| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 1986
Make: Ford
Model: Bronco II
Engine: 2.9L
Class: 4x4
Used For: camping, hunting, fishing, 4 wheelin
Rep Power: 0 ![]() iTrader: (0)
Sorry if this is in another thread somewhere but ive been searching for an hour and havent found anything so here goes.
I have a 94 Mazda B4000 LE 4x4. a couple of weeks ago i had a severe coolant leak from my lower intake manifold gasket. I did a full replacement with the new 2-piece felpro gaskets. during the replacement i found a cracked fuel injector,after replacing the 1 injector as well as the fuel rail and upper intake gasket, It was running rough so i replaced the rest of the injectors and new upper gaskets(again). the truck seemed to be running fine yesterday, although it would jerk softly forward once i came to a stop and when i got home from work it was leaking coolant and oil from somewhere on the rear of the engine and down the trans. Not a crazy pouring leak but a steady drip. I fired it up today and after it warmed up it leaked a little oil but no coolant. I also think i hear a knock or something from the bottom of the engine/trans bell housing area. I am not sure what to do next, if anyone from sacramento knows these 4.0s and wants to make some cash i could use some help.... |
Tweet
#2 |
Year: 1986
Make: Ford
Model: Bronco II
Engine: 2.9L
Class: 4x4
seems to leak from the seal between the engine and trans but its hard to tell
Any ideas or methods for narrowing my search would be helpful Last edited by Cannisseur; 01-24-2012 at 05:55 PM. |
Tweet
#3 |
Year: 1997
Make: Ford
Model: Ranger
Engine: 4.0L V6
Class: 4x4 TTB
Used For: Everything
Rep Power: 4 ![]() iTrader: (0)
Maybe the rear main seal? I put one in my 97 Ranger when I did my clutch job at 230k, it was about to let go. It's the seal that seals the end of the crank shaft. If it's dripping down from the back of the engine between the transmission bellhousing that could very well be it
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
