| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here. |
Thread Tools | Display Modes |
#1 |
Year: 1988
Make: ford
Model: ranger
Engine: 2.0
Class: 2wd off road
Rep Power: 7 ![]() ![]() iTrader: (0)
Hi all. I'm looking for individual clutch friction discs for my trac lock. I have it out right now and will be installing a carbon disc rebuild kit. I figured I would try stacking them using the alternating method, though, which requires one extra friction. Does anyone know where I can buy individual carbon friction discs, or any individual friction discs for that matter? I posted this in the axle section, but figured there may be a better chance of someone happening across it here that may be able to help me. This axle is going back in the truck this weekend, and I would love to be able to use all new frictions. I will reuse two old ones if I need to, but I'm not buying two kits right now at $100 a pop. Thanks for reading and for any help you all can give.
__________________
Autofab bent beams, 31x10.5 15s, 8.8 w/ 5.13s, 2.0 w/ Lunati cam, portwork, 350 Holley, header, Expo leafs, long shackles, F150 springs and 10" front shocks in the works |
Tweet
#2 | ||
June 2011 OTOTM Winner
Year: 2007
Make: Ford
Model: Ranger FX4 Level II
Engine: 4.0
Class: 4x4
Used For: stealing candy from babies, and sometimes driving to work
Rep Power: 56 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
iirc, stock order is fccfccf
if you take your stockers and flip the c's so that the surfaces that are facing eachother are outwards, and put it back in, it brings it back almost to new trac-loc type deal... if you put new ones in and want a more firm trac loc, you install them in this order: cfcfcfc your kit should give you a total of 8 of one disk, and 6 of another... if it doesn't i'm fairly sure you're missing pieces...
__________________
Quote:
Quote:
Tweet
#3 |
RBV Technical Advisor
Year: 1987... sorta
Make: Ford
Model: Ranger Supercab
Engine: '93 4.0
Class: 4x4
Used For: Roadtrip Warrior
Rep Power: 47 ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (18)
If you look at the old discs you are taking out you will see that the "outboard friction" on either side, the one that rides against the differential carrier on either side only contacts the plate on the inboard side.
It rests against a spacer shim and the differential carrier on it's outboard side and never rotates agains the shim or carrier so the outboard side is "new" flip that one disc and reinstall it with the new frictions and you are good to go. AD
__________________
Gun Control - A theory espoused by some monumentally stupid people; who claim to believe, against all logic and common sense, that a violent predator who ignores the laws prohibiting them from robbing, raping, kidnapping, torturing and killing their fellow human beings will obey a law telling them that they cannot own a gun. |
Tweet
#4 |
December 2011 STOTM Winner
Year: 1997
Make: Ford
Model: Ranger
Engine: 5.0L HO, GT40 heads, GT40 intake, 65mm TB, 1.7rr, Tri-Y headers, dual 2.5" exhaust, Flowmaster muffl
Class: 2wd
Rep Power: 13 ![]() ![]() iTrader: (0)
FWIW, the alternating method kicks ass.
__________________
97 Supercab 5.0 H.O. EFI Tri-Y Headers T-5 DJM 5/8 Drop Cal-Vu mirrors, Shaved badges. Explorer interior 18X9/18X10 Bullitt wheels (275/40, 295/35) 5.0 link |
Tweet
#5 | |
Year: 1988
Make: ford
Model: ranger
Engine: 2.0
Class: 2wd off road
Quote:
__________________
Tweet
#6 |
Year: 1987... sorta
Make: Ford
Engine: '93 4.0
Class: 4x4
Do remember not to shim the unit too tight.
it is a common mistake to confuse "preload" with effectiveness The fact is that MOST of the pressure squeezing the clutches & Steels together is a function of a camming effect caused by the rounded gear faces that aid in creating a situation where force applied to the axle pinions by the spider pinions tends to "wedge" the axle pinions outwards against the clutch packs. So over-shimming makes the diff less effective than having it a little loose AD
__________________
Tweet
#7 |
Year: 1988
Make: ford
Model: ranger
Engine: 2.0
Class: 2wd off road
Interesting. I was somewhat aware that some sort of camming effect was at work, but I haven't taken the time to study one of these diffs closely. I know I put an S spring from an F-150 in a Mustang before, having heard that it was stiffer and would increase the effectiveness of the diff, but it made no difference that I could feel. I will be sure to get the preload right, and not overdo it. Thanks AllanD, I appreciate your advice on this. With any luck, I will have the truck out for a drive with this axle under it some time next week. I also got my pop to go half in on an extra carbon kit with me on the condition that I rebuild his trac lok when I get around to it, so I will be able to use all carbon clutches this time around.
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
