Go Back   The Ranger Station Forums > Engine & Transmission Forums > V6 Forums > 3.0 Liter Forum
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 11-17-2011, 07:55 AM   #1
rangers92
Junior Member
rangers92's Avatar
Year: 2003
Make: ranger
Model: basic
Engine: 3.0 v6
Class: 2wd street/offroad
Used For: daily driver mild offroading
rangers92 is on a distinguished road
Question 03 3.0 shake at idel
my 3.0 has some noticable shake at idel. it also shakes a little more when cold or the a/c is on. i have changed the plugs wires the batery the serp belt the fuel filter i run fuel injector cleaner regularly. an i use 89 gas. the shake calmed down some when i changed the fuel filter. however i am getting great power friom my motor i am getting no missifres no over heating no knock or tick and it revs good. very smoth as well. i have been told all rangers shake specialy the 3.0 something about the resoneces of the unibody and motor?? just looking for insight. also in the summer im rebuliding the motor. all new water pump alt power sterring pump starter and ac compressor. along wiht maybe head gaskets and pistons. motor has 106k on it and starts fine. also while it shakes at idel the rpms stay dead still and constant and only increase a little when the a/c is on. just looking for some insite not worried or anything.
rangers92 is offline   Reply With Quote
Old 11-17-2011, 09:38 AM   #2
dancron
dancron's Avatar
Year: 2005
Make: Ford
Model: Ranger
Engine: 3.0 V6
Class: 2WD
Used For: picking up beer
dancron is on a distinguished road
Default
Ever try cleaning the back of your throttle body, intake air control valve, and your maf sensor? It smoothed out my idle nice when I did it.
__________________
click!
dancron is offline   Reply With Quote
Old 11-17-2011, 01:11 PM   #3
rangers92
Junior Member
rangers92's Avatar
Year: 2003
Make: ranger
Model: basic
Engine: 3.0 v6
Default
yep i did all of those i even bought a new idel air vavle but when i pt the new one on it seemed to idel worse i i cleaned the stock one with break cleaner as told ot and put it back on and it smothed out some. clean my tb and maf sensor to. i mean the shake inst bad it could proably just be me being picky becuas i need every thing perfect.
Old 11-17-2011, 07:28 PM   #4
dancron
dancron's Avatar
Year: 2005
Make: Ford
Model: Ranger
Engine: 3.0 V6
Class: 2WD
Default
maybe a worn motor mount?
__________________
click!
Old 11-22-2011, 07:17 AM   #5
rangers92
Junior Member
rangers92's Avatar
Year: 2003
Make: ranger
Model: basic
Engine: 3.0 v6
Default
more input?
Old 11-22-2011, 10:14 AM   #6
Rearanger
Year: 2003
Make: Ford
Model: Ranger 3.0L
Rearanger is on a distinguished road
Default
Quote:
What's your idle rpm? I will say the 3.0 is not a smooth idler, at least to other V6s I have driven. You might also check your engine mounts. Also check for vac leaks especially in the PCV system.
But it's your money.
__________________
2003 3.0L Long Box, 5spd Manual, 2wd, 3.73 LS,
P235/70R-16, Synthetic fluids, Dual by-pass filter system, 60k
Rearanger is offline   Reply With Quote
Old 11-22-2011, 10:45 AM   #7
triumphrider-1
triumphrider-1's Avatar
Year: 1999
Make: Ford
Model: Ranger XLT
Engine: 3.0L
Class: 4x4
Used For: Pondering
triumphrider-1 is a jewel in the roughtriumphrider-1 is a jewel in the roughtriumphrider-1 is a jewel in the roughtriumphrider-1 is a jewel in the rough
Default
Does it have the original belt tensioner?
__________________
1999 Ranger XLT 4x4
Supercab four door
3.0L flex fuel, automatic transmission
"Minds are like parachutes, they only function when open" - Anna Pavlova
triumphrider-1 is offline   Reply With Quote
Old 11-25-2011, 10:48 PM   #8
03 EdGe 30
Year: 2003
Make: Ford
Model: Ranger
03 EdGe 30 is on a distinguished road
Default
My 03 has the same issue.....ive went as far as to change the plenum gaskets trying to weed vacuum leaks out....still not solution....it drives me nuts!!! it idles like a dang diesel but drives smooth and enjoyable.Ive also had several people tell me for some reason that the 3.0 is a rough idler...i wish it idled like the 3.0 in my escape lol or had the power the escape does DOHC FTW.....
03 EdGe 30 is offline   Reply With Quote
Old 11-26-2011, 05:44 AM   #9
Rearanger
Year: 2003
Make: Ford
Model: Ranger 3.0L
Default
Quote:
Yea, my I4 Camry idles dead smooth, but it has a balance shaft system to even out the lumps. I'm wondering if this is just poor QC and or design in the balance of the crankshaft. I've learned to live with it.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
