Go Back   The Ranger Station Forums > Axles, Brakes, Wheels & Tires > Brakes
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 02-07-2012, 05:21 AM   #1
sbsrlewis
sbsrlewis's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4x4
Used For: Play and daily driver
sbsrlewis will become famous soon enough
Default Master cylinder ?
I'm hoping I can get some guidance on my brake. Here's a brief histor that since the issue started.
Last fall I bought and installed Dana 35 beams with Dana 44 Outers on my 89 BII. During the install I replaced the rotors, calipers and pads with new ones. After the install the brake pedal traveled further and didn't seem as strong. Not long after I swapped the drums on by 8.8 to disk. After this the braking got even worse so I changed the BII master cylinder out for one from an Explorer with 4 wheel disk and removed the RABS moduel and there has been no improvement.
I am using the original BII hard lines and bought the extended stainless braided lines from Duff. I also purchased a Motive Products power bleeder. I have bleed the brake numerous times but braking remains the same.
Do you think that a master cylinder from a 1/2 would fix this issue and get my brakes back? I would like to get this solved so I can start driving this again plus I have an off-road trip coming up that I won't be able to do without brakes.
Ideas?
Steve
__________________
1989 BII, 4.0, Mazda 5-Speed, 1350/1354 Doubler, D-35 w/D-44 outers, 8.8 w/Yukon Ultimate 88 kit and disk brakes, 1" BL, JD Coil Buckets, 66-77 F150 Coils, JD HD Coil Seats, JD front quad shocks, JD Extended Radius Arms, Extended Braided Stainless Steel brake lines, Cut fenders, 33" Pro Comps, Line-X'd interior & rocker panels.
sbsrlewis is offline   Reply With Quote
Old 02-07-2012, 08:52 AM   #2
infantry grunt
infantry grunt's Avatar
Year: 1994
Make: mazda
Model: b-3000
Engine: 3.0l
Class: 4x4
Used For: everything
infantry grunt will become famous soon enough
Default
proportioner valve maybe,this happened on my wifes truck once,i was stummped,replaced everything i knew to.its like a junction where your brake lines go into and out of,should be mounted inside your frame rail.hpe this is useful
__________________
4 inch skyjacker,3 inch body,d35 and 99 explorer 8.8 with disc brakes,33x1250-15,4.56 gears,flat black paint(removed and/or painted over ALL reflectors, homemade,cannot and will not be detected at night, spare tire carrier(made from sway bar)mounts in the bed,back off or dim your lights rear monted fog lights w/toggle switch(lol),trimmed fenders,and saving up for 35's(finally)WOOHOO!!
infantry grunt is offline   Reply With Quote
Old 02-07-2012, 10:25 AM   #3
kryptonitecb
Premium Member
kryptonitecb's Avatar
Year: 1994
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: daily driver, trail ready
kryptonitecb is just really nicekryptonitecb is just really nicekryptonitecb is just really nicekryptonitecb is just really nicekryptonitecb is just really nice
Default
If you get a master cylinder from an explorer with 4 wheel disk and the proportionating built in it may solve your issue. I did that swap when I moved from drum to 4 wheel disk on my ranger. Also try adjusting the rod that goes from the booster to the master cylinder. After I replaced my master and extended that rod (which is a pita, you have to adjust, install, test, remove, adjust, etc) everything worked great. This was on a ranger with 8.8 rear and d35 ttb front so it may require some trial and error for you to make it work.
Sent from the road while ignoring traffic
kryptonitecb is offline   Reply With Quote
Old 02-07-2012, 10:46 AM   #4
alwaysFlOoReD
Super Moderator
Year: '91, '85, '97
Make: ford
Model: ranger, b-II, f-150
Engine: 4.0,4.0,4.2
Class: 4x4 race, 4x4, 2wd work
Used For: 4x4 race, 4x4,2wd work
alwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to behold
Default
All I have is some thoughts, I don't have real world experience.
You replaced the rubber lines with ss braided so there shouldn't be any swelling of the lines going on.
You aren't losing fluid.
You have correctly bled the system.[?]
You have replaced the front calipers with new that have a larger piston displacement [larger volume]
You have replaced the rear drums with calipers that have a larger piston displacement [larger volume]
You are using a master with a small displacement piston [small volume].
