Go Back   The Ranger Station Forums > Engine & Transmission Forums > 4-bangers > 4-Cylinder (2001 & Newer)
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 03-01-2008, 08:27 PM   #1
MaxT
Year: 2003
Make: Ford
Model: Ranger
MaxT is on a distinguished road
Default Overheating I think
I own a 2003 2.3 Ranger. Runs great, only has 42000 miles. All gauges normal. I hooked up my scan gauge and my water temperature is at 260.
It has the yellow coolant and it is just below the minimum mark. The upper radiator hose and the heater hoses get hot which the service manual states means the thermostat is working. The lower radiator hose stays cool. With the 2.3 motors having the thermostat at the end of the lower radiator hose, I thought it would be a bad thermostat.
Any ideas or suggestions?
Max
MaxT is offline   Reply With Quote
Old 03-03-2008, 11:13 AM   #2
Simple_serf
Simple_serf's Avatar
Simple_serf is on a distinguished road
Default
Hmm...what are you using for a "scan guage"?
260 Is WAY too hot, in fact it's hot enough to make me wonder if the scan tool or a sensor is screwy.
__________________
98 Ranger XLT 2.5 lima RIP
04 Ranger XL 3.0 Vulcan RIP
Currently 04 XLT Supercab 4x4 4.0 5 spd 4.10 axles (Hell YEAH!)
Paul Johnson
KC2TOO
Simple_serf is offline   Reply With Quote
Old 03-03-2008, 11:25 AM   #3
MaxT
Year: 2003
Make: Ford
Model: Ranger
Default
It's name is "Scan Gauge". It plugs into the data port. I checked the temperature this AM on the scan gauge and it read 59 degrees at startup with an outside temperature of 49 degrees, then quickly rises.
It changes too fast for water temperature. I've read my service manual and found that the 2.3 has a cylinder head temperature sensor also. I'm thinking that this is the temperature the scan gauge is reading since it does rise so quickly. I can see the cylinder head temperature rising quickly with the engine running. Water temperature usually rises slower, especially when cold outside.
The truck does not boil over or show any other overheating signs other than the scan gauge reading of 260. It also stays between 250-260 and doesn't get any hotter like it is being regulated instead of something stuck. It's a mystery unless it is the cylinder head temp I'm reading.
Thanks for any insights.
Max
Old 03-03-2008, 06:25 PM   #4
Wicked_Sludge
Wicked_Sludge's Avatar
Year: 1993
Make: Ford
Model: Ranger, Flareside
Engine: 3-point-GO
Class: 4x4
Used For: Attracting the ladies
Wicked_Sludge will become famous soon enough
Send a message via MSN to Wicked_Sludge
Default
your computer will actually trip a CEL if anything screwy is happening with the engines temperature. if there are no codes (and the stock gauge shows OK), i wouldnt worry about it
__________________
As seen on the internets!
Quote:
Originally Posted by Hahnsb2 View Post
Dyno sheet or GTFO
Quote:
Originally Posted by Ranger Dave (B25) View Post
The call was for scantily-clad women. A Certificate of Boob Authenticity was NOT specified.
Quote:
Originally Posted by Grant Imahara
I'm not sure if we have the right stuff; I'm just hoping we don't have the wrong stuff.
__________________________________________________ ____________________________________
Wicked_Sludge is offline   Reply With Quote
Old 03-06-2008, 06:47 AM   #5
MaxT
Year: 2003
Make: Ford
Model: Ranger
Default
Good point, I think the gauge is reading cylinder head temperature instead of water temperaure because it runs great and does not overheat.
Old 03-07-2008, 12:50 PM   #6
addiman09
addiman09's Avatar
Year: 2003
Make: Ford Ranger
Model: 2.3 Liter 5spd
Engine: 2.3 Liter DOHC 5spd
Class: 2WD Street
Used For: everything
addiman09 is on a distinguished road
Default
its probably just wired in wrong, check your connections and then check where every wire runs, you could of mixed up the wires and tapped into the wrong one.
addiman09 is offline   Reply With Quote
Old 05-30-2008, 11:48 AM   #7
MaxT
Year: 2003
Make: Ford
Model: Ranger
Default Thanks
Thanks for the help and ideas. I put a gage in the upper radiator hose with a kit from Summit Racing and the temperature runs fine. I did not tap into any wires as I'm using a Scan Gauge II plugged into the computer port so it reads whatever is factory wired into that port.
Max
Old 01-07-2009, 11:32 PM   #8
Kaz
Year: 2004
Make: Ford
Model: Ranger
Kaz is on a distinguished road
Default
good to know, i was just about to replace my water pump and t-stat cause i though mine was running to hot, cause its doing the same thing as yours. thanks.
Kaz is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
