Go Back   The Ranger Station Forums > Engine & Transmission Forums > Transmissions
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 01-26-2012, 12:31 PM   #1
Kevery
Premium Member
Kevery's Avatar
Year: 1999/1978
Make: Ford
Model: Ranger F250
Engine: 4.0 V6
Class: 4x4
Used For: Everyday driver/wheeler
Kevery is on a distinguished road
Default C6 tranny on a 351
I'm wanting to put a c6 on my 351ci does anyone know if it will bolt up or do I need to get an adaptor or bell housing of a c4. the c6 is coming off of my 429ci.
Kevery is offline   Reply With Quote
Old 01-26-2012, 12:46 PM   #2
alwaysFlOoReD
Super Moderator
Year: '91, '85, '97
Make: ford
Model: ranger, b-II, f-150
Engine: 4.0,4.0,4.2
Class: 4x4 race, 4x4, 2wd work
Used For: 4x4 race, 4x4,2wd work
alwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to beholdalwaysFlOoReD is a splendid one to behold
Default
Sorry, won't fit. The c-6 has an integral bellhousing and you need one with a small-block pattern for 351 windsor and cleveland, not sure about 351M.
Richard
__________________
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
alwaysFlOoReD is offline   Reply With Quote
Old 01-26-2012, 12:58 PM   #3
Kevery
Premium Member
Kevery's Avatar
Year: 1999/1978
Make: Ford
Model: Ranger F250
Engine: 4.0 V6
Class: 4x4
Default
thanks, you think I could swap bell housings from my c4 maybe?
Old 01-26-2012, 01:00 PM   #4
alwaysFlOoReD
Super Moderator
Year: '91, '85, '97
Make: ford
Engine: 4.0,4.0,4.2
Default
Sorry, there are no [edit; removable] bellhousings on the c-6.
Richard
__________________
Old 01-26-2012, 01:08 PM   #5
Kevery
Premium Member
Kevery's Avatar
Year: 1999/1978
Make: Ford
Model: Ranger F250
Engine: 4.0 V6
Class: 4x4
Default
DAMN IT! thanks though. I guess I'll just put the 429 is my cougar as well, darn.
Old 01-26-2012, 01:12 PM   #6
alwaysFlOoReD
Super Moderator
Year: '91, '85, '97
Make: ford
Engine: 4.0,4.0,4.2
Default
I've been thinking about a similar build. I've heard that the 351m/400 bolt pattern is the same as the 429/460. I have not confirmed this.
Richard
__________________
Old 01-26-2012, 01:31 PM   #7
alwaysFlOoReD
Super Moderator
Year: '91, '85, '97
Make: ford
Engine: 4.0,4.0,4.2
Default
Copied from this site;
http://www.fordbroncoexperts.com/adv...trans-swap.jsp
Ford C4 & AOD (5 1/8" center to center top two holes) 289, 302, 351c, 351W
Ford C6 (6" center to center top two holes) 332, 352, 360, 390, 406, 427, 428
Ford C6 (7 3/4" center to center top two holes) 429, 460, 351M, 400M
Richard
__________________
Old 01-31-2012, 01:32 AM   #8
projectnitemare
projectnitemare's Avatar
Year: 1988
Make: Ford
Model: Ranger XLT
Engine: 396W
Class: 4x4 Extreme
projectnitemare will become famous soon enoughprojectnitemare will become famous soon enough
Default
If you are dead balls set on using that particular transmission buy a bolt on bellhousing for a C6 in a small block pattern. You have the cut the cast bellhousing off the transmission and bolt the now one on through the pump. You'll shell out about $350 for one and most are SFI approved scatter shields. Aside from that you need a different transmission.
Matt
__________________
88 Ranger XLT 4x4, no drivetrain, no frame, nothing....new stroker, frame and drivetrain in the works
projectnitemare is offline   Reply With Quote
Old 01-31-2012, 04:38 AM   #9
alwaysFlOoReD
Super Moderator
Year: '91, '85, '97
Make: ford
Engine: 4.0,4.0,4.2
Default
Quote:
Originally Posted by projectnitemare View Post
buy a bolt on bellhousing for a C6 in a small block pattern. You have to cut the cast bellhousing off the transmission and bolt the new one on through the pump.
Matt
That's good info to know. Do you have a link?
Richard
__________________
Old 01-31-2012, 10:05 AM   #10
projectnitemare
Year: 1988
Make: Ford
Model: Ranger XLT
Engine: 396W
Class: 4x4 Extreme
Default
I may have to retract that statement for the C6. It's made for just about everything except the C6. http://www.campbellenterprises.com/a...ellhousing.htm Maybe call JW and see if they know of or maybe make one. I'm very familiar with doing this on tubro 400, see a lot of them broken in race cars. I could have sworn at one time made the same for a C6 as well.
Matt
__________________
Old 02-16-2012, 09:22 PM   #11
fordmanms
Year: 1999
Make: Ford
Model: Ranger
Engine: 3.0 Flex (unfortunately)
Class: 4x4
Used For: Everything
fordmanms is on a distinguished road
Default C6 tranny on 351
If you have a small block C6, it will fit the 351c/w. It will also fit 302/289's as well as other small blocks. If the tranny came from a 351w, it will only fit big blocks such as 400, 429, 460. I beleive the 390 also uses the big block housing. As the C6 does not have a removable bellhousing, you will not be able to swap it from a c4. Small Block C6's are becoming less common to find as they are a popular trans, but there are other alternatives out there that are just as good.
fordmanms is offline   Reply With Quote
Old 06-16-2012, 12:43 PM   #12
sirgrizz420
Year: 1986
Make: ford
Model: rangers
sirgrizz420 is on a distinguished road
Default
ha thats funny i just finished pulling a c6 out of my 79 bronco with a 351m and a np205 t case i"m gonna build the 351m to a 400 and stuff it in my explorer with the full width axles under it.
sirgrizz420 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
