3/4 shift solonoid
baddis
20+ Year Member
Solid Axle Swap
Avon,il
2014
ok i have an 88 stx with the a4ld. first thing when i take off it shifts normal. then after about 3 miles it kicks out of o/d pulled codes and get a 3/4 shift solonoid . so how do i check this?
Not really sure how to check it But the stupid selenoid is in the tranny, which means pulling the pan and the valve body to get to it.
somebody has to know how to test this :( i havent been able to find a fsm for 88 and the Haynes doesn't cover it. looked at a Haynes tranny rebuild manual and it covered everything BUT the a4ld
2/4 shift solenoid
Ebay has a couple different rebuild/troubleshooting manuals strictly for the A4LD trans for about $10.00 each. I bought one for reference when rebuilding my trans and it had about two dozen pages of troubleshooting charts and detailed instructions on checking each solenoid. Just search "A4LD manual". Hope this helps.
Cocoa, Interested in reading the troubleshooting charts and making a couple of bucks to help pay for the book?.. I really don't have time to wait for it to get mailed.. :-(
Vehicle: 1993 Aerostar AWD A4LD
Problem: Don't move...up and stopped moving when pulling into the driveway. ( no previous signs ( noises/slippage )
Fluid level fine.
Mileage 181k, and serviced at 173k and all was fine...nice fluid and no magnetic "stuff" in pan.
Engine: runs fine
NOT: The shifting linkage...as it shifts...holds "park" etc
History:
Trans serviced 174k... at 174.5k November-2006 I moved from Montana to Mpls, MN... another 1,200 miles and no problems. ( now at 175.7k )
11/06 - 4/07 Racked up all the rest of the mile except for 350 of them ( 180.6k ) Then moved 2 blocks from work from 5/1/07 - 8/3/07 and only drove maybe 150 miles..
8/3 move to Wisconsin 350 mile trip... Pull into freinds auto shop ( mainly GM guys, no Ford electrical code checking ability, and they don't do transmissions )
At this point, I noticed a very small trans fluid leak between block/trans... maybe 4" round... Checked fluid...still fine... He gave me sealer/conditioner...but I didn't put it in.
Sits a few days...no leaks...drive a few miles...still OK... then, drive into town...make it back out...and dies ( no more movement..no sounds etc) in drive.
Only thing is, that when I went on the 3.5 round trip, is that when I started out...the airbag light was flashing.
Have read all posts here on this site, and can't seem to find an exact problem...
Have read all:
http://www.turbotbird.com/techinfo/AutoTransFix/A4LD_Fix.htm &
http://home.att.net/~performance2800/A4LD.html
Problem also = Ford dealership closed up 2-3 days before this...
Any thoughts anyonbe?
Thx in advance
Jim
NOTE: this is a response from me to another post in this section.... After looking over wiring drawings and testing... and probing, I finally broke down and had a code scan done. This may not be your problem, but my problem was in the ECU. Turns out that my computer was not working correctly and not shifting from 3 to 4. If you have a spare one hanging around, maybe try plugging it in and see if that cures your issue. If not, it's rather easy to figure out. First step, confirm you have power (12V) coming from the center connection (red wire) of the three pin plug on the left side of the transmission with the key in the run position and engine off. If you have power there, then check the other two leads for continuity. The coloring on the connection is the same as the colors on the computer plug in. These two leads are located next to each other. Mine were a brown wire with a light blue tracer and a white wire. If you have continuity in these wires (no breaks) odds are, you have either a faulty shift solenoid or a faulty ECU. Remember, this is just MY EXPERIENCE. Your problem may be different.
