| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 1991
Make: Ford
Model: Ranger
Engine: 4.0L V6
Class: 2WD Off-road
Used For: Daily driver and some off-roading
Rep Power: 0 ![]() iTrader: (0)
Alright I've got a 91', 4.0, 5spd, 2wd with the 8.8 28 spline out back. My buddy has some 4.10's out of a 2000 explorer 8.8 31 spline do you think it will work in my axle? If so do i need just the gears or do i need the carrier as well?
Tweet
#2 | |
I wouldn't bother with a factory limited slip, as already stated, if you are looking for performance, go with a lunch box locker
Quote:
hick |
Tweet
#4 |
Year: 1977
Make: Ford
Model: Pinto
Engine: 2300
Class: 4x4
Used For: Mud racing/trails
Rep Power: 15 ![]() iTrader: (1)
Yeah, the Exploder axles are a different width than the Ranger axles. You could put the whole exploder axle assembly in but, it will require a bit of fab work.
All 8.8 rear gears (Ring and pinion) interchange.
__________________
'84 Ranger, 351c,C6,208,EBsas."DeRanged Mudder" '86 Ranger, 3.0swap,coil rear suspension"Black Frog" |
Tweet
#5 |
Coast Mountain Crawlers
Year: 1991/1997/2008
Make: Ford
Model: Ranger/Ranger/SuperDuty
Engine: 4.0L/3.0L/6.4L
Class: 4x4
Used For: Play toy/Daily Driver/Grocery Getter
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
8.8 gears are 8.8 gears irregardless of spline count
__________________
http://www.coastmountaincrawlers.com 1991 Ranger - one tons, 3 link, air shocks and 40's 1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 4.56 gears, 6" lift, 33" MT's. 2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake 1967 Mustang Coupe - 289, c4, pretty much stock |
Tweet
#6 |
Year: 1997
Make: Ford
Model: Ranger
Rep Power: 12 ![]() iTrader: (0)
He has a 8.8 28 spline axle now. He just needs the 4:10 gears not the carrier. I have a set of 4:10 gears from a 31 spline Explorer axle. I'm 99% sure it will work in his 28 spline Ranger, correct?
__________________
2006 4X2 Ranger 2.3, 5 speed manual. 2004 F150 Supercab 4X4 5.3, auto. 1997 4X4 Ranger standard cab, James Duff Stage 3, 5.5" lift, Explorer rear axle with disc, Detroit Truetrac, 4:88 gears, 33" MTR's. 3.0, auto. . |
Tweet
#8 |
Year: 1991
Make: Ford
Model: Explorer Sport
Engine: 4.0 OHV
Class: 4X4 Extreme
Used For: Wheelin
Rep Power: 14 ![]() iTrader: (0)
Yes.
__________________
2001 Mustang Cobra SVT convertible: 5-speed, 320HP V8, 0-60 in 4.8 2009 Chevy Aveo 5-door LS: 5-speed, DD |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
