Serving 1984-1990 Ford Bronco II Owners & Enthusiasts
Home Library Bronco II's For Sale Bronco II Gallery B2C Shirts & Decals The Ranger Station
Go Back   The Ranger Station Forums > Truck Discussions > Bronco II & Explorer Specific
Notices
Bronco II & Explorer Specific Also check out our Bronco II section at the BroncoIICorral
Post New Thread Reply
Thread Tools Display Modes
Old 03-12-2012, 05:59 PM   #1
jstcuz
Year: 1986
Make: Ford
Model: Bronco II 4WD
Engine: 2.9L
Class: 4WD
Used For: Just about everything
jstcuz is on a distinguished road
Default Rattling Brakes!
So, I have an 86 Bronco II that goes through anti-rattle clips like a kid goes through candy. My brakes are always rattling!
My dad had the same problem with his 85 Ranger. It's like the anti-rattle clips just get worn out real fast or something.
Does anyone have any good tips/tricks to get them to stay in or ANY tips/tricks just to get the brakes to stop rattling?
Thanks
jstcuz is offline   Reply With Quote
Old 03-12-2012, 06:04 PM   #2
shane96ranger
\----===FoMoCo===----/
shane96ranger's Avatar
Year: 1997 / 1989
Make: Ford
Model: F150 XLT / Mustang GT
Engine: 4.6 Triton / 5.0
Class: 4X4 / Hot Rod
Used For: Everything / The war on imports
shane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond repute
Default
Thanks
I always open them up further to cause a little more pressure. I've seen some clips siliconed to the pad on some rigs in the junkyard, but I've never tried it.
__________________
Click to see my 97 F-150 XLT
Click to see my 89 Mustang GT
Quote:
Originally Posted by jammert609@yahoo.com View Post
I am being told by family an friends my truck is a piece of shit
shane96ranger is offline   Reply With Quote
Old 03-12-2012, 06:09 PM   #3
will1861
Junior Member
will1861's Avatar
Year: 1991
Make: Ford
Model: XLT
Engine: 2.3
Class: 2wd
Used For: DD
will1861 is on a distinguished road
Default
Are your rotors on good shape? Sometimes a warped rotor could put presure at different points causing the spring clips to expand and wear at a faster rate
will1861 is offline   Reply With Quote
Old 03-12-2012, 07:36 PM   #4
Earl43P
Premium Member
Year: 2000
Make: Ford
Model: Ranger
Engine: 3.0
Class: 4WD
Used For: DD
Earl43P is just really niceEarl43P is just really niceEarl43P is just really niceEarl43P is just really niceEarl43P is just really nice
Default
That 86 has those rubber bushed pins to mount the calipers.
Try a new set, they're cheap.
The other thing I always do is add a nice bead of that CRC Disk Brake Quiet goop everywhere the pad touches. Put a ring atop the piston and dabs on the ears and back of the stationary pad, after cleaning up the caliper contact points. Even if the pads have those plates I always use that stuff.
__________________
If at first, you don't succeed, RTFM.
Earl43P is offline   Reply With Quote
Old 03-12-2012, 08:53 PM   #5
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: What engine?
Class: 4x4
Used For: Elevenses
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
I do everything Earl said with two major differences.
1) I throw the rattle pads in the trash as soon as I open the box.
2) I use Motorcraft dielectric and caliper grease. I have found that the CRC stuff dries into a gel that can allow some funny things to happen if you goop it took thick. I also don't like the way it gets stuck in everything and never washes out of fabric and glues stuff together. It's worse than jizz once it starts to dry.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: 12-Volt Sandwich
Quote:
Originally Posted by Mark_88 View Post
Question: "What year is your truck"?
My Answer: "What part"?
Quote:
Originally Posted by John Adams
Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other.
HELP REPEAL OBAMACARE
Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind.
adsm08 is offline   Reply With Quote
Old 03-12-2012, 09:21 PM   #6
shane96ranger
Year: 1997 / 1989
Make: Ford
Default
Quote:
That rules!
Maybe what I thought was silicone was the CRC stuff. I had some years ago that was spray on, but I didn't think it did a damn bit of good.
__________________
Old 03-13-2012, 12:52 AM   #7
Brownie Mobile
Brownie Mobile's Avatar
Year: 1984
Make: Ford
Model: Bronco II
Engine: 2.8l
Class: 4x4
Used For: To take up space in my driveway
Brownie Mobile is on a distinguished road
Default
i had the same problem and i found if you bend the clip for a tighter snugger fit it seems to work better just is a bitch to get on.
Brownie Mobile is offline   Reply With Quote
Old 04-12-2012, 06:44 PM   #8
jstcuz
Year: 1986
Make: Ford
Engine: 2.9L
Class: 4WD
Default
Hey thanks guys.
I think I got it fixed by just bending the clip a little more so it's tighter and cleaning up the contact points where the pad touches and so far it's quiet again!
Old 04-12-2012, 06:49 PM   #9
clvanhorn
clvanhorn's Avatar
Year: 1988
Make: Ford
Model: Ranger
Engine: 2.9
Class: 4x4
Used For: dd and my workhorse
clvanhorn has a spectacular aura aboutclvanhorn has a spectacular aura aboutclvanhorn has a spectacular aura about
Default
lol... sigged.
__________________
clvanhorn is offline   Reply With Quote
Reply
Bookmarks
Tags
brakes, bronco ii, clips, question
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
