Go Back   The Ranger Station Forums > Truck Discussions > General Discussions
Notices
General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here.
Post New Thread Reply
Thread Tools Display Modes
Old 11-06-2011, 09:07 AM   #1
Sultan
Year: 1986
Make: Ford
Model: Bronco 2 EB
Engine: 2.9
Class: 4x4
Used For: Winter DD
Sultan is on a distinguished road
Default My wife's dumb husband!
Yesterday my wife's dumb husband checked the coolant level on his 2.9 and drove to a pull a part. The B2 drove great all the way there but after he left the B2 would lose power going up hills. It ran great when it was level. So he thought maybe the gas gauge was wrong and he needed gas. While filling up I looked under the hood and then saw the radiator cap missing. He bought some more coolant and filled it up. The B2 drove perfectly after that.
So the question is why did it loose power when the radiator cap was off?
Sultan is offline   Reply With Quote
Old 11-06-2011, 09:12 AM   #2
superds
Premium Member
superds's Avatar
Year: 90 99 84 85
Make: Ford
Model: Ranger Explorer BII
Engine: 2.9/5.0/2.8/5.0
Class: 4x4
Used For: Activities that a Focus or an F150 can't do
superds is a splendid one to beholdsuperds is a splendid one to beholdsuperds is a splendid one to beholdsuperds is a splendid one to beholdsuperds is a splendid one to beholdsuperds is a splendid one to beholdsuperds is a splendid one to behold
Default
The nut behind the wheel was loose?
__________________
Quote:
Originally Posted by Guy on another forum
...I only like jeeps that hardly have anything original left...
Quote:
Originally Posted by pillen140 View Post
machine guns.... every truck needs machine guns.
superds is offline   Reply With Quote
Old 11-06-2011, 10:33 AM   #3
straycat
Premium Member
straycat's Avatar
Year: 99, 02 and 06
Make: Ford /Jeeps/Etc
Model: 99 Ranger 4.0L 2wd 33x12.5 KO tires. Grand Cherokee 4x4 4.0L Wrangler X 5.7 Hemi 87 Samurai 4x4
Used For: DD and trail rides
straycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud ofstraycat has much to be proud of
Default
Would not have lost power form that. I drove my tractor on our property for years with no coolant cap and it never lost power. Some other issue I suppose. I know pwople who drove for miles without a radiator cap to go buy a new one and they never lost power.......
__________________
Straycat
99 Ranger XLT 4 door Supercab lifted 2wd
33x12.5x15 KO's on 15x8 AR polished rims
Spare 33 KO mounted flat in bed/custom bed extender
straycat is offline   Reply With Quote
Old 11-06-2011, 10:38 AM   #4
straycat
Premium Member
straycat's Avatar
Year: 99, 02 and 06
Default
OOOps....you did not mention about overheating. You said he thought it was a low gas issue. The cap will keep the coolant from spilling out. If hte temp gauge shoots way up then you can damage the motor of course.
__________________
Straycat
Old 11-06-2011, 11:33 AM   #5
Sultan
Year: 1986
Make: Ford
Model: Bronco 2 EB
Engine: 2.9
Class: 4x4
Used For: Winter DD
Default
It wasn't gas. I watched the temp gauge the whole way which was maybe five to ten miles and it never got warm.
Still stumped....
Old 11-06-2011, 12:02 PM   #6
Captain Ledd
Captain Ledd's Avatar
Year: 1984, 1997
Make: Ford
Model: Rangers
Engine: 302, 2.3
Used For: Literally everything.
Captain Ledd is a jewel in the roughCaptain Ledd is a jewel in the roughCaptain Ledd is a jewel in the roughCaptain Ledd is a jewel in the rough
Default
Quote:
Still stumped....
Depends if the temperature sensor was in the coolant, let alone in the hot spot at the upper cylinders and cylinder heads where there was no coolant.
The temperature gauge is merely an average temperature at that spot, and it will vary depending on it's location on the engine. It only measures the coolant temp, not the engine temp.
