Go Back   The Ranger Station Forums > Suspension & Armor > PreRunners
Notices
PreRunners Dedicated to legendary desert racer and Ranger driver Manny Esquerra.
Post New Thread Reply
Thread Tools Display Modes
Old 03-16-2012, 09:44 PM   #1
jesse93
jesse93's Avatar
Year: 1993
Make: ford
Model: ranger
Engine: 4.0l
Class: 4x4
Used For: everything it wasn't made for
jesse93 is on a distinguished road
Default Florida runner build
it has come time for me to finally start my build thread.
what i have started with is a 93 ranger stx 4x4 with a 4.0 auto. i wanted it for a trail truck and sas swap, the whole 9. but i love prerunners, i know there is no where to run one here in muddy Florida but im doing one anyway.
i want to go with a simple but good looking set up seeing im not going to be jumping it at huckfest
i will stop talking and get to the pics.....
bumper i built then trashed
so i can install my 99 front clip
pulled her in to start on the rear
rancho rs9000xl with res. 15in travel
next to my 35
2000 tundra springs. 58in long and have a 8.5in arc
camburg shackles
ballistic fab shock tabs
flipped it, but didnt work for me
then i moved it back 3in and dropped it 2in. braced the frame and built a drop bracket for the hanger
welded it all up
moved the front hanger
installed the spring and i was amazed that i pulled 18in from bump to full drop
put the bed back on and i was..ok..with the height, but when i get my bed sides i will be much happier.
started on my bedcage
all in and now for the fun part.
fully removable, now time to weld it all up
welded up and shocks installed
i still have to add some small braces and my tire rack then i will paint it. im happy with the way it turned out. it rides amazing compared to stock and lifted. the dirt roads are now a blast to drive. ive started on my cut and turn beams but im still doing my homework.
jesse93 is offline   Reply With Quote
Old 03-16-2012, 09:49 PM   #2
jesse93
jesse93's Avatar
Year: 1993
Make: ford
Model: ranger
Engine: 4.0l
Class: 4x4
Default
sorry pics are so big..i have no idea what im doing..lol
Old 03-16-2012, 10:05 PM   #3
getrdone52
Premium Member
getrdone52's Avatar
Year: 1998
Make: Ford
Model: Ranger
Engine: 3.0L
Class: 4x4
Used For: Daily Driver
getrdone52 is a name known to allgetrdone52 is a name known to allgetrdone52 is a name known to allgetrdone52 is a name known to allgetrdone52 is a name known to allgetrdone52 is a name known to all
Default
Why did you get rid of the bumper? Looks good by the way.
__________________
BUILD THREAD
Quote:
Originally Posted by 88_Eddie View Post
woah, woah, woah, buddy....are you trying to give the man bad advice? you never, under any circumstances, put a doodad on a doohicky. it'll cause the thing-a-ma-jig to vibrate too much and wear out the whatchamacallit
getrdone52 is offline   Reply With Quote
Old 03-16-2012, 10:09 PM   #4
jesse93
jesse93's Avatar
Year: 1993
Make: ford
Model: ranger
Engine: 4.0l
Class: 4x4
Default
it gave me over heating problems with the skid plate and it looked goofy from the side, it was almost flat in the front. i will make another one soon.
Old 03-16-2012, 10:16 PM   #5
swickwake
swickwake's Avatar
Year: 98
Make: we all know tha
Model: hhmmm
Engine: 4 Point Big O
Class: 2wd Off-Road.