Replace small volume master with larger
I think your idea of using a 1/2 ton master is valid. I do remember seeing a thread about this same problem and IIRC that was the solution. I would look for a master from a truck with brakes closest to what you have now. You may have to incorporate an adjustable proportioning valve.
Good luck,
Richard
__________________
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
alwaysFlOoReD is offline   Reply With Quote
Old 02-07-2012, 02:21 PM   #5
Sasquatch_Ryda
Coast Mountain Crawlers
Sasquatch_Ryda's Avatar
Year: 1991/1997/2008
Make: Ford
Model: Ranger/Ranger/SuperDuty
Engine: 4.0L/3.0L/6.4L
Class: 4x4
Used For: Play toy/Daily Driver/Grocery Getter
Sasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to behold
Send a message via MSN to Sasquatch_Ryda
Default
Front calipers on are the correct sides and the bleeders are at the top of the caliper correct?
__________________
http://www.coastmountaincrawlers.com
1991 Ranger - one tons, 3 link, air shocks and 40's
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 4.56 gears, 6" lift, 33" MT's.
2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake
1967 Mustang Coupe - 289, c4, pretty much stock
Sasquatch_Ryda is online now   Reply With Quote
Old 02-07-2012, 06:21 PM   #6
Loud Ranger
Loud Ranger's Avatar
Year: '95
Make: Ford
Model: Ranger XLT Ext. Cab
Engine: 4.0
Class: 4x4
Loud Ranger is on a distinguished road
Default
Quote:
^Id double check this, When i installed my 8.8 discs i accidently swapped sides with the calipers since they were labeled wrong. Couldnt get much pressure at all since all the air was trapped in the top of the caliper and the bleeders were pointing down.
__________________
Explorer 8.8 Swap
32x11.50x17 BFG Mud Terrain Km's
Flowmaster 40 series
My Cardomain site:
http://www.cardomain.com/ride/3234904
Loud Ranger is offline   Reply With Quote
Old 02-09-2012, 05:08 AM   #7
sbsrlewis
sbsrlewis's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4x4
Default
I will double check to make sure I have the calipers on the correct side but I think I will try and extend the rod before I replace the master cyl. Thanks for the ideas.
Steve
__________________
Old 02-10-2012, 12:44 PM   #8
kryptonitecb
Premium Member
Year: 1994
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Default
That rod is something that isn't discussed in the library and was all I had to do to make mine work right. The post I ran across had mentioned that the stock ranger rod length is less than that of the explorers by a couple hairs. I was at my wits end like you so I gave it a try and it worked perfectly. Hopefully it solves your issue also.
Old 02-10-2012, 01:18 PM   #9
sbsrlewis
sbsrlewis's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4x4
Default
I checked my nipples are up...or should I say the brake bleeders are in the up position.
As for adjusting the rod, which is my next step, does 1 full turn make a BIG difference? Curious as to how much I should turn it out?
Steve
__________________
Old 02-10-2012, 01:29 PM   #10
scooter
October OTOTM Winner
scooter's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 5.0L
Class: 4x4 Extreme
Used For: FUN.
scooter has much to be proud ofscooter has much to be proud ofscooter has much to be proud ofscooter has much to be proud ofscooter has much to be proud ofscooter has much to be proud ofscooter has much to be proud ofscooter has much to be proud ofscooter has much to be proud ofscooter has much to be proud of
Default
I went bout three turns at a time, only put two nut on it while testing also.
I pretty well did the same thing you did untill i noticed the adjuster on
the MC.
__________________
1989 Bronco II, 5.0L H.O.,C-6 Transmission,203/205 doubler, Rockwells 4 wheel steer,44in Boggers, 3-link front, 1-link rear.
Drunken Rock Brigade.
OCT 2008 OTOTM
Cardomain:http://www.cardomain.com/ride/2927642
scooter is offline   Reply With Quote
Old 02-10-2012, 02:44 PM   #11
kryptonitecb
Premium Member
Year: 1994
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Default
X2 to scooter, take off MC, adjust, install 2 nuts, test, repeat till good. Make sure not to extend to far or you will constantly engage the MC.
Old 02-10-2012, 05:39 PM   #12
scooter
scooter's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 5.0L
Class: 4x4 Extreme
Used For: FUN.
Default
Um yeaaaaaa, i did that too.... Drove it around a bit (around the block), brakes were touchy.
Came back home and was like uhhh ohhhhh i smell HOT brakes!!!
__________________
OCT 2008 OTOTM
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
