Go Back   The Ranger Station Forums > Engine & Transmission Forums > 4WD Systems
Notices
4WD Systems Transfer Cases & Locking Hubs. Forum sponsored by The Shiftster
Post New Thread Reply
Thread Tools Display Modes
Old 11-07-2011, 07:44 PM   #1
Hagan
Hagan's Avatar
Year: 1986
Make: Ford
Model: Ranger
Engine: 2.3
Class: 4x4
Used For: causing headaches
Hagan will become famous soon enough
Default Installing Dana 35 without carrier?
I just removed my dana 28 and beams out of the my truck. I am wanting to install the Dana 35 but I am waiting on a set of gears. Can I install the beams and hubs without the carrier and axle shafts and drive?
Its kind of a stupid rookie question. I didn't remove the dana 28 carrier from the beam when I removed it. Thanks for the help!
__________________
1986 Ranger 2.3t -Turbo'd/SAS'd - FW HP D44, FW 8.8, 5.13's, Spartan lockers, 1 ton steering, EB 4.5" WildHorses Springs, Chevy 63's, Extended radius arms, 35" Mickey Thompson Baja Claw TTC's...
Hagan is offline   Reply With Quote
Old 11-07-2011, 08:29 PM   #2
Hahnsb2
Hahnsb2's Avatar
Year: 88-95
Make: Ford-Dodge
Model: BII-Dakota
Engine: 4.0-5.2 Turbo
Class: Real 4WD, 3WD.
Used For: Going where I point it-Going fast
Hahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really nice
Send a message via AIM to Hahnsb2
Default
It's called a pig or 3rd member and yes.
__________________
88 Bronco II, 4.0L, M5OD, 4.56s, Aussie Locked 8.8/D35, 1354M, 34" LTBs
95 Dakota CC, 5.2, 5 Spd, 2WD,Turbo, Megasquirt, 3.55s, Locked
Hahnsb2 is offline   Reply With Quote
Old 11-07-2011, 10:11 PM   #3
scotts90ranger
scotts90ranger's Avatar
Year: 1990
Make: Ford
Model: Ranger
Engine: 2.3 Turbo
Class: 4x4
Used For: holding down the driveway
scotts90ranger has a spectacular aura aboutscotts90ranger has a spectacular aura aboutscotts90ranger has a spectacular aura about
Default
stuff a rag in the back of the spindles and you should be ok for a while, speaking from experience as I've pulled my pig lately, it's kind of a pain to get out but with my suspension setup right now my radius arm bushings are nearly maxxed out at ride height (I'll be working on that soon hopefully). I had both spindles removed, drivers side pivot bolt removed, did I mention it was raining?
__________________
converted to 4x4, turbo'd the 2.3, 6" lift with 35's and 5.13 gears!
Send e-mail instead of PM, box full...
scotts90ranger is offline   Reply With Quote
Old 11-08-2011, 12:06 AM   #4
Hagan
Hagan's Avatar
Year: 1986
Make: Ford
Model: Ranger
Engine: 2.3
Class: 4x4
Default
Oh sorry about the terminology.
I guess this is going to sound stupid but when I take the d35 out I have to pull one axle shaft out, then take the other one out using the c-clip (I think?). But what about the axle shafts? Can I just leave them there? It should be fine if the hubs aren't engaged because it isn't spinning right?
__________________
Old 11-08-2011, 01:44 AM   #5
The Mud Addict
The Mud Addict's Avatar
Year: '85
Make: Ford
Model: Bronco II
Engine: 2.hate LOL!
Class: 4x4
Used For: Teasing Jeeps!
The Mud Addict will become famous soon enough
Default
Remove the axle shaft and stuff rags into hole, or duct tape the holes closed
The Mud Addict is offline   Reply With Quote
Old 11-08-2011, 06:18 AM   #6
88_Eddie
Motorboater (.Y.)
Chopper Challenge Champion
88_Eddie's Avatar
Year: 1988, 2000
Make: Ford
Model: Bronco II (Eddie Bauer), Explorer
Engine: 2.9L, 4.0L
Class: 4x4, 2WD
Used For: Annoying the old ball and chain.
88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute
Default
you'll have to pull out the driver side axle shaft to get the pig out. the middle axleshaft is the one with a c-clip on it. if you're taking out the pig, i'd just leave it in until you're ready to do the gear swap or whatever you're doing. keep it all together. if you arent planning on driving the vehicle, i'd just leave the pass side axleshaft in. if you are gonna drive it, i 'd take it out to keep it from flopping around.
__________________
BUILD THREAD<<<<<<<<<<<<<
The Tikki Torch Build Thread
1988 Bronco II 4x4 2.9, FM146, 1350M, Disc 8.8, D30 SAS, 3.73's, 31's (for now)
2000 Explorer 4.0 2WD DD
Everything I need to know about Islam, I learned on 9/11.
The hardest part about a zombie apocalypse will be pretending I'm not excited.
Quote:
Originally Posted by Wedding Crashers
What'd you do with them? Motorboat? You play the motorboat? You motorboatin son of a bitch! You old sailor you!
Quote:
Originally Posted by jammert609@yahoo.com View Post
I am being told by family an friends my truck is a piece of shit
88_Eddie is offline   Reply With Quote
Old 11-08-2011, 09:38 AM   #7
Hagan
Hagan's Avatar
Year: 1986
Make: Ford
Model: Ranger
Engine: 2.3
Class: 4x4
Default
I think I'll just leave it in until I get the gears! Thanks guys!
__________________
Old 11-15-2011, 02:10 PM   #8
legoms013
legoms013's Avatar
Year: 1996
Make: Ford Ranger
Model: XLT 4x4
Engine: 4.0L V6
Class: Serious Bolt On 4x4
Used For: DD, Rearranging the Landscape
legoms013 is a jewel in the roughlegoms013 is a jewel in the roughlegoms013 is a jewel in the roughlegoms013 is a jewel in the rough
Send a message via AIM to legoms013
Default
You have to remove both shafts completely to get the 3rd out.
When I did mine I put the shafts back in (but not the inner passenger side stubbie that goes in the diff.
Then I used a bungie cord and duct tape to secure the shafts so they don't flop around. I did this so no dirt or other crap would get in the hubs and such from the back side of the spindle (you could take the shafts out and stuff a rag in there but if it is raining when you drive good luck keeping the stuff out...).
Have you eliminated the c-clip on the passenger-side axle shaft that goes into the pig?
Do it now if you haven't. Makes removal of the shafts easier in the future...
__________________
'00 Ranger on '96 TTB frame/drivetrain
legoms013 is offline   Reply With Quote
Old 11-16-2011, 12:15 AM   #9
Hagan
Hagan's Avatar
Year: 1986
Make: Ford
Model: Ranger
Engine: 2.3
Class: 4x4
Default
No i haven't yet. I'm working on the lift/radius arms right now...just getting everything fabbed together. I need to regear the front and add a locker.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
