| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 1993
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Used For: DD
Rep Power: 10 ![]() ![]() iTrader: (0)
ok. i dont know if this is normal or not. when i park my truck i usually just leave it in first. but on a hill if i want to let it warm up or anything i obviously need to use the parking brake. when i push it it goes almost all the way to the floor and will hold the truck on a small hill, but if i release it and pump it again it gets firm a lot quicker and holds the truck a lot better. is this normal or bad or is something broken?
__________________
93 ranger, 4.0L, ex cab, standard, 4x4, 2" coils, 15x8 AR Baja, 33x10.5" bfg at, cab lights Build Thread ........to be modified........ -Ryan- |
Tweet
#2 |
Year: 1993
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Used For: DD
Any ideas
__________________
Tweet
#3 |
Super Moderator
Year: '91, '85, '97
Make: ford
Model: ranger, b-II, f-150
Engine: 4.0,4.0,4.2
Class: 4x4 race, 4x4, 2wd work
Used For: 4x4 race, 4x4,2wd work
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
I would guess that the cables are not moving freely inside the casing. Get a friend to help by stepping on the parking brake while you look for any signs of seizing.
Good luck, Richard
__________________
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein |
Tweet
#4 |
RBV Technical Advisor
Year: 1987... sorta
Make: Ford
Model: Ranger Supercab
Engine: '93 4.0
Class: 4x4
Used For: Roadtrip Warrior
Rep Power: 47 ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (18)
This is a weirdness that is understandable if you know how things really work.
The rear drum brakes on rangers are what are known as "servo actuated brakes" Yes, the rear hydraulic cylinders move the brakes into engagement, but the primary braking force comes from a rotational "Wedging effect" Rolling forward the front shoe contacts the drum and the rotational drag drives the show downwards away from the single anchor point at the top. This wedges the longer rear show firmly into the brake drum and that is what provides most of the actual stopping force. Because of the difference in spring rates and the longer show being in back the brakes are not as effective when backing up. The parking brake is mechanically actuated but the principle remains the same. The fact is that after the brakes are applied parts inside move, in some cases a suprising amount, and after they've moved they often move in a way that offers you more mechanical advantage so you can get another click or so and get better holding as a result. AD
__________________
Gun Control - A theory espoused by some monumentally stupid people; who claim to believe, against all logic and common sense, that a violent predator who ignores the laws prohibiting them from robbing, raping, kidnapping, torturing and killing their fellow human beings will obey a law telling them that they cannot own a gun. |
Tweet
#5 |
Super Moderator
Year: '91, '85, '97
Make: ford
Engine: 4.0,4.0,4.2
Ahhh, that makes sense. Thanks for explaining.
Richard
__________________
Tweet
#6 | |
Year: 2008
Make: Ford
Model: F-150 XL
Engine: 4.2L/ 11,370Miles
Class: 2wd
Used For: Being a Big Girl!
Rep Power: 7 ![]() ![]() ![]() ![]() ![]() iTrader: (0)
The 93-98 rangers have an "in-service-able parking break" gotta replace the cables. Mine rolls with the parking break on. you can get a new cable at o'reillys or napa.
What it is, there's a self adjusting thingy under there and it'll stretch to where it wont self adjust, so you gotta get a new cable. I figured that out, and then confirmed that was the problem with Lima Bean. its the front cable that's probably loose, it's just like a 2'-3'ft cable like on a bicycle.
__________________
Quote:
Tweet
#7 | |
Year: 1988
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: Trail Slut
Rep Power: 19 ![]() ![]() ![]() ![]() iTrader: (1)
Quote:
If he can apply and release the parking brake the cable is not the problem, and there is nothing in the cable system for the parking brake that will stretch and wear out. That would be a dumb idea on the engineers part as the brake could be applied and that part stretch out and allow the vehicle to roll away
__________________
HE WHO DIES WITH THE MOST TOYS WINS |
Tweet
#8 | ||
Year: 2008
Make: Ford
Model: F-150 XL
Class: 2wd
Quote:
I can apply and release my parking break and it'll hold, unless it's on a slope or a slick spot. And it says in my book that I can't service the parking break.
__________________
Quote:
Tweet
#9 | |
Year: 1988
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Quote:
You posted something that made no absolute sense at all. You stated that there was/is a part in your parking brake system that stretched and gave you no hold from your parking brake. There is nothing from the parking brake pedal to the drums that can stretch. The cables will stretch and then break when enough pressure is applied. If they do break it is because of rust and not stretching. The should be a part by your front spring hanger on the rear drivers side that has an adjustment and connects the rear cables to the front, that won't stretch either. Like Allan said the only part of your rear brakes that actually hold anything is the front shoe. If the rear brake shoes are out of adjustment then yeah the pedal may be pumped to hold better.
__________________
Tweet
#10 | |
Year: 1988
Make: Ford
Model: Ranger SXY
Class: 4X4
Used For: Doing dirty deed's dirt cheap.
Rep Power: 38 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
Quote:
__________________
88 Ranger http://www.cardomain.com/ride/2459246 "You have come to take our evil black guns? heh heh be right with ya there mister."
Tweet
#11 | |
Year: 1988
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Quote:
__________________
Tweet
#12 |
Year: 1988
Make: Ford
Model: Ranger SXY
Class: 4X4
Maby so but dont ditch the deal man. Explain your side and maby educate me, i was not dissing you. Thats why we are both here so state your side and lets work together as a team , got it!
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
