Driveshafts after SAS?
triumphrider-1
15+ Year Member
Port Huron, MI
For those that have done an SAS, what drive shafts did you use? Were they homemade, modified orginals, or bought?
Thanks
So far it looks as if my stock (upgraded to 98+ rear) shafts are gonna work fine, the front bolts right up. However, forklift flex testing will tell me whether I need to add limit straps/build longer shafts.
-andrew
I'm planning on using modifyed shafts from possibly an F150 with the correct U joint size
my front shaft bolted up.
