Go Back   The Ranger Station Forums > Suspension & Armor > PreRunners
Notices
PreRunners Dedicated to legendary desert racer and Ranger driver Manny Esquerra.
Post New Thread Reply
Thread Tools Display Modes
Old 02-21-2012, 03:07 AM   #1
redrider121
Year: 2005
Make: Ford
Model: Ranger Edge 2WD
redrider121 is on a distinguished road
Default Ranger Edge long travel input please
What's up everyone. First actual post in TRS (aside from that inroduction page). Anyways, I've got a stock 05 ranger edge 2wd. As most of you know, the edge's came factory "lifted". But Im considering trying to fabricate my own long travel suspension system. I'm looking for ideas or people who have already done this to an edge.
Camburg, Blitzkreig, and a few other companies have long travel kits for purchase, but I don't have the cash or the will to lay down 12K in a nice long travel system.... so my solution is to build my own!
Any help would be greatly appreciated.
redrider121 is offline   Reply With Quote
Old 02-22-2012, 01:58 AM   #2
doyouquaxu
doyouquaxu's Avatar
Year: 2005
Make: Ford
Model: Ranger XLT
Engine: 3.0
Class: 2WD Off-Road
Used For: Desert Shenanigans and DD
doyouquaxu is a jewel in the roughdoyouquaxu is a jewel in the roughdoyouquaxu is a jewel in the roughdoyouquaxu is a jewel in the rough
Default
Without the use of Google define these terms
Castor
Camber
Spindle
Upright
Scrub Radius
Ackerman angle
King Pin Inclination
If you can accurately define those 7 terms, you're ready to move to the next step of building a long travel kit, the next step is step 2, there are 398,765 steps, better get started.
__________________
Quote:
So this thread should be about pictures of your truck next to a tank.
doyouquaxu is offline   Reply With Quote
Old 02-22-2012, 02:04 AM   #3
alwaysFlOoReD
Super Moderator
Year: '91, '85, '97
Make: ford
Model: ranger, b-II, f-150
Engine: 4.0,4.0,4.2
Class: 4x4 race, 4x4, 2wd work
Used For: 4x4 race, 4x4,2wd work
alwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to behold
Default
I have a basic grasp of all except 'upright'. Please elaborate.
Thanks,
Richard
__________________
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
alwaysFlOoReD is online now   Reply With Quote
Old 02-22-2012, 02:18 AM   #4
bilzy7
bilzy7's Avatar
Year: 1998
Make: Ford
Model: Explorer
Engine: 4.0 SOHC
Class: 4x4
Used For: daily driving, fun in the snow
bilzy7 is a glorious beacon of lightbilzy7 is a glorious beacon of lightbilzy7 is a glorious beacon of lightbilzy7 is a glorious beacon of lightbilzy7 is a glorious beacon of light
Default
12k... Who said you need to spend that much... Figure out your front end suspension... Then attack the rear... I planned on doing rear myself and having a shop install my front suspension... Then my wife raped my face and I was broke... Ugh... Good times.
__________________
1999 Ranger 4.0 4x4 Off Road
http://www.therangerstation.com/foru...d.php?t=103611 <--- My Slow Build
bilzy7 is offline   Reply With Quote
Old 02-22-2012, 02:38 AM   #5
doyouquaxu
doyouquaxu's Avatar
Year: 2005
Make: Ford
Model: Ranger XLT
Engine: 3.0
Class: 2WD Off-Road
Default
10k is the average cost of a blitzkrieg kit to drive your truck in stock and leave with a front kit put on a ranger, 1500ish less if you don't want bypasses. you're lucky you have an edge truck though, less cutting on the frame.
__________________
Old 02-22-2012, 08:44 AM   #6
redrider121
Year: 2005
Make: Ford
Default
Yeah, its around 10k for BLitzkrieg and more for camburg.. if you let them do all the work.
I understand all of those terms aside from upright just like alwaysfloored. And the rear suspension is really simple to me, I'll tackle that later.
