- Dec 11, 2011
I just did a gravity flush on my '98 Ranger. The clutch was working just fine up to that point but the pedal wasn't very smooth going in and out. Never did I let the fluid drop more than 1/2 reservoir before topping it off. I also pulled the master cylinder through the firewall and tilted it so that the pushrod was lower than the hose connections on the master. Bled about a pint of fluid through the system and closed it up tight. No air bubbles in the hose off the slave nipple.
The pedal feel improved immensely - smoother and "lighter". BUT... after a day of driving it or so, when I put it in reverse, clutch in, the car started creeping as though the clutch was partially engaged. Yanked it out of reverse, pumped the clutch a couple times and all was well again.
Is this more of a symptom of air that somehow got past my bleed/flush technique or a slave cylinder that coincidentally decided to start crapping out? There are no leaks at the slave cylinder side, the reservoir stays full, and I did look inside the bellhousing via that rubber-covered "port" - dry as a bone.
Thoughts? Bleed yet again? Is there an actual way to see/check if a slave is giving up the ghost?
If I do have to replace the slave, can the tranny be pulled back just far enough to remove/replace it or does it need to be entirely dropped.
Thx,
Al
Thx,
Al
