Serving 1984-1990 Ford Bronco II Owners & Enthusiasts
Home Library Bronco II's For Sale Bronco II Gallery B2C Shirts & Decals The Ranger Station
Go Back   The Ranger Station Forums > Truck Discussions > Bronco II & Explorer Specific
Notices
Bronco II & Explorer Specific Also check out our Bronco II section at the BroncoIICorral
Post New Thread Reply
Thread Tools Display Modes
Old 02-19-2012, 05:40 PM   #1
jgill
Year: 1986
Make: Ford
Model: Bronco ll
jgill is on a distinguished road
Default New Bronco 2 owner needs help
Issue
I just picked up a 86 bronco II xlt V-6 2.9,4wd,5-speed.Has 44,000 original miles on it bought it from an old lady for 800 bucks.I live out in Moab,Ut I want to make this a trail truck for site seeing around the area.So here are the issues I have so far with the truck.*
1.Grinding popping noise during take off or acceleration,sound like it coming from the back or center of vehicle??
2.4wd will engage with button but will not disengage,unless you disconnect the battery wait awhile then hit the button??
3.Door lock work fine with button in cab,but will not unlock with key,barley turns then comes to a dead stop.
4.Fuel gauge only reads E or F....sending unit??
5.when putting the window up it falls forward...is there plastic rollers to guide it up??
Any help with issues would be grate new to the bronco II world...one last question what is the widest tire and wheel combo for stock height.I want wider tires to help stabilize the truck and reduce roll over risk!! **
jgill is offline   Reply With Quote
Old 02-19-2012, 07:23 PM   #2
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: What engine?
Class: 4x4
Used For: Elevenses
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
Good looking vehicle.
1) Hard to say without hearing it in person.
2) Probably the module. Find a manual transfer case. Barring that, I am manual swapping my 88. I'll rip the module out and sell it to you cheap, but my low range doesn't work, not sure if it's the button or the module.
3) Probably worn out key or lock cylinder. Are your keys worn out really badly?
4) Probably the sending unit. Search around for posts about putting a patch plate in for ease of access to the pump.
5) Nope, no rollers. That is a common problem with the dog ear window setups. Aside from ditching them for full windows I don't know what the fix is. If I had to guess, I'd say the regulator, but I'm not sure of that.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: 12-Volt Sandwich
Quote:
Originally Posted by Mark_88 View Post
Question: "What year is your truck"?
My Answer: "What part"?
Quote:
Originally Posted by John Adams
Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other.
HELP REPEAL OBAMACARE
Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind.
adsm08 is offline   Reply With Quote
Old 02-19-2012, 07:27 PM   #3
Earl43P
Premium Member
Year: 2000
Make: Ford
Model: Ranger
Engine: 3.0
Class: 4WD
Used For: DD
Earl43P is just really niceEarl43P is just really niceEarl43P is just really niceEarl43P is just really niceEarl43P is just really nice
Default
What a beautiful "survivor"!
You got a great deal on that truck.
Window: sounds like you need a new regulator (requires drilling out a rivet and replacing the regulator, and the rivet becomes a bolt/nut).
Door lock is probably a bad lock actuator, 4wd shift is probably a bad shift motor (or clean it using the procedure in the Tech Library Tab at the top of the page). The popping might be a stretched transfer case chain. Shop around, transfer cases are everywhere for these trucks.
Welcome to The Ranger Station!
__________________
If at first, you don't succeed, RTFM.
Earl43P is offline   Reply With Quote
Old 02-19-2012, 07:40 PM   #4
88_Eddie
Motorboater (.Y.)
Chopper Challenge Champion
88_Eddie's Avatar
Year: 1988, 2000
Make: Ford
Model: Bronco II (Eddie Bauer), Explorer
Engine: 2.9L, 4.0L
Class: 4x4, 2WD
Used For: Annoying the old ball and chain.
88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute
Default
nice lookin b2
__________________
BUILD THREAD<<<<<<<<<<<<<
The Tikki Torch Build Thread
1988 Bronco II 4x4 2.9, FM146, 1350M, Disc 8.8, D30 SAS, 3.73's, 31's (for now)
2000 Explorer 4.0 2WD DD
Everything I need to know about Islam, I learned on 9/11.
The hardest part about a zombie apocalypse will be pretending I'm not excited.
Quote:
Originally Posted by Wedding Crashers
What'd you do with them? Motorboat? You play the motorboat? You motorboatin son of a bitch! You old sailor you!