What I had in mind was something along the line of scrapping the torsion bars that are on my truck now and fabricating a boxed lower a-arm with 4130 chrom-moly (maybe some other material, idk yet). And offsetting the control arm towards the rear by means of an offset, as well as with a full suspension rotation to get roughly 10* of castor. With the suspension rotated back slightly, and the king pin angled back also, it will give me a zero camber when driving straight, positive and negative to the left and right tires when I turn right, respectively, and vice versa to the left. My hopes with the suspension rated back slightly is that it will soak up bumps a little easier. (I'm using dirtbike fork geometry for this)
I don't really care about ackerman angle because turning radius really doesn't bother me. I learned to drive in a chevy 3500 long bed daully crew cab lol.
Old 02-22-2012, 12:05 PM   #7
motorbill87
motorbill87's Avatar
Year: 2003/2006
Make: Ford
Model: Ranger EDGE/F-150
Engine: 5.8L/4.6L
Used For: money pit/ D.D.
motorbill87 will become famous soon enough
Default
With it set back, do you mean bringing the front centerline towards the rear of the vehicle? Youre going to have clearance issues with bigger tires if you do.
Having an idea in your head and actually building the parts is a completely different reality. I'm not tryintg to be a dick but do you have a good solid know how or background with metal fabrication and welding? If you're not solid on that matter i wouldn't even try to make any suspension components.
If you are a well rounded fabber and welder than more power to you! I build most of my own components my self but found out quick that you've gotta have the good quality equiptment cause a good build doesnt come from harbour freight tools lol.
__________________
STILL LOOKIN FOR SOMEONE TO GO WHEELIN WITH
motorbill87 is offline   Reply With Quote
Old 02-22-2012, 01:14 PM   #8
doyouquaxu
doyouquaxu's Avatar
Year: 2005
Make: Ford
Model: Ranger XLT
Engine: 3.0
Class: 2WD Off-Road
Default
only problem with setting it back is that you'll run into clearance issues with your tire and the fire wall. if anything, people like to push the wheel base forward and inch or two to clear bigger tires at full lock at the fire wall.
if you design the arms with enough internal ribs and whatnot, you don't have to use 4130 plate. you can, to be a baller, but a lot of kits are made of mild or less expensive steel.
__________________
Old 02-22-2012, 02:38 PM   #9
redrider121
Year: 2005
Make: Ford
Default
Sorry, I should have specified.
I was going to run 32" tires and leave the control arms close to their location and push the lower a arms towards the front so clearance isn't an issue.
Welding isn't an issue. I've been welding for about 5 years now. I prefer stick or oxy-acetelen, but mig and fluxcore are easy too. As for Tig welding, I have lots of friends that Tig weld for a profession.
Do you think if I used an internal ribbing method with medium steel the supports should be vertical or triangular (on the inside)?
Also, does anyone know about front shock angle? because I see some buggies and rails with the shocks mounted at 45* to vertical (or close to it). Are there benefits/drawbacks to this?
Old 02-22-2012, 11:03 PM   #10
doyouquaxu
doyouquaxu's Avatar
Year: 2005
Make: Ford
Model: Ranger XLT
Engine: 3.0
Class: 2WD Off-Road
Default
Vertical ribs between the plates. Id say mig weld everything.
The shocks should be as close to 90* in relation to the lower arm at bump as possible. Angling forward or back doesn't matter much, as long as everything clears
__________________
Old 02-28-2012, 01:34 AM   #11
Cody Ray
Cody Ray is on a distinguished road
Default
I'm all for people building they'er own stuff, but just remember that you will be depending on these parts to support the weight of a vehicle and whatever off-roading you will be doing. Not to mention the fact that if you get into an accident because of a mistake in your fabrication you could be in serious dooky.
Cody Ray is offline   Reply With Quote
Old 02-28-2012, 01:37 AM   #12
Cody Ray
Default
Quote:
Castor
Camber
Spindle
Upright
Scrub Radius
Ackerman angle
Where is toe
Reply
Bookmarks
Tags
baja, lift kit, long travel, prerunner
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