__________________
"The difference between genius and stupidity is that genius has its limits" - Albert Einstein
Never give up: http://www.youtube.com/watch?v=Y6hz_s2XIAU
1984 Ranger - std cab, long bed: The Deathtrap
302; T18; D20 Tcase; 6' lift; 4.56 gears; 33' pro comp MT's; Aussie locked rear
1997 Ranger - std cab, short bed: Red Ranger
2.3L; M50D R1; 2wd; 4.56 gears; Explorer 8.8; ARB locker; 235/75R15 AT's
(soon to undergo 4x4 conversion )
Captain Ledd is offline   Reply With Quote
Old 11-06-2011, 01:15 PM   #7
Sultan
Year: 1986
Make: Ford
Model: Bronco 2 EB
Engine: 2.9
Class: 4x4
Used For: Winter DD
Default
So when I was going uphill the coolant would drain away from the sensor and then the sensor would tell the computer that is was overheating and kill the power? Is that what you are suggesting?
Old 11-06-2011, 02:13 PM   #8
jhammel85
Capt. Slow
jhammel85's Avatar
Year: 1987
Make: Ford
Model: Ranger
Engine: 2.9 V6
Class: 4X4
Used For: Daily Driver / Off Road from time to time
jhammel85 has a spectacular aura aboutjhammel85 has a spectacular aura aboutjhammel85 has a spectacular aura about
Default
I did that once with the oil cap. I could not figure out why it wouldn't idle....lol
Make sure you get all the air out of it. Shutting it off without the cap on sucks in air.
__________________
-1987 Ranger 4x4-
3" Body Lift, 2.9 V6, A4LD auto, Manual Hubs, Dynomax Super Turbo Exhaust, 30x9.5R15 A/T, 15x8 Cragar Soft 8 Wheels
jhammel85 is offline   Reply With Quote
Old 11-06-2011, 02:14 PM   #9
Captain Ledd
Year: 1984, 1997
Make: Ford
Model: Rangers
Engine: 302, 2.3
Default
Nope, the extra heat in the engine kills the power, and going up hills it was particularly noticeable.
Without any coolant in an area, and under load, those parts (upper cylinders and cylinder heads) will heat up very hot extremely quick. And if it's not pumping coolant past the sensor, it'll never know.
__________________
Old 11-06-2011, 07:17 PM   #10
doorgunner
Lab Rat for V.A. hospital
doorgunner's Avatar
Year: 1989/1936
Make: Ford
Model: Ranger XLT
Engine: V-8...Carbed/fo-barrel
Class: 2WD Street
Used For: FUN on a daily basis!
doorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond repute
Default
I read an article on cylinderhead heat last night....seems that a 40 degree temp increase in cylinder heads causes a 20 H.P. loss.....now that's noticeable!
__________________
*******My Stupied Build Thred! http://www.therangerstation.com/foru...ad.php?t=30561*******
*****All the people who's freedom of speech I fought to defend are now telling me to shut up*****
**********The Congress that gave me a Machine Gun to kill as many enemy as possible now wants my Winchester Model 1894 because I have PTSD!**********
doorgunner is offline   Reply With Quote
Old 11-07-2011, 12:59 PM   #11
tbirdsps
tbirdsps's Avatar
Year: 1992
Make: Ford
Model: RANGER XLT
tbirdsps has a spectacular aura abouttbirdsps has a spectacular aura abouttbirdsps has a spectacular aura about
Default
Nothing seems strange to me anymore. A few years ago I left the oil fill cap off and the engine pinged. I opened the hood, slapped my head and put the cap back on and it has never pinged since.
tbirdsps is offline   Reply With Quote
Old 11-07-2011, 06:44 PM   #12
Ranger Sport Honduras
Solid Axled yo!
Ranger Sport Honduras's Avatar
Year: 1999
Make: Ford
Model: Ranger XLT Sport
Engine: 2.5 (5spd)
Class: SAS 4X4
Used For: Everything and more...
Ranger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond reputeRanger Sport Honduras has a reputation beyond repute
Send a message via MSN to Ranger Sport Honduras
Default
Just dont do it again, ok?
__________________
click for:
Ranger Sport Honduras Level II (My D30 SAS 4WD)
Mini Power Stroke (My bro's Crew Cab 4WD Ranger--Slow build)
Ranger Militia
Cardomain(All the trucks)
Ranger Sport Honduras is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