Quote:
Originally Posted by jammert609@yahoo.com View Post
I am being told by family an friends my truck is a piece of shit
88_Eddie is offline   Reply With Quote
Old 02-19-2012, 07:51 PM   #5
whatelseisleft
Junior Member
whatelseisleft's Avatar
Year: 1987
Make: ford
Model: Bronco2
Engine: 2.9 for now
Class: 4x4
Used For: everything
whatelseisleft will become famous soon enough
Default
popping noise is probabaly the driveshaft especially if it is the tulip style(cv joint) they suck really bad...
__________________
whatever you do just don't stop !!!
whatelseisleft is offline   Reply With Quote
Old 02-19-2012, 07:54 PM   #6
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Class: 4x4
Used For: Elevenses
Default
Quote:
Can't be. He said it works fine with the button, it's the key that gives him problems.
__________________
Old 02-19-2012, 07:56 PM   #7
kimcrwbr1
kimcrwbr1's Avatar
Year: 1983
Make: ford
Model: ranger
Engine: 2.8l
Class: 2WD street
Used For: DD tow boat
kimcrwbr1 is just really nicekimcrwbr1 is just really nicekimcrwbr1 is just really nicekimcrwbr1 is just really nice
Default
Sounds like it needs alot of work I`ll give you $500 cash. Just kidding give it a good once over clean all the elect connectors and use some dielectric grease when you put them together. LMC truck has all the parts new you need for the doors windows they are not too hard to take apart. You may be able to find the parts at the bone yard figure out what tools you need by taking it apart first then you know exactly what you need as far as tools and parts.
__________________
it takes a nickle to go first class
when it stops hurting it will feel alot better
kimcrwbr1 is offline   Reply With Quote
Old 02-19-2012, 08:21 PM   #8
jgill
Year: 1986
Make: Ford
Model: Bronco ll
Default
Thanks for tips and comments on the b2..sounds like I have my work cut out for me next set of days off.Yea the keys are original ,also found under the flag tire cover was hideing the orginal bronco 2 cover!!
I almost don't want to do anything to it and just keep it all original..?
Old 02-19-2012, 08:52 PM   #9
kimcrwbr1
kimcrwbr1's Avatar
Year: 1983
Make: ford
Model: ranger
Engine: 2.8l
Class: 2WD street
Default
Looks like good wheels and tires stock will work just fine. Block the front tires and put it in neutral and then get under it and wiggle the shafts if you see/feel any movement other than gear lash in the rear you will need to drop the shaft and replace whatever is bad. I allways replace all the u-joints while I have it apart they are not that expensive. I would change all the fluids and gear oil look for metal shavings. A little preventive maint goes A long way give it a good once over now. I like to get my manuals at the bone yard for $10 if they have one.
__________________
Old 02-19-2012, 11:51 PM   #10
trail B2
trail B2's Avatar
Year: 1986
Make: ford
Model: bronco 2
Engine: 4.0
Class: 4x4
Used For: 4x4 and DD
trail B2 will become famous soon enough
Default
My 86 doesn't have a wind wing must have changed mid year.I would try squirting some oil in the lock with a little straw on a good lubricant.Then try working it some more.
__________________
We make A living by what we get, We make A life by what we give.http://www.therangerstation.com/foru...lies/yahoo.gif
trail B2 is offline   Reply With Quote
Old 02-19-2012, 11:52 PM   #11
cstill88@hotmail.com
Year: 1986
Make: ford
Model: bronco 2
Engine: 2.9
Class: 4x4
Used For: Driving
cstill88@hotmail.com is on a distinguished road
Default Bronco II
Fuel gauge problem is a bad ground, these have bad grounds all over, the advice about dielectric grease is good too.
Your truck looks like my twin except yours is in better shape... have fun with it, they are pretty capable as stock.
cstill88@hotmail.com is offline   Reply With Quote
Old 02-20-2012, 12:27 AM   #12
4.0B2
MALL CRAWLER POST WHORE!
4.0B2's Avatar
Year: 1988
Make: Ford
Model: Bronco II
Engine: 4.0 v6
Class: 4x4
Used For: Taking my Money
4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute
Default
1. welcome
2. YOU POSTED PICS! GOOD JOB!
ok... i'm gonna say
1. driveshaft. swap out the cv joint one for a u-joint one
2. listen to adsm08. he knows his stuff.
4.0B2 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
