing up and down (or left and right). In and out movement of about 1/16" is normal.
Your shafts are bent, I'd get new ones.
Actually it sounds like the axle as a whole as a lot of wear on it. Rebuild it, rebuild another or build an expo 8.8 on the side. It is time to retire that axle in one form or another.
__________________
'00 Ranger on '96 TTB frame/drivetrain
legoms013 is offline   Reply With Quote
Old 04-01-2012, 01:48 AM   #11
arren
arren's Avatar
Year: 1994
Make: Mazda
Model: B4000
Engine: 4.0
Class: 4x4
Default
I was afraid of this. Well I will post back once I am able to afford another axle. Thanks for all the help guys I appreciate it
__________________
Old 04-23-2012, 07:36 PM   #12
sixty9oz
Junior Member
sixty9oz's Avatar
Year: 1992
Make: Ford
Model: Ranger STX Supercab
Engine: 4.0
Class: 4x4
Used For: fixing it. lol
sixty9oz is on a distinguished road
Default
I have basically the same problem, but with the drums off, I can't see anything moving out of round or anthing, and that's putting a straight edge to it and feeling it also. With the drums (which are new), it looks like they are moving up and down a little, but very slightly. Bearings are new. With wheels and tires on, around 60+ on jack stands, it shakes like nobody's business. Replacing the drums helped a lot, but not completely. I'm not sure if it's the axle, shafts, or rims/tires. After a year or so of replacing every bushing/bearing, mount, brake, tires, tie rod end, ball joint, shock and a few other things, I've finally narrowed it down to the rear end, so I know how you feel. lol
sixty9oz is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