Used For: Point "a" to point "b" driving. with intentions to go to point "z" first.
swickwake is on a distinguished road
Default
im glad the hanger set up is working for you. truck looks great with the up dated clip and ttb's
swickwake is offline   Reply With Quote
Old 03-16-2012, 10:20 PM   #6
jesse93
jesse93's Avatar
Year: 1993
Make: ford
Model: ranger
Engine: 4.0l
Class: 4x4
Default
Quote:
thanks..i basically copied your hanger set up
Old 03-17-2012, 03:50 PM   #7
bmxryder
bmxryder's Avatar
Year: 1994
Make: ford
Model: ranger
Engine: 4.0
Class: 2wd long travel
Used For: DD and fun
bmxryder is on a distinguished road
Send a message via AIM to bmxryder
Default
Looks like a great start. I dont see why extended 4wd beams couldnt perform as good or better than SAS
__________________
GINGER PRIDE!!
bmxryder is offline   Reply With Quote
Old 03-19-2012, 09:01 AM   #8
nooch450
nooch450's Avatar
Year: 1991
Make: Ford
Model: Ranger XLT
Engine: 4.0 OHV
Class: 4x4 Extreme
Used For: Spending money on that I dont have...
nooch450 is on a distinguished road
Default
Everything looks good to me so far. Are you planning on extending your beams or just doing a cut and turn? I just used stock width with drop brackets, I hear it handles better in woods.
The only think I would do is triangulate the floating shock mount corner (where the two tubes meet at a 90) to the bottom of the cage to give it strength.
How much were those shocks and why did u chose them?
nooch450 is offline   Reply With Quote
Old 03-19-2012, 09:27 AM   #9
06RangerXLT
06RangerXLT's Avatar
Year: 2006
Make: Ford
Model: Ranger XLT Extended Cab
Engine: 4.0L
Class: 2WD Country
Used For: Shenanigans
06RangerXLT has much to be proud of06RangerXLT has much to be proud of06RangerXLT has much to be proud of06RangerXLT has much to be proud of06RangerXLT has much to be proud of06RangerXLT has much to be proud of06RangerXLT has much to be proud of06RangerXLT has much to be proud of06RangerXLT has much to be proud of
Default
you gotta gusset that bed cage, especially around the plates mounting it to the bed itself.
otherwise, it looks good. though your droop is way past where you want it to stop. you droop it until the leafs separate, go up one inch and strap it there. best rule of thumb to avoid destroying them or something else.
__________________
Camburg BTF mid-travel kit, 64's, 33x12's,E-Fan Conversion, 4.56 8.8, McNeil Glass
06RangerXLT is offline   Reply With Quote
Old 03-19-2012, 07:24 PM   #10
doyouquaxu
doyouquaxu's Avatar
Year: 2005
Make: Ford
Model: Ranger XLT
Engine: 3.0
Class: 2WD Off-Road
Used For: Desert Shenanigans and DD
doyouquaxu is a jewel in the roughdoyouquaxu is a jewel in the roughdoyouquaxu is a jewel in the roughdoyouquaxu is a jewel in the rough
Default
do you not have a notcher or anything?
__________________
Quote:
So this thread should be about pictures of your truck next to a tank.
doyouquaxu is offline   Reply With Quote
Old 03-21-2012, 03:21 PM   #11
jesse93
jesse93's Avatar
Year: 1993
Make: ford
Model: ranger
Engine: 4.0l
Class: 4x4
Default
im going to do the cut and turn to get rid of the drop brackets.
the bed cage has been gusseted since pics. but i want to do more, as well as my tire carrier.
the shocks were 350.00 shipped and i picked them because its my daily and i wont be doing any crazy jumping with it, just down dirt roads.
thanks for the advise on the droop, i will be straping it.
i have a hf nocther and it wasnt doing its job so i had to do them by hand. i know that some of them are good, some are not.
Old 03-21-2012, 05:37 PM   #12
nooch450
nooch450's Avatar
Year: 1991
Make: Ford
Model: Ranger XLT
Engine: 4.0 OHV
Class: 4x4 Extreme
Default
If the notcher is not notching the pipe centered shim the clamp with washers... look how the pipe sits in it and fix the thing...
I would keep the drop brackets, it will keep your steering alignment better (if you plan on running stock setup with pitman arm drop) and also I hear C&T can cause weird handlin up hills in the woods ext...
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
