Go Back   The Ranger Station Forums > Engine & Transmission Forums > Transmissions
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 10-11-2011, 11:44 AM   #1
TroutFinder
TroutFinder's Avatar
Year: 2000
Make: Ford
Model: Ranger XLT 4wd
Engine: 4.0, bone stock with k&n drop in.
Class: 4x4 to get where you want to be.
Used For: Everything I ask of it.
TroutFinder is on a distinguished road
Unhappy Rattling sound again
I read this thread, and it sounds like the same prob. I'm having. Tranny sounds like you threw a hand full of inch and a half rocks into an empty concrete mixer.
Started abruptly the morning after I installed new to me 1700# rear springs, took out the add-a-leaf because it raised the ass up 3" higher than the front and I could not find anywhere to get a "Mullet" to complete the look. They were off of a 2007 Ranger so there was < an 1/8" difference in the eye to eye measurement. Less than the dia. of the bolt so should not be a problem, however...
Thought heat shield, checked, nope. Only rattles in gear, forward or rev.
Changed fluid and filter and it got better, but did not go away.
Tranny gets hot as indicated when the OD light starts flashing and it wants to go int OD at about 30 mph. Shut down, cool down and computer reset abates that, until next time. It threw a pressure related code when it did this but I can't remember exactly what it was and am loath to try and recreate this condition.
It stalls when I go from drive to reverse or from reverse to drive. Not from park/neutral into gear.
Took it to the tranny shop prior to fluid change and the tech. looked at the fluid and said it needs rebuilt to the tune of $2600 plus labor. He didn't drive it or even touch the shifter. Not sure, but it looks like about 8 hours out and in. That's $3600 plus, OUCH!!!
When I drained the fluid there was a-lot of very fine metal dust in the pan stuck to the magnet and 3 rice grain (plain white rice, not arborio or other larger grained rice) sized pieces of non steel (aluminum?) pieces of metal in the pan.
Could it be just the TC, or do I need a tranny? Looks like I can get the TC for a buck and a half to two hundred. I can't find the tranny rebuilt for less than $1800 plus core and shipping that I ain't got right now.
Park it? burn it? leave the keys in it and put a sign out stating "Steal Me"?
Oh yeah, 2000 Ford Ranger XLT, ext. cab, 4.0l. pushrod. 4 speed auto, 4wd. electric transfer case. 110000 hard miles.
Any help, suggestions or even ridicule would be very appreciated.
Thank you all for such a great resource.
TroutFinder is offline   Reply With Quote
Old 10-11-2011, 12:27 PM   #2
brinker88
Premium Member
brinker88's Avatar
Year: 1993
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Used For: Weekend Warrior
brinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to behold
Default
Ever changed your filter? (tranny filter I mean)
__________________
Obsession is a word justifying your insanity. We ARE the 4x4%.
Build Thread
brinker88 is offline   Reply With Quote
Old 10-11-2011, 12:36 PM   #3
BDAB
BDAB's Avatar
Location: People's Republic of Michiganistan, United Socialist Republic of America
Year: 99, 96
Make: Lincoln, Ford
Model: Continental, F350 CC dually
Engine: 32v DOHC 4.6L V8, powerstroke
Class: fwd, 2wd
Used For: rice killer,Because I wanted it
BDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud ofBDAB has much to be proud of
Default
You need a rebuild bro. Or convert to 5spd manual. Those rice grain size piece are out of the torque converter and are likely throughout the transmission.
You might find a used one.
__________________
Quote:
Ain't it funny what power and money can do to the soul of a man.......
BDAB is offline   Reply With Quote
Old 10-11-2011, 12:36 PM   #4
TroutFinder
Year: 2000
Make: Ford
Default
Changed filter with fluid change, post tranny shop visit.
Old 10-11-2011, 12:42 PM   #5
TroutFinder
Year: 2000
Make: Ford
Default
It is easier to get forgiveness than permission. Words to live by, no lie. If I replace the TC and go for now, will it kill the new TC before I can afford to replace the tranny?
Old 10-11-2011, 12:45 PM   #6
BDAB
BDAB's Avatar
Year: 99, 96
Make: Lincoln, Ford
Class: fwd, 2wd
Default
Seriously, your transmission is screwed. When that overdrive light flashes like that your transmission has an internal temp of around 300*f. Your box is cooked........ Likely due to a disintegrated torque converter. You need a rebuild....... Check aamco....... They rebuilt the 4r70w in my Expedition for $2600 all inclusive.
__________________
Old 10-11-2011, 12:49 PM   #7
TroutFinder
Year: 2000
Make: Ford
Default
Thank you for your response. It's what I thought, but Having been out of the circle for a while I hoped for a different answer.
Peace.
Old 10-11-2011, 12:52 PM   #8
BDAB
BDAB's Avatar
Year: 99, 96
Make: Lincoln, Ford
Class: fwd, 2wd
Default
My expedition did the same thing in billings montana while on vacation. Internal temp of 312*f and non magnetic metal shavings throughout. The TC grenaded and took out the rest. It sucks, I wish I could give you better news. But a used car is a crap shoot, thats all there is to it.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
