| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Communications This forum is for CB & HAM radio, cellphones, PDAs, in-cab computer installations and GPS. |
Thread Tools | Display Modes |
#1 |
Year: 1986
Make: Ford
Model: Ranger
Engine: 2.9
Class: 4x4
Used For: Puddle jumpin,gettin stuck
Rep Power: 9 ![]() iTrader: (0)
I know that I'm gonna need to run my Co ax cable from the antenna to the CB so what's the best day to get it into the cab? Doors jam? Or drill a hole somewhere Anne put a rubber gromit in there to seal it off from water?
__________________
My Build Thread: Clicky! Mods:4" RC lift,33's,rednecked fender flares,toolbox. Plans:SAS and 38's |
Tweet
#2 |
Year: 2003
Make: ford
Model: ranger
Engine: 2.3 4 cylider
Class: 2WD Off-Road
Used For: daily driver & Off Roading
Rep Power: 0 ![]() iTrader: (0)
I went through my firewall
__________________
03 ford ranger xl 4 cyl with 3 inch body lift and 31 inch m/ts |
Tweet
#3 |
Year: 1986
Make: Ford
Model: Ranger
Engine: 2.9
Class: 4x4
So you went under the truck then?
__________________
Tweet
#4 |
Year: 2002
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: Daily Driver
Rep Power: 20 ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
My era of Ranger has a grommet in the floor right below your feet when you're sitting in the truck... So that's where I ran mine through.
__________________
Click --> 2002 Ford Ranger 4x4 |
Tweet
#5 |
Year: 1986
Make: Ford
Model: Ranger
Engine: 2.9
Class: 4x4
I didn't see one so maybe ill have to run it through the firewall but that's alot of wire.
__________________
Tweet
#6 |
Year: 2006
Make: Ford
Model: Ranger XLT Extended Cab
Engine: 4.0L
Class: 2WD Country
Used For: Shenanigans
Rep Power: 22 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
then get your drill
__________________
Camburg BTF mid-travel kit, 64's, 33x12's,E-Fan Conversion, 4.56 8.8, McNeil Glass |
Tweet
#7 |
Year: 1986
Make: Ford
Model: Ranger
Engine: 2.9
Class: 4x4
Lol I have a ahole already in the firewall that is already there just need to run to radioshack and get the Co ax.
__________________
Tweet
#8 |
Year: 2006
Make: Ford
Engine: 4.0L
Class: 2WD Country
remember, antenna and wire should be the best quality you can buy.
__________________
Tweet
#9 |
Year: 1986
Make: Ford
Model: Ranger
Engine: 2.9
Class: 4x4
Care to elaborate? What would you recommend for wire?
__________________
Tweet
#10 |
Mall-Rated
Year: 1990,1994
Make: Ford
Model: Bronco II, Ranger
Engine: 2.9L, 4.0L
Used For: Crawling over things
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
Mine has grommets in the rear cab floor behind the seats. I cut a hole with an Xacto knife and ran the coax cable through there.
RG-58U cable is fine for CB (<30 MHz) IF it has a good-quality shield braid (or a 100% foil wrap). There's literally tons of crap 58U cables that don't have this however (Radio Shack's garbage is probably the absolute worst these days ), your chances of getting a good quality cable are much better if you stick with RG8X or 8M cable (which will almost universally have a foamed center insulation too, which is also better).
__________________
'90 Bronco II XLT 5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s '94 Ranger XLT 6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s |
Tweet
#11 |
MALL CRAWLER POST WHORE!
Year: 1988
Make: Ford
Model: Bronco II
Engine: 4.0 v6
Class: 4x4
Used For: Taking my Money
Rep Power: 51 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (4)
rg8x gets my vote.. i don't use 58u.. had to many coax issues in the past..
Tweet
#12 |
Year: 1988
Make: Ford
Model: Ranger XLT
Engine: 2.3
Class: 2WD
Used For: Get to Work/Tow Rig
Rep Power: 4 ![]() iTrader: (0)
please for the love of your CB dont go to rat shack, find a truck stop or CB shop that has the rg8 and not mini 8 (rg8x) ....... i know all my rat shack has is crap for coax
I hope you also know about setting your SWR so you dont fry your radio, if not ask, ill post up what you need to know edit: mini 8 will be ok IF you are not running a linear (amp) Last edited by 88ranger89camaro; 10-10-2011 at 10:02 PM. |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
