Go Back   The Ranger Station Forums > Engine & Transmission Forums > 4-bangers > 4-Cylinder (2000 & Older)
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 10-27-2011, 05:14 PM   #1
dangerranger78
Year: 1986/2000
Make: ford
Model: ranger
Engine: 2.3/2.5
Class: 4x4/2WD
Used For: the 86 might be a daily driver someday the 00 is a daily driver
dangerranger78 is on a distinguished road
Default 2.3 throttle body ???
hey guys i have an 86 2.3 4x4 and im starting to try to get a little more oomph out of it. i plan on an air intake pretty soon but on the 86 the IAC is located on the air box. Can i swap the trottle body off a newer model with the IAC on the TB and not on the air box?
dangerranger78 is offline   Reply With Quote
Old 10-30-2011, 09:23 PM   #2
dangerranger78
Year: 1986/2000
Make: ford
Model: ranger
Engine: 2.3/2.5
Class: 4x4/2WD
Default
ok guess ill go to the junk yard and do some measuring and plug checking.
Old 10-30-2011, 10:44 PM   #3
scotts90ranger
scotts90ranger's Avatar
Year: 1990
Make: Ford
Model: Ranger
Engine: 2.3 Turbo
Class: 4x4
Used For: holding down the driveway
scotts90ranger has a spectacular aura aboutscotts90ranger has a spectacular aura aboutscotts90ranger has a spectacular aura about
Default
I haven't seen one with the IAC on the air box, but I imagine it shouldn't be a problem assuming it's the same actuator
__________________
converted to 4x4, turbo'd the 2.3, 6" lift with 35's and 5.13 gears!
Send e-mail instead of PM, box full...
scotts90ranger is offline   Reply With Quote
Old 10-31-2011, 07:39 PM   #4
dangerranger78
Year: 1986/2000
Make: ford
Model: ranger
Engine: 2.3/2.5
Class: 4x4/2WD
Default
thanks i think its a mid 80's thing. i ve seen 88-90ish models on the TB. ill look around the junkyard and narrow it down a little.
Old 10-31-2011, 08:55 PM   #5
88ranger89camaro
88ranger89camaro's Avatar
Year: 1988
Make: Ford
Model: Ranger XLT
Engine: 2.3
Class: 2WD
Used For: Get to Work/Tow Rig
88ranger89camaro is on a distinguished road
Default
88 is going to have it on the box too ....... you can port your box to get more air in it and put in a K&N would give you good air flow with minimal mods, i used a dremel to cut another air inlet below the filter so it still sucks filtered air, just an extra hole to get more air from
88ranger89camaro is offline   Reply With Quote
Old 11-02-2011, 11:57 AM   #6
dangerranger78
Year: 1986/2000
Make: ford
Model: ranger
Engine: 2.3/2.5
Class: 4x4/2WD
Default
thats a pretty good idea. did the throttle cable mod. made a huge drivability improvement. now looking for a little power up grade. nothing huge but my 2.5 is worlds ahead of my 86' 2.3. just needs a little help.
Old 11-02-2011, 12:13 PM   #7
88ranger89camaro
Year: 1988
Make: Ford
Model: Ranger XLT
Engine: 2.3
Class: 2WD
Default
What's the throttle cable mod I haven't seen that one on here
Old 11-02-2011, 01:41 PM   #8
Heavyfire14
Heavyfire14's Avatar
Year: 1997
Make: FORD
Model: F150
Engine: 4.2l manual
Class: 2WD Off-Road
Used For: DD/Fun
Heavyfire14 is a jewel in the roughHeavyfire14 is a jewel in the roughHeavyfire14 is a jewel in the roughHeavyfire14 is a jewel in the rough
Default
^^ zip ties on the throttle cable up by the pedal
__________________
Quote:
Originally Posted by nine-teen91stxranger View Post
duct tape and crazy glue. that holds anything together... duhh
Quote:
Originally Posted by 88_Eddie View Post
yeah it does. my wife and i have a 15th century battle axe suspended over our bed with it
2002 mazda b2300 ext. Cab 2.3l 5 speed
Build Thread
Heavyfire14 is offline   Reply With Quote
Old 11-02-2011, 02:24 PM   #9
chilsam
chilsam's Avatar
Year: 91 branger
Make: ford
Model: hybryd swb ranger bod fs bronco chassis
Engine: 300 six
Class: both 4x4
Used For: FUN!
chilsam is on a distinguished road
Default Yes!
I swapped a 2.3 from a 87 mustang into my son's 87 all I had to do was extend the wire from where I cut the the plug off ran it in with the power wires then spliced plug back on and am running a RE WORKS airfilter right off the throttle body with 94 shorty header and plugged EGR.RUNS GREAT and really cleaned up the engine compartment.
chilsam is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
