Tom Cat
- Feb 24, 2009
- Automatic
Listed as stock replacement.
Ford stock cam info
351W
Valve Lift (Intake / Exhaust) .444 / .452 .050" Duration (Intake / Exhaust) 206 / 221 Lobe Separation Angle 117 / 113
240, 300 I6
Valve Lift (Intake / Exhaust) .395 / .395 .050" Duration (Intake / Exhaust) 192 / 192 Lobe Separation Angle 108 / 114
2.3, 2.5 ROLLER
Valve Lift (Intake / Exhaust) .354 / .353 .050" Duration (Intake / Exhaust) 188 / 188 Lobe Separation Angle 120 / 104
2.3 TURBO
2.3 1987/90
Valve Lift (Intake / Exhaust) .390 / .390 .050" Duration (Intake / Exhaust) 187 / 190 Lobe Separation Angle 108 / 116
2.3 1974/86
Valve Lift (Intake / Exhaust) .399 / .399 .050" Duration (Intake / Exhaust) 196 / 196 Lobe Separation Angle 129 / 111
2.5L HSC 1986/90
Valve Lift (Intake / Exhaust) .249 / .239 .050" Duration (Intake / Exhaust) 202 / 190
144, 170, 200I 6
Valve Lift (Intake / Exhaust) .349 / .349 .050" Duration (Intake / Exhaust) 180 / 180
250 1969/80
Valve Lift (Intake / Exhaust) .366 / .366 .050" Duration (Intake / Exhaust) 185 / 185 Lobe Separation Angle 112 / 103
370, 429, 460
Valve Lift (Intake / Exhaust) .437 / .480 .050" Duration (Intake / Exhaust) 193 / 206 Lobe Separation Angle 110 / 116
352, 360, 390
Valve Lift (Intake / Exhaust) .432 / .435 .050" Duration (Intake / Exhaust) 192 / 199 Lobe Separation Angle 113 / 111
289 1963/68, 302 1968/76
Valve Lift (Intake / Exhaust) .368 / .380 .050" Duration (Intake / Exhaust) 184 / 189 Lobe Separation Angle 114 / 104
302 1976/91 TRUCK, 255 1980/82
Valve Lift (Intake / Exhaust) .380 / .395 .050" Duration (Intake / Exhaust) 184 / 192 Lobe Separation Angle 103 / 111
SVO TURBO CAM, engine not specified
Valve Lift (Intake / Exhaust) .437 / .437 .050" Duration (Intake / Exhaust) 208 / 208
2.9 1986/92
Valve Lift (Intake / Exhaust) .358 / .370 .050" Duration (Intake / Exhaust) 196 / 200 Lobe Separation Angle 102 / 117
3.0 VULCAN
Valve Lift (Intake / Exhaust) .416 / .416 .050" Duration (Intake / Exhaust) 198 / 198 Lobe Separation Angle 110 / 118
4.0 OHV 1995/97
.050" Duration (Int/Exh) 189 / 206 Cam Lift (Int/Exh) .263" / .275"
Valve Lift (Int/Exh) .384" / .402" Lobe Separation (Int/Exh) 107 / 117
3.8 1982/83
Valve Lift (Intake / Exhaust) .415 / .416 .050" Duration (Intake / Exhaust) 186 / 201 Lobe Separation Angle 106 / 114
3.8 1989/96 4.2 1997/2008 ROLLER
Valve Lift (Intake / Exhaust) .423 / .447 .050" Duration (Intake / Exhaust) 185 / 203 Lobe Separation Angle 106 / 114
1970/74 351C 351/400M ALL
Valve Lift (Intake / Exhaust) .428 / .432 .050" Duration (Intake / Exhaust) 192 / 198 Lobe Separation Angle 109 / 111
6.9, 7.3 IDI
Valve Lift (Intake / Exhaust) .253 / .253 .050" Duration (Intake / Exhaust) 176 / 184 Lobe Separation Angle 103 / 105
389 6.3L 1975/78 ??, 330 1964/78
Valve Lift (Intake / Exhaust) .425 / .425 .050" Duration (Intake / Exhaust) 193 / 193 Lobe Separation Angle 110 / 110
Ford stock cam info
351W
240, 300 I6
2.3, 2.5 ROLLER
2.3 TURBO
2.3 1987/90
2.3 1974/86
2.5L HSC 1986/90
144, 170, 200I 6
250 1969/80
370, 429, 460
352, 360, 390
2.9 1986/92
3.0 VULCAN
4.0 OHV 1995/97
3.8 1982/83
6.9, 7.3 IDI
